ECT Stealth PRO shift knob
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Mar 8, 2019.
  1. May 16, 2020 at 12:50 AM
    #2421
    siniquezu
    siniquezu Well-Known Member
    I'm too stupid to figure it out so can anyone trace which cables i would need to trigger to use the ect button? I saw how to do it for the anytime camera but not the newer camera solutions one.
  2. May 16, 2020 at 8:44 AM
    #2422
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    The ECT button has nothing to do with the radio wiring. its a plug/switch that may be where your problem started.
    go look at this
    https://youtu.be/eFaqc8LkOa4
  3. May 16, 2020 at 7:32 PM
    #2423
    GoldenTaco27
    GoldenTaco27 Well-Known Member
    Blake
    Long Beach Ca
    2017 Tacoma DCSB TRD Off Road
    @hungoverland on IG, King 2.5" EXT Travel w/ Archive Garage shock relocation, Icon RXT leafpack, 285 Nitto M/T's, bronze Raceline Defender wheels, TJM front/rear bumpers, TJM Sliders, Prinsu Cabrac, Katzkin leather, RSI Smartcap EVO topper, OV Tuned, MESO everything, Spyder headlights and tail lights, center mounted infant restraining system (CMIRS) \m/
    Will these DIY kits be available again anytime soon? Any word on the back ordered knobs from toyota?
    Tacospike likes this.
  4. May 18, 2020 at 10:02 AM
    #2424
    Justin7841
    Justin7841 Member
    Justin
    2020 Cement Tacoma TRD OR
    Noob Question here - Working on connecting the second button to activate the Anytime Camera System, I remember seeing in this thread that it's possible, just not sure I've seen a diagram or how it was done and cant seem to find those posts again through the lengthy thread, even with the search function
    From the extra pigtail connector, there are the Yellow and White wires, which I need to just connect to the lines heading into the relay, but do I need to use both wires from the stealth knob? Does one ground and one connect to the relay?
    Just want to make sure I'm not shorting out my system or wiring lol
  5. May 18, 2020 at 10:08 AM
    #2425
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Snap pics of your wiring once you get it worked up.
    I'm thinking of doing this too, but also was considering the park assist button.
  6. May 18, 2020 at 10:45 AM
    #2426
    Justin7841
    Justin7841 Member
    Justin
    Found this. https://www.tacomaworld.com/threads/ect-stealth-pro-shift-knob.597659/page-108#post-22845869
    https://youtu.be/bRVlJMvPyo4
    It Looks like you tap the Meso Switch wires into the Green & Red wires of the ABC harness.
    White --> Red 12v
    Yellow --> Green Front Camera Wire
    As a side note/clarification for others thinking of doing this. The stealth knob button is a momentary button, so it will activate the camera only while you hold down the button, and then turns back off once you release the button. (which works for me perfect on those moments of trying to park in a tight space or just trying to see over the "hump" when off-road)
  7. May 18, 2020 at 10:51 AM
    #2427
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Greg.Brakes.Tacos likes this.
  8. May 25, 2020 at 12:44 AM
    #2428
    CP40
    CP40 Well-Known Member
    Toyota Tacoma TRD off-road 2020
    Now all we need is the video that shows us how to hook it to the parking assist... The holy Grail of the right shift knob button.
  9. May 25, 2020 at 2:46 AM
    #2429
    CAG Gonzo
    2018 OR DCLB BarRed
    What's with the drive to wire that up? I always leave it on. Not knocking on anyone for wanting to do it, I just don't understand why.
  10. May 25, 2020 at 3:30 AM
    #2430
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    I turn it off when pulling my trailer...between that and temporary front anytime camera for the momentary right switch is what I'd like to be able to do...obviously only one option for the one button.
  11. May 25, 2020 at 6:45 AM
    #2431
    CP40
    I guess I could do that. What do you have for the second switch?
  12. May 25, 2020 at 12:04 PM
    #2432
    CAG Gonzo
    2018 OR DCLB BarRed
    Ah thanks. Hadn't thought of that. I've only towed once but did find the BSM/Parking Assist annoying. Never thought to turn them off.
    Front camera! I've set it to the left switch and ECT on the right. Very handy for Walmart parking wheeling.
    58electricman likes this.
  13. May 25, 2020 at 2:53 PM
    #2433
    Greg.Brakes.Tacos
    Greg
    wanna be mods
  14. May 25, 2020 at 3:13 PM
    #2434
    CAG Gonzo
    2018 OR DCLB BarRed
    Yep, since both switches are identical. I just route the ECT wire to the right switch instead of the default left.
  15. May 25, 2020 at 6:30 PM
    #2435
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I’m glad I got the beat sonic camera… i don’t need to hold it down to keep camera activated (just a simple press keeps front cam on) without any latching relay either.
    I activate it every time I park, it’s super convenient at the shift knob
  16. May 26, 2020 at 2:07 PM
    #2436
    airmac_11
    airmac_11 Well-Known Member
    2019 Cement DCSB Premium/ Tech TRD 4x4 Sport
    Where did you purchase your beat sonic at?
  17. May 26, 2020 at 9:54 PM
    #2437
    baldbeardedtaco
    FL
    Honestly I can’t remember… maybe Amazon or directly from manufacturer. Just google it and I’m positive you’ll find something
  18. May 26, 2020 at 10:55 PM
    #2438
    58electricman
    58electricman Well-Known Member
    San Diego,Calif.
    18' TRD Sport Black DCLB, & 05' Sport Pre-Runner Black DCSB
    Icon Coilovers & UCA's, Maxtrac 4" lift Spindles, Falken MT 285/70/17 Tires, Mickey Thompson Classic III Wheels 17X9 -12mm 4.53in Backspace, Bilstein 5160 Rear Shocks, TRD Cold Air Intake, Aries Action Trac Side Steps, Rough Country Speedometer Calibrator, Shift Sense Pro, Pedal Commander, Bakflip MX4 Bed Cover, Mountain Hatch Tailgate Insert, TRD Pro Grill, Start-X Remote Start, Pop n" Lock Tailgate, OEM Bed Mat, OEM Cargo Divider, OEM Bed Step, MORIMOTO 5500 35W HID's, ORACLE H11 - VSeries LED Highbeams, MESO Stealth Pro Shift Knob, MESO Puddle Pods, MESO Ultimate Turn Signals, MESO Total Tail Stage 1, MESO TRD Blk Start Button &Trim Ring &Coin Tray & Gasshole, Hondo Phone Mount, Clazzio Leather Seats, Vantrue Dash Cam, Off Grid/Blue Sea Fuse Block & Tray Mount, Beat-Sonic CS6EP W/ Natika Front Camera, Kicker Speakers/Subaru Tweeters & 300W Amp & 8"Hideaway Subwoofer, CADDY Train Horns, Redline Hood Struts, Automatic ECT PWR Power Mode Default Always ON, RAV4 Blind Spot Mirrors, Matt Gecko LED hood light engine kit, SEVENS Tailgate Letter Inserts, Smittybilt 2781 5.65CFM Air Compressor, AVS Window Visors, All Window Tint, RHINO USA Recovery Accessories, KTJO4X4 DRIVER'S SIDE GRAB HANDLE (Installed), DARTH VADER, & a STORM TROOPER, etc...
    Yea, just Google Beat-Sonic, they are out of Cali, $175...easy to install, I got the Natica Camera on Amazon $29. You have to get the camera separate!
    Beat-Sonic CS6EP Toyota Front Camera Interface...
    Don't know how to do a link with my phone...
  19. May 27, 2020 at 11:30 AM
    #2439
    reymataco
    reymataco Well-Known Member
    Denver, CO
    2020 DCLB Off Road Premium in Slowsand
    @MESO Got my knob kit installed a couple weeks back, been tooling around with it. This is my favorite mod so far, hands down. Thanks!
    MESO[OP] and 58electricman like this.
  20. May 27, 2020 at 6:08 PM
    #2440
    TacoTaco-BurittoTaco
    TacoTaco-BurittoTaco Well-Known Member
    James
    Georgia
    2023 TRD Off-Road DCSB
    Stock
    Does anyone have a wiring diagram to place the second switch on the knob to activate the front camera?
