ECT / Towing / Hills
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2021SR5V64WD, Apr 7, 2021.
  1. Apr 7, 2021 at 1:10 PM
    2021SR5V64WD
    2021SR5V64WD [OP] Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Probably discussed before but let's bring it up again.
    The trip from Phoenix to say the Grand Canyon is nice but there are a few
    steep hills to climb - coupled with hot-weather road signs advise to turn off A/C
    to prevent over-heating and I've seen many cars go up in flames ( literally )
    on that trip.
    Questions:
    1. Can the ECT button be engaged while driving? Say I'm doing 60-65 realize
    I'm about to hit some elevation can I just push it on or should it be done from
    a complete stop.
    2. And that begs the question if using ECT and the road becomes nice and
    flatter can I disengage at 60-65 or do I need to stop first.
    3. Is driving with ECT full-time that big of a deal or should we not do it.
    4. Can it be used in conjunction with 'Sport' mode?
    We're talking about a 1,000 lb teardrop, 200-300 pounds of cooler and gear in
    the truck bed, 300 pounds max in the cab not like we're hauling 4,000 pounds
    but I believe the ECT delivers a smoother go at it while towing.
    Thanks to this board I know I'll get a myriad of responses - and damn fast too.
  2. Apr 7, 2021 at 1:12 PM
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    1. Yes
    2. Yes
    3. No
    4. Yes
    Good talk.
  3. Apr 7, 2021 at 1:13 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    driving with ECT on is completely okay and you can turn it on/off to your hearts desire.
    2016Tacoman likes this.
  4. Apr 7, 2021 at 1:14 PM
    anthonynoriega
    anthonynoriega I just wanna disappear and find nothing.
    Anthony
    Idaho
    2019 Tacoma SR5 QS DCLB
    OV Tune 2.0, UpTop Rack, RTT, Total Chaos Bed Stiffeners, LED Grille Lights, Custom decals and pretty stickers.
    Wait... but how are baby Tacoma's made?
    kite_325, brtnstrns, 02Duck and 4 others like this.
  5. Apr 7, 2021 at 1:15 PM
    TXnativeson
    TXnativeson Mmmmm tacos
    Alabama
    2019 TRD Sport DCSB 4X4 MGM
    Second this.
    4. Yes and it is not sport mode. Read the manual on towing it tells you to use ECT in conjunction with "S" mode in S5 on the hwy to lock out the 6th gear
  6. Apr 7, 2021 at 1:15 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Well you see a daddy tacoma finds a mommy tacoma and they go play in the woods. I left out some details since it seems like our audience may not me into the nitty gritty details.
    02Duck, Doc62 and DWD484 like this.
  7. Apr 7, 2021 at 1:20 PM
    anthonynoriega
    Anthony
    Idaho
    Wait, its not "Sport" mode? Even with the SR5?
    Don't tell me... it stands for Standard...
  8. Apr 7, 2021 at 1:26 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    S stands for Sequential not Sport
    02Duck, TXnativeson and DWD484 like this.
  9. Apr 7, 2021 at 1:30 PM
    anthonynoriega
    Anthony
    Idaho
    Son of a....
    TXnativeson likes this.
  10. Apr 7, 2021 at 1:33 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Towing you'll be in S4+ECT. 3rd up and down hills, maybe 2nd if it gets steep. Don't be afraid to rev it.
    71tattooguy and 2021SR5V64WD[OP] like this.
  11. Apr 7, 2021 at 1:36 PM
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    A lot of times I'll forget to immediately hit the ECT button after I start up the truck, so I'll just push it while going down the road. No issues with that. Same with turning it off. I always use ECT and S-mode when towing and plenty of people use it all the time and there haven't been any problems.
  12. Apr 7, 2021 at 1:37 PM
    TXnativeson
    Alabama
    Just calls it "S mode" in the manual and mainly talks about how it is used for engine braking. But my understanding is it shifts as you said "sequentially" and stops at the highest gear you have selected instead of picking what ever gear the ECU wants at that moment in time. The manual calls "D" "AI-SHIFT" .... Ooooh fancy.
  13. Apr 7, 2021 at 1:38 PM
    AZ_J
    AZ_J Well-Known Member
    Ahwatukee, AZ
    2019 TRD OR 4x4 DCSB
    265/75r16, sliders, softopper, roof rack
    When I went to Greer in mine from Phoenix, TRDOR not an SR5, so I cannot comment on overheating, But I pulled a ~1500lb side-by-side with a ~1000 lb trailer. I was in the "sequential" shift mode with ECT on always. The steeper hills I would be doing S3 moderately flat S4 and super flat/downhill in S5. Never use S6 while towing, or so its been preached on here a lot.
    I never once worried about having my A/C in July & September when that trip ocurred
  14. Apr 7, 2021 at 1:42 PM
    TXnativeson
    Alabama
    Direct quote page 186 "Vehicles with an automatic transmission: To maintain engine braking efficiency and charging system performance when using engine braking, do not use the transmission in D. If in the S mode, the transmission shift range position must be in 5 or lower. "
  15. Apr 7, 2021 at 2:02 PM
    2021SR5V64WD
    Thanks for the clarification - !
    TXnativeson[QUOTED] likes this.
  16. Apr 7, 2021 at 3:44 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i installed the messo ECT "on at start up" mod about 4 years ago on my 2016, ECT has been on every time i drive the truck since.
  17. Apr 7, 2021 at 3:54 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Definitely hold a lower gear, the upshifts, only to downshift are what really heats the transmission/converter. Revs won't hurt the engine.
  18. Apr 7, 2021 at 4:01 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Grandpa was a logging truck driver- I'll always remember him telling me; go down in the gear you would go up in, and gears down, revs up.. he was talking about my little 22re but I still apply it today.
    Chew[QUOTED] likes this.
  19. Apr 7, 2021 at 4:15 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    S4 and ECT is the best setting for hills. 4th is the lowest gear that the torque converter will lock, keeping tranny temps down. If you can maintain speed and keep the torque converter locked S4 is the best gear.
    2021SR5V64WD[OP] likes this.
  20. Apr 8, 2021 at 5:50 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Imo, driving with ECT on all the time without towing anything heavy shouldn't be used. You'll over-rev your shift points plus get worse fuel economy. All else is ok.
