ECU help 3 gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redfox83, Apr 28, 2025.
  1. Apr 28, 2025 at 1:41 PM
    Redfox83
    Redfox83 [OP] New Member
    Jimmy
    2016 tacoma
    My ECU is in self mode can't get anything to work truck start fine I had code that I didn't fix and the battery die the ECU forgot or is not working will don't get me wrong it is in limp mode the only time the truck power up when I turn key on I don't got no radio nothing but truck start to runs but soon I turn key off inter lights everything goes dead
  2. Apr 28, 2025 at 1:49 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    :confused:
    Might need a translator, but @tonered... is this something a tuner can help with?
  3. Apr 28, 2025 at 1:51 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Man this is a tough first post. Sorry Jimmy.
    I'd start with whatever code you had that you didn't fix.
    Chew and Bertw192 like this.
  4. Apr 28, 2025 at 1:56 PM
    Off Topic Guy
    "My ECU is in safe mode. I can't get anything to work. The truck started fine, I had a code that I didn't fix, and the battery died. The ECU forgot or is not working well. Don't get me wrong; it is in limp mode. The only time the truck powers up is when I turn the key on. I don't have any radio or anything else, but the truck starts to run; but as soon as I turn the key off, the interior lights and everything goes dead."
    My interpretation is a code took the truck out of commission, it sat long enough for the battery to die, the ECU somehow forgot it was an ECU because it had no power, and has now defaulted to limp mode.
  5. Apr 28, 2025 at 1:58 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Nicely done. That's what I interpreted as well.
    I know some of the tuner folks have been able to unbrick some ECU's that didn't take a tune flash appropriately, so they may be able to help here.
  6. Apr 28, 2025 at 2:03 PM
    Off Topic Guy
    Definitely not my expertise, but I'd start with a known good battery, address any and all codes, and spend a day or two with a multimeter/test light. I'm sure if multiple components are out (not getting power), many of them likely all lead back to a common source. I'd probably also lock and unlock my doors with the key fob a few times to ensure the security system isn't kicking in or doing something weird after the power loss.
    SR-71A and Bertw192[QUOTED] like this.
  7. Apr 28, 2025 at 2:12 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Unfortunately, limp modes typically clear after after cycling the ignition.
    The fact that it is running is good. I just have no idea other than a short / rodent damage causing an issue?
    Look for any evidence of a nest or chewing on insulators.
  8. Apr 28, 2025 at 2:24 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Wow, slow down and type, I know talk to text is convenient, but it's not getting you any help.
    SR-71A, jmneill and t0p_d0g like this.
  9. Apr 29, 2025 at 5:12 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    does not compute...
    but welcome aboard anyways
  10. Apr 29, 2025 at 5:14 AM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Where did you go to school?
  11. Apr 29, 2025 at 7:02 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I prefer not to share my thoughts.
    Off Topic Guy likes this.
  12. Apr 29, 2025 at 8:08 AM
    Redfox83
    Jimmy
    2016 tacoma
    I replaced everything the truck coder read it still saying check Stabilizer I did put new tires on it when I try to reset it I will not could it be in the key fob
  13. Apr 29, 2025 at 8:29 AM
    Off Topic Guy
    Steering angle sensor is a pretty common failure after a drained battery. Maybe read some threads about it. Heres one:
    Check vehicle stability control system | Tacoma World
