ECU needed! 01, 3.4l, 4x4, m/t
Discussion in '1st Gen. Tacomas (1995-2004)' started by BajaBound, Dec 11, 2016.
  1. Dec 11, 2016 at 9:44 PM
    BajaBound
    BajaBound [OP] Member
    01 Tacoma
    Supercharger, Fox Suspension, ARB front bumper
    Been battling both knock sensor codes for months now and after replacing both sensors and harness twice as well as double checking everything else that could set off the knock sensor codes, I'm thinking that I have a bad ecu. How common is it for these things to go bad? Anyone had a similar issue or any input? Thanks for your time...
  2. Dec 11, 2016 at 9:56 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    i saw an ecu here in Texas craigslist a few days ago...if you cant find one locally to you, maybe look in other CL listings in other areas, and have some of us help you w shipping?
    jjsul likes this.
  3. Dec 12, 2016 at 7:29 AM
    ramonortiz55
    Ramon
    Texas
    stock
  4. Dec 12, 2016 at 7:32 AM
    trd518
    trd518 Well-Known Member
    2016 DCSB
    My 2001 threw code after code and after replacing a ton of parts it turned out to be the ecu. So it is probably fairly common
  5. Dec 12, 2016 at 8:25 PM
    chaosrob
    chaosrob Well-Known Member
    I have a 99 manual from a 4runner if they are the same?
    did you use shielded wire on the knock sensors? A lot of times, at least on Supra's, if you do not use the shielded wire the interference code will not go away. I would typically run a whole new wire back to the ecu from the sensor using shielded cable to eliminate any issue with splicings on the wire, sometimes it is corrupted where it cannot be seen. Not sure if it is applicable on Tacos as I am still learning, just a suggestion
