Ecu pinout
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 999TRD, Jul 13, 2024.
  1. Jul 13, 2024 at 9:53 PM
    999TRD
    999TRD [OP] Member
    2017 trd sport 4x4
    Stock
    Hi, is there anyone here that might have a pinout or know where i can find it. I need to know the location of the wires that go from the knock sensors and where they go on the ecu
    Thanks.
  2. Jul 13, 2024 at 9:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    For the 3.5?
    Dm93 likes this.
  3. Jul 13, 2024 at 9:59 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    E11 connector of ECU. Note. Each bank has a junction connectors.
    Mice chewed through wires?
    Dm93 likes this.
  4. Jul 13, 2024 at 10:00 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Bank 1 on the right side of engine goes to pins 19 and 29 on connector E11.
    Bank 2 on the left side of engine goes to pins 18 and 28 on connector E11.
    Lol. I see I posted same time as a few others.
    Dm93 likes this.
  5. Jul 13, 2024 at 10:02 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Bank 1 is E11 Pin 19 (Black) and E11 Pin 29 (White)
    Bank 2 is E11 Pin 18 (Green) and E11 Pin 28 (Red)
  6. Jul 13, 2024 at 10:03 PM
    TnShooter
    Deogee
    STOCK
    All of us were all over it at once.
    Not too often that happens.
    Dm93[QUOTED] likes this.
  7. Jul 13, 2024 at 10:05 PM
    999TRD
    999TRD [OP] Member
    2017 trd sport 4x4
    Stock
    Yes, problem is they chewed up the part that goes to the main harness, so I'm having a really fun time trying to fix it, and yes is for the 3.5, thanks a lot yall.
    TnShooter likes this.
  8. Jul 13, 2024 at 10:07 PM
    Vlady
    Issy, WA
    It seems there have been a weekly knock sensor lose.
    TnShooter[QUOTED] likes this.
  9. Jul 13, 2024 at 10:12 PM
    999TRD
    999TRD [OP] Member
    2017 trd sport 4x4
    Stock
    It's really a pain, thats why i was looking for the pinout, I'm looking into making a whole new harness and cancel the old part, that way i can stress less trying to reach between the cab and engine in order to fix where it's broken
  10. Jul 13, 2024 at 10:15 PM
    Vlady
    Issy, WA
    Is it easy to unwrap a few inches if the harness and solder broken wires?
  11. Jul 13, 2024 at 10:19 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The knock sensor wires are shielded to suppress electrical noise, that kinda complicates repair and also running a new un-shielded harness may have issues with electrical noise.
    Toycoma2021 and Vlady[QUOTED] like this.
  12. Jul 15, 2024 at 8:34 PM
    999TRD
    999TRD [OP] Member
    2017 trd sport 4x4
    Stock
    It is kind of difficult since is not the harness that connects to the actual knock sensors, it's the part where that harness connects to, the one that goes to the main harness, the thing here is that this tiny part is just tucked behind the engine, i ended up soldering it but i had to disconnect several plugs all the way from the transmission in order to safely pull it to where i could cut the insulation, solder the new connector (left if a bit longer so that is not to tight like it is from the factory) put heat shrink insulation in each little wire, then put it back into the oem conduit, wrapped tightly with electrical tape, then a wrap with 3m temflex cloth tape, then another piece o wire loom just to make sure lol. Kinda tedious but i wanted to make sure it doesn break anymore.
    My truck is running incredibly smooth now btw
    Vlady, TnShooter and Dm93 like this.
  13. Jul 15, 2024 at 8:48 PM
    999TRD
    999TRD [OP] Member
    2017 trd sport 4x4
    Stock
    This is the wire that was broken, it came off of a pin from the connector, I forgot to take a photo when it was fixed, guess I was just too excited to finally had it doneScreenshot_20240712_194646_Gallery.jpg
  14. Jul 15, 2024 at 11:54 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    The only thing I could possibly add to that would be to use "adhesive lined" heat shrink. Good work.
