ecu programmers and computer chips
Discussion in '4 Cylinder' started by turbothompson13, Apr 25, 2011.
  1. Apr 25, 2011 at 1:47 PM
    turbothompson13
    turbothompson13 [OP] Well-Known Member
    Jay
    Parkersburg, WV
    08 2.7L
    4.5 inch front suspension lift, 3 inch rear end block lifts, 4 inches total lift, k&n cold air intake, racing shocks, front bilstien rear fox shocks, n fab pre runner light bar/bumper with fog lights, 33 inch nitto dune grapplers and ballistic jester 18 inch wheels.
    has anyone found any or used any performance programmers or ecu chips on there 2.7L? also i am looking for one that is a 05+ if anyone knows anything about these please let me know, finding parts for a 4 banger tacoma are about impossibe.
  2. May 1, 2011 at 12:54 PM
    surfntaco
    surfntaco New Member
    Ed
    Ventura
    SR5 access cab
    Chips are used in forced induction motors (turbos/superchargers) to reprogram fuel maps and force more air in faster. They don't do much for normally aspirated motors. Toyota has pretty much optimized everything already.
  3. May 1, 2011 at 7:12 PM
    turbothompson13
    Jay
    Parkersburg, WV
    08 2.7L
    yeah, i was just wondering if anyone had found anything that helped pull out a few more ponies. the only thin i have found so far has been the urd maf calibrater. since i have a exhaust and a cai.
  4. May 1, 2011 at 7:33 PM
    frog13
    frog13 Well-Known Member
    Since the manufactures have to make all engines conform to EPA standards(lean settings...jetted/injected) then I presume ther is no way to make your injected engine run,more on the rich side....to help decrease operational temps?.You would probably have to install an entirely different/reconfigured ECU?.
  5. May 2, 2011 at 10:47 AM
    turbothompson13
    Jay
    Parkersburg, WV
    08 2.7L
    i was kinda thinking that too. for a lot of newer cars ecu chips dont really work. you usually have to get the whole ecu, i have seen a few things that supposedly work tho, and i may give something a try because i want any power i can get, because obviously that 4 banger dont have a whole lot.
