ECU reset sequence is not starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tumblinw, Jun 30, 2025 at 6:07 AM.
  1. Jun 30, 2025 at 6:07 AM
    Tumblinw
    Tumblinw [OP] New Member
    Yesterday
    2014 Tacoma
    None
    Battery died. Recharged battery. Held terminals together for 5 minutes. Reconnected positive then negative. All I get is horn beeping, not rapid beeps to begin reset sequence. Door is closed. What might be the issue?
  2. Jun 30, 2025 at 6:12 AM
    Clearwater Bill
    Billy
    Largo Florida
    All I've ever done is charge battery with cables connected, or swap battery when it was dead.
    Never had any noises. Started, drove, done.
  3. Jun 30, 2025 at 6:18 AM
    Tumblinw
    Yesterday
    2014 Tacoma
    None
    I've run this sequence (that I learned from a Toyota mechanic) before and it has worked and is necessary to reset the factory anti-theft system.
  4. Jun 30, 2025 at 6:29 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    uhhh I don't think so
    Batteries get swapped all the time. No need to do any special reset procedure
  5. Jun 30, 2025 at 6:31 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like an aftermarket alarm system, the stock system won't do that.
  6. Jun 30, 2025 at 6:34 AM
    Bishop84
    Bishop84 Well-Known Member
    That’s a VW trick, not a toyota trick. You cannot reset Toyota security systems with any sequences. It sounds like a security alarm or maybe the battery is backwards
  7. Jun 30, 2025 at 6:43 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Hit the unlock button on the fob or lock and unlock the drivers door. That might get the alarm to shut up
