ECU Swap from later tacoma into 95-96?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Avsguy33, Mar 20, 2011.
  1. Mar 20, 2011 at 12:53 PM
    Avsguy33
    Avsguy33 [OP] Well-Known Member
    Wondering if anyone has done this? Tried to search but couldnt find any for sure info on if this will work. Reason being is I am looking to supercharge the taco and since it is the DD I would prefer it not to be down while troubleshooting. Have read speculations about the URD kit with stock ECU but I would think if you could just swap ECU's then install the TRD charger everything would work. Any other issues with swapping the ECU?
  2. Mar 20, 2011 at 8:04 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I would defiantly be interested in this to SC my Taco too..
  3. Mar 21, 2011 at 10:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bump, anyone have any idea if this works?
  4. Sep 11, 2013 at 9:58 AM
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Did you ever figure this out? I'm in the same position except with a turbo instead of S/C. I keep getting BS answers every time I call Toyota or the local yards about year compatibility and exact CPU part numbers and stuff. I'm in Thornton too BTW
  5. Sep 11, 2013 at 2:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes it works. Although if your turboing..you should go about it in a way it won't matter anyways.
    but for SC. You want a 97 ecu with the exact same options as you in terms of motor and tranny and 4wd.
  6. Sep 12, 2013 at 3:53 AM
    GioGuitarDude
    Gio
    Cold air intake
    Ok cool. I called Gadget from URD and he said that it retards the the timing from the boost itself, not just the S/C itself necessarily. I'm not sure how true that is, but would you recommend just getting a 97 ECU anyway? Thanks a bunch for your time
