ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Nov 7, 2018 at 7:50 AM
    #2321
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Naw win 10,, uninstalled and trying again
  2. Nov 7, 2018 at 7:52 AM
    #2322
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Weird. Our laptop is old (8yrs?) and started as a Win7 64bit machine, upgraded to Win10 64. No problems with that version of TS.
  3. Nov 7, 2018 at 7:53 AM
    #2323
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Hmmm I’ll let ya know in a few min ,, download ,, replace Main menu file and key an dahoykdk be good to go ?
    tonered[OP] likes this.
  4. Nov 7, 2018 at 7:56 AM
    #2324
    tonered
    tony
    Lynnwood, WA
    Yup. It should be that easy. The installation took forever, but no problems.
    That said. To do the update, all you need is to have TS installed, I believe. Then, the CUW file becomes executable.
    If you get TS running, then you can do the customizations and monitoring.
  5. Nov 7, 2018 at 1:18 PM
    #2325
    mstrbrc
    mstrbrc Well-Known Member
    ABQ
    '16 DCSB OR MT
    I also found out that you can program new keys as well using this TS as well... You just gotta buy the Toyota ‘H’ key, get it cut, and you can program it yourself using TS; I’ve done two keys myself.
    *The two that I programmed have been basic keys only, not the key that has the lock/unlock/panic buttons on it (although I’m sure there’s a way to program those keys/buttons as well).
    tonered[QUOTED][OP] likes this.
  6. Nov 7, 2018 at 1:24 PM
    #2326
    tonered
    tony
    Lynnwood, WA
    I saw that in TS but didn't mess around. I was trying (unsuccessfully) to find a way to kill the key in chime.
    Someone in one of the recent TPMS threads said that Torque Pro can program sensors so that you can have a second set of tires. I need to dig into that to verify since I don't recall seeing that in the past. Carista will now let you do that if you have an active subscription.
  7. Nov 7, 2018 at 2:05 PM
    #2327
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    I programmed several H keys with the built-in buttons to my 2nd gen with TS and a cheapo Amazon OBD cord. Worked great, and got rid of the separate remote. You have to use a different process to program the remote button functions of the key. On the 2nd gen, it was some combination of ignition key turns, open-close doors shenanigans.
  8. Nov 7, 2018 at 2:21 PM
    #2328
    csmacomber
    csmacomber Well-Known Member
    NA
    I had to re-program my key/remote after I got an AJT fob (not sure what I did wrong, as the chip worked after programming, it was just erased). I used the one I didn't break, erased everything but that and then programmed the AJT one again. There is a separate section for programming the remote parts. It took me about 10 minutes to do the whole thing.
    Since I had the tactrix cable already, that is what I used, but key programming is not even remotely the concern that a ECU flash is so I wouldn't be concerned at all about a cheaper cable for that.
  9. Nov 7, 2018 at 2:27 PM
    #2329
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    hey guys downloaded ts,,trying register and the key i have doesnt work,,,solutions ???
    TeecoTaco and tonered[OP] like this.
  10. Nov 7, 2018 at 3:50 PM
    #2330
    corgimas
    corgimas Well-Known Member
    rob
    North Shore of Massa-who-setts
    0rangeSeventeenShortSportStick
    uhhhh....dog fur?
    There is a map? who would have thunk it ;)
    jkcashin[QUOTED] and tonered[OP] like this.
  11. Nov 7, 2018 at 4:05 PM
    #2331
    Belding
    Belding New Member
    2016 Sport DCSB 6MT
    I took mine in because it was running rough. They ran an update for TSB0125-18. Which is written up as an idling issue. I don't know if it is the same software update as this, but it felt like a new truck on the way home. It might be easier to get them to do something if you mention rough idling. It specifically mentions MT in it.
  12. Nov 7, 2018 at 4:11 PM
    #2332
    tonered
    tony
    Lynnwood, WA
    It is said to be the same software.
    Enjoy!
  13. Nov 7, 2018 at 4:16 PM
    #2333
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    Good to know. I've noticed rough idle but I've ignored thinking it's still breaking in.
  14. Nov 7, 2018 at 4:26 PM
    #2334
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Us or canada
  15. Nov 7, 2018 at 4:31 PM
    #2335
    jkcashin
    jkcashin Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
  16. Nov 7, 2018 at 6:15 PM
    #2336
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
  17. Nov 7, 2018 at 6:20 PM
    #2337
    tonered
    tony
    Lynnwood, WA
    Nice!
    Thanks!
  18. Nov 7, 2018 at 6:20 PM
    #2338
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Search for mainmenu.exe in Program files (x86) and replace the file in that location, with the one from the .rar. Then fire it up and enter the key.
  19. Nov 7, 2018 at 6:23 PM
    #2339
    tonered
    tony
    Lynnwood, WA
    He's been down that path. Something weird is up. I asked him to uninstall and search for any remnants left behind just in case, then reinstall.
    He was up to the point that it just wouldn't accept the key.
    Tacoma816 likes this.
  20. Nov 7, 2018 at 6:55 PM
    #2340
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Dood, how you making out? I can set up a webex tomorrow am with you, show me what you're seeing and walk you thru what is needed.
    shakerhood, MOC221_ and tonered[OP] like this.
Thread Status:
