ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Apr 26, 2019 at 10:18 AM
    #2621
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    It was a 2016. I had to change the VIM in TS too (opposed to the easy drop down on the update file). Then we had fun with Windows 10 being a jerk and finicky on connecting at times.
    But we got it all done. Easy enough when it worked..
  2. Apr 26, 2019 at 10:19 AM
    #2622
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Excellent!
  3. Apr 26, 2019 at 10:22 AM
    #2623
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    I read your response and I was like ‘it can’t be that ea.. and we’re in.’
    Didn’t figure TS would need finessing like the CUW, but what do I know :)
    pinochle and tonered[QUOTED][OP] like this.
  4. Apr 26, 2019 at 10:24 AM
    #2624
    tonered
    tony
    Lynnwood, WA
    Hahaha!
    I'm all for the easy fixes. The other day, I was struggling with wifi at home. I did look over to be sure the router was turned on, but that ended up just being Windows messing with me.
    kakwvu[QUOTED] likes this.
  5. Apr 26, 2019 at 10:25 AM
    #2625
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    I’m running Windows 10 on boot camp and was convinced it was a combo of that and my USB C dongle for the new MacBooks.
    Tech is supposed to be getting simpler. Wrong.
    tonered[QUOTED][OP] likes this.
  6. Apr 26, 2019 at 10:29 AM
    #2626
    tonered
    tony
    Lynnwood, WA
    That was always the hope, but we are definitely more complex. I do love having the info I need at my finger tips.
  7. Apr 26, 2019 at 4:34 PM
    #2627
    crigg93
    crigg93 Well-Known Member
    Chuck
    Rochester, NY
    2018 M/T MGM TRD Sport
    Ovtuned, Rokblokz, Toyo A/T II's on F5s, URD U-Spec, Afe Intake, Fox shocks, Dirtking UCAs, KC Flex ambers.
    Finally got around to setting up techstream V12 and running the CUW file for my 2018. Install went very smoothly, truck runs great!
  8. Apr 26, 2019 at 4:56 PM
    #2628
    tonered
    tony
    Lynnwood, WA
    Awesome! Nice work.
    :cheers:
    crigg93[QUOTED] likes this.
  9. Apr 26, 2019 at 9:10 PM
    #2629
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    Is a later version of TS needed to install this update onto a 2018? The regkey isn't working for me....I saw the post attempting to explain how to find the "cracked" version of this, but I didn't understand it.
  10. Apr 26, 2019 at 9:35 PM
    #2630
    tonered
    tony
    Lynnwood, WA
    The version linked in the OP will work on your 2018. Just follow the steps. It makes the TSB software (the CUW file) executable. You won't be able to use TS to customize your Taco, but you will get the 04A71 tune.
    For the key to work, you have to swap the EXE file. If you didn't do that, you have to fully uninstall TS, I believe.
  11. Apr 26, 2019 at 9:36 PM
    #2631
    Tacoma816
    Fred and Ginger
    Uninstalling again now. The swap thing isn't making sense to me for some reason, might need to sleep on it.
  12. Apr 26, 2019 at 9:37 PM
    #2632
    tonered
    tony
    Lynnwood, WA
    Definitely take your time. Get TS working by itself. Then plug in an do the tune.
    Tacoma816[QUOTED] likes this.
  13. Apr 27, 2019 at 3:49 AM
    #2633
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    There’a a video linked in there that shows how to install it.
  14. Apr 27, 2019 at 8:30 AM
    #2634
    Tacoma816
    Fred and Ginger
    Video helped, thank you. Everything seemed to install, but I just drove it around the block and there's no change, 1800-2000 rpm the problem still persists. Is there a way to verify I'm on A7100 with TS?
  15. Apr 27, 2019 at 8:38 AM
    #2635
    Tacoma816
    Fred and Ginger
    Just checked it with Carista, I'm on A7100, does it just take time for this issue to "learn" to go away?
  16. Apr 27, 2019 at 10:15 AM
    #2636
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    Yes. Your trims reset on flash.
  17. Apr 27, 2019 at 11:12 AM
    #2637
    tonered
    tony
    Lynnwood, WA
    You should feel the shifts are easier and a slight bump in power.
    kakwvu likes this.
  18. Apr 29, 2019 at 12:28 AM
    #2638
    Tacoma816
    Fred and Ginger
    I want to feel that, but the 1800-2000 RPM stutter is just as-if not more- bad as ever. If Mat replies tomorrow with the reg files, I’ll be immediately applying. Pray for me.
    tonered[QUOTED][OP] and Dogg23 like this.
  19. Apr 29, 2019 at 5:21 AM
    #2639
    tonered
    tony
    Lynnwood, WA
    Sorry to hear that.
    The tune will be very different.
  20. Apr 30, 2019 at 4:23 PM
    #2640
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    Ok, so my report after a few more months... the truck is just much more predictable off the line now. That early lag is still there but only slightly. It's MUCH more easier to overcome off the line. There's a few "Fast and Furious" early morning stop lights where two lanes go to one lane quickly after the light. Needless to say, I don't have any issue beating cars off the line after this update. In general, I'll still stand by my previous comments that the truck is much more pleasing to drive and not fighting RPM's as much from idle. It drives a bit more similar to my first gen 3.4 but with more pep (more HP).
    tonered[OP] likes this.
Thread Status:
