ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Apr 30, 2019 at 5:13 PM
    #2641
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    When did you notice changes? Immediately or how long after the update? I’m a tank of gas in and notice nothing.
  2. Apr 30, 2019 at 5:59 PM
    #2642
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    I noticed the decrease in lag pretty much right away. The truck relearned some it’s other behavior about a week in. However, the early lag was much less noticeable. I did start driving with a heavier foot after the change and maybe that helped the re-learning process a bit. However, I feel the update took away that early lag pretty well.
  3. May 3, 2019 at 2:49 PM
    #2643
    ETnmgmYota
    ETnmgmYota Member
    Justin
    houston,tx
    2017 Trd Sport 6mt
    I hope you guys can help me, I tried researching a little but didn't come up with anything, I am trying to do the update myself and I cannot get the cuw files to work. When I click on them it says that the software has to be registered. Does anyone know what I am doing wrong?
  4. May 3, 2019 at 2:52 PM
    #2644
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    You need to fully uninstall TS and start again. Follow the installation instructions. Mainly, once it is installed replace the menu.exe file with the one in the zip file. Then, enter the text in the key.txt file.
    pinochle and kakwvu like this.
  5. May 3, 2019 at 2:54 PM
    #2645
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    And make sure you have the right VIM selected in TS too. It’s not as apparent as the CUW file.
    tonered[QUOTED][OP] likes this.
  6. May 3, 2019 at 3:00 PM
    #2646
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    And make sure you’re using a Tactrix! Not a generic USB cable.
  7. May 3, 2019 at 3:02 PM
    #2647
    ETnmgmYota
    ETnmgmYota Member
    Justin
    houston,tx
    2017 Trd Sport 6mt
    I have techstream itself working, finally. I thought the cuw file is separate from techstream.
  8. May 3, 2019 at 3:02 PM
    #2648
    ETnmgmYota
    ETnmgmYota Member
    Justin
    houston,tx
    2017 Trd Sport 6mt
    I am using a tactrix and v13 of ts.
    pinochle[QUOTED] likes this.
  9. May 3, 2019 at 3:05 PM
    #2649
    pinochle
    NNJ
    It is a separate file.
    tonered[OP] likes this.
  10. May 3, 2019 at 3:07 PM
    #2650
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    If TS is working and connects to your truck, the file should load.
  11. May 3, 2019 at 3:16 PM
    #2651
    ETnmgmYota
    ETnmgmYota Member
    Justin
    houston,tx
    2017 Trd Sport 6mt
    TS is working, I messed with it a little. I changed the amount of flashes when you bump the turn signal to 4 just to make sure it was working and it did. I tried deleting the files and redownloading them, but that didn't change anything.
  12. May 3, 2019 at 3:17 PM
    #2652
    ETnmgmYota
    ETnmgmYota Member
    Justin
    houston,tx
    2017 Trd Sport 6mt
    Is there anyone who has posted a tutorial on how to do this?
  13. May 3, 2019 at 3:23 PM
    #2653
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    If TS is working, the CUW should work fine. I assume you’re selecting the correct VIM and update file?
  14. May 3, 2019 at 3:28 PM
    #2654
    ETnmgmYota
    ETnmgmYota Member
    Justin
    houston,tx
    2017 Trd Sport 6mt
    VIM is openport 2.0, I'm not sure what the update file is.
  15. May 3, 2019 at 3:29 PM
    #2655
    ETnmgmYota
    ETnmgmYota Member
    Justin
    houston,tx
    2017 Trd Sport 6mt
    Sorry, its been a long day. I selected the 0033-18 file.
  16. May 3, 2019 at 3:30 PM
    #2656
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    You said TS v13.x. As far as I'm aware v12.x is only hacked version out there. Might be the issue
  17. May 3, 2019 at 3:36 PM
    #2657
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    It’s not. The links in the OP work.
  18. May 3, 2019 at 4:23 PM
    #2658
    tonered
    tony
    Lynnwood, WA
    The 1st Post has all the details.
  19. May 3, 2019 at 4:26 PM
    #2659
    ETnmgmYota
    ETnmgmYota Member
    Justin
    houston,tx
    2017 Trd Sport 6mt
    Update on my situation. I installed the older version of techstream and the cuw file started working. Might help someone in the future.
    InfernoPhil, pinochle and TeecoTaco like this.
  20. May 3, 2019 at 4:42 PM
    #2660
    TeecoTaco
    SW Ontario
    Yup, that's what I was sayin...good work
Thread Status:
