ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Jul 3, 2019 at 8:51 AM
    #2721
    johnbets
    johnbets Member
    Calaveras County, CA
    2018 Tacoma Sport MT
    Fiberglass shell, 1K# pull-out tray, lumber rack, OVTune 87 octane, base tune
    Trudging through the OV tune. Support takes days to answer each question which is a little frustrating. Right now when I get to "Identify" I get "ToyFlash has stopped working"...
  2. Jul 3, 2019 at 8:56 AM
    #2722
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    It is a two person operation with Mat supporting all Toyotas tunes, plus he's expecting. So, that is not really out of line?
    That might be you antivirus software? Have you excluded the Toyota Flash folder?
    Do you have
  3. Jul 3, 2019 at 9:07 AM
    #2723
    johnbets
    johnbets Member
    Ha yeah I thought it might be that. I'm glad to know that so I can relax.
    I have turned off my anti-virus software. That's how I got this far actually. Do I still need to exclude Toyota Flash folder. Anyway I'll take a look. Thanks!
    tonered[OP] likes this.
  4. Jul 3, 2019 at 9:09 AM
    #2724
    johnbets
    johnbets Member
    OK I've excluded Toyota. Going to give it another try.
  5. Jul 3, 2019 at 9:09 AM
    #2725
    tonered
    tony
    Lynnwood, WA
    If you have AV turn off, excluding the folder won't get you any further.
    It will allow you to not have to worry about turning it off in the future though.
    So, but I have no other ideas to help you.
  6. Jul 3, 2019 at 9:14 AM
    #2726
    johnbets
    johnbets Member
    Yeah that didn't work. Okay I'll wait for Mat. Thanks again.
  7. Jul 3, 2019 at 9:21 AM
    #2727
    johnbets
    johnbets Member
    So looking at threads related to "ToyFlash has stopped working" I see stuff about downloading the Tatrix drivers. I assumed that happened when I downloaded the Flash Folder but maybe not? If not how does one go about downloading the drivers?
  8. Jul 3, 2019 at 9:22 AM
    #2728
    su.b.rat
    su.b.rat broken truck
    https://www.ovtuned.com/pages/instructions-downloads
  9. Jul 3, 2019 at 9:41 AM
    #2729
    johnbets
    johnbets Member
    Yes! I had not downloaded the drivers. Onward!
  10. Jul 3, 2019 at 9:54 AM
    #2730
    johnbets
    johnbets Member
    I have two versions of Flashing instructions. V.1 has instructions for flashing a file all the way through. V4.2 has me sending my output info to OVTune and getting the flash files from them. Can I use either instruction? Why the change? The new version seems less technically challenging so maybe they've been experiencing problems with operator error and tying to dumb it down (greatly appreciated by this dummy). Will it hurt to try the V.1 instructions?
  11. Jul 3, 2019 at 11:11 AM
    #2731
    johnbets
    johnbets Member
    FWIW I followed the V.1 instructions and successfully flashed the truck. It's running much better! Thanks everyone.
    Steelhead Taco and tonered[OP] like this.
  12. Jul 3, 2019 at 12:33 PM
    #2732
    tonered
    tony
    Lynnwood, WA
    That is the older version for folks with dongles for security, not the REG files.
  13. Jul 3, 2019 at 1:24 PM
    #2733
    johnbets
    johnbets Member
    Interesting that the V.1 instructions worked but only would let me download 1.05 version at 87 octane and base tune. All other configurations would not download. I flashed that version and it has made a big improvement it the surging/stuttering problem I was having. I let Matt know and I expect he will send me the other tuning options. For now I am thrilled that it seems to have made the truck run in an acceptable manner.
  14. Jul 3, 2019 at 4:45 PM
    #2734
    tonered
    tony
    Lynnwood, WA
    You should be able to download Base and FOB for all octanes available.
    Performance, GL, and 1.05.1 are AT only. 2.0 is not out yet.
  15. Jul 4, 2019 at 9:58 AM
    #2735
    johnbets
    johnbets Member
    Thanks tonered. Great information. I'm getting better at using this forum and found a thread that addresses all the questions I have about the different tunes. I'll try them all! Still getting a little bump here and there but 80% better and an extra mile per gallon (18mpg with fiberglass shell, pull-out tray and lumber rack). My rhetorical question is, why on gods green earth is Toyota not addressing this? It baffles the mind.
  16. Jul 4, 2019 at 3:49 PM
    #2736
    tonered
    tony
    Lynnwood, WA
    You're welcome. Enjoy the new setup.
    They probably think they corrected it with the TSB. Give them some more time to do more.
  17. Aug 13, 2019 at 10:53 AM
    #2737
    TacoMan408
    TacoMan408 Well-Known Member
    CA
    2016 TRD Sport Manual
    OVTune (04B13+1.05 87 FOB), Morimoto XB Headlights, Toyota LED Fog Lights, Toyota TRD Lift Struts, Wheelers Progressive AAL, TRD Pro Tail Lights, 17" TRD Pro SEMA wheels, BFG 285/70R17, TRD Skid Plate, Bakflip MX4, OEM Audio +, Anytime Front Camera, G-Tek Fab Door Sill Protectors, WeatherTech Floormats Suntek Carbon 35% Tint
    Apologies if this is a stupid question...is the cable that comes with OV Tune a Tactrix cable (or equivalent)? I'm looking upgrade my ECU to and was a little unclear if I need to get a new cable.
  18. Aug 13, 2019 at 10:55 AM
    #2738
    tonered
    tony
    Lynnwood, WA
    It is a Tactrix cable, but OVT says that it is changed a bit for OVT. It will work just fine to load the TSB tune.
    TacoMan408[QUOTED] likes this.
  19. Aug 13, 2019 at 10:58 AM
    #2739
    TacoMan408
    CA
    Thank you sir
    tonered[QUOTED][OP] likes this.
  20. Aug 13, 2019 at 11:00 AM
    #2740
    tonered
    tony
    Lynnwood, WA
    You're welcome!
    :cheers:
    Just in case, you can also do all the dealer customizations within TS also (number of blinks for the one touch signals, turn off seat belt chimes, etc.).
Thread Status:
