ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Dec 23, 2019 at 12:54 PM
    #2901
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    tsb flash was successful, now I'm having trouble loading OVTune. P5flash utility has all the buttons greyed out. I cannot click identify. Tactrix is selected connected to truck and key is in on position.
    I should add that I just got my laptop back from RMA repair and it has been reflashed. I dont think that should affected the registration. I loaded the same registration file sent to me originally.
  2. Dec 23, 2019 at 12:57 PM
    #2902
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Weird.
    There is a new version of FM. For it to work, you have to completely uninstall the old version. Start Menu changes from OVTune Toyota Flash to OVTuned. Without uninstalling, I was greyed out also.
  3. Dec 23, 2019 at 12:59 PM
    #2903
    Garab
    The computer's been completely wiped and a fresh windows loaded. I downloaded everything fresh this morning. I should have the latest and newest version of everything running. FM says version 1.3.0
  4. Dec 23, 2019 at 1:03 PM
    #2904
    tonered
    tony
    Lynnwood, WA
    Ah! I did you reinstall the REG file? Is you System ID still the same as before?
  5. Dec 23, 2019 at 1:24 PM
    #2905
    Garab
    yes I reinstalled the reg file, as far as I know the system ID is still the same. It's the same laptop. EVGA reflashed it after repair and sent it back to me clean. That wouldn't change the system ID would it? how do I check?
    Am I able to move my truck with 04A71 ECU and 04A70 ovtune? or is that a very bad idea?
  6. Dec 23, 2019 at 2:24 PM
    #2906
    tonered
    tony
    Lynnwood, WA
    Do the Identity in FM. I don't know if that would change the System ID, but at least one person posted that an OS update changed theirs.
    The TSB tune wiped OVT. You are 04A71 Stock right now.
  7. Dec 23, 2019 at 2:35 PM
    #2907
    Garab
    That's the problem, all the buttons are greyed out and unclickable in TM. So I should have no problem dirivng it then, that's a bit of a relief.
  8. Dec 23, 2019 at 2:54 PM
    #2908
    tonered
    tony
    Lynnwood, WA
    Yes. You are good to go until OVT can get you a new REG file.
  9. Dec 24, 2019 at 11:41 AM
    #2909
    Garab
    Waiting on OVT. My first impressions of 04A71 inspire alot of hope for the OVT 2.0. Just the stock file alone for 04A71 is so much smoother. The sputtering and delay surge in 2nd gear and 3-4 seems completely gone. (we'll see once the tune settles in if that's truely the case) but it's really an huge improvement.
    For anyone out there still on 04A70, do yourself a huge favor and get the TSB done if you can or flash it yourself to 04A71.
    Now that I've got the clutch MC replaced, this TSB flashed, and the ADM done, slowly but surely this truck is starting to drive the way it should have from the factory.
  10. Dec 24, 2019 at 9:06 PM
    #2910
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Did your system id actually change? Is your name next to the system id in flash manager? if so try reinstalling the drivers/software.
  11. Dec 25, 2019 at 7:42 AM
    #2911
    Garab
    Yes my name's next to the SystemID in p5flash utility. I am using Flash Manager version 1.3.0 , and p5flash version 1.2.2
    After digging a little deeper I went to the original emails I sent mat when setting up OVTune the first time. The SystemID currently in p5flash utility does not match the System ID that I originally emailed Mat back in the day nor does it match the registration file sent back to me.
    I used this registration file again when setting up the laptop for this flash attempt so I dont quite understand how it could be different. It's the same registry file, same laptop (reflashed), same truck other than 04A71 now being loaded. But Idont get access to the flash utility buttons whether it's plugged into the truck or not.
  12. Dec 26, 2019 at 9:06 AM
    #2912
    nuckingfuts
    nuckingfuts Well-Known Member
    Anyone in New York area?
  13. Dec 27, 2019 at 3:17 PM
    #2913
    18TRDOR
    18TRDOR Well-Known Member
    Kyle
    New Philadelphia, OH
    2018 TRD OR DCSB 6MT
    No dice again from the dealership today. Has anyone used techstream on a Mac running windows 10 through Virtualbox? Trying to avoid buying a windows ten laptop haha.
  14. Dec 27, 2019 at 3:21 PM
    #2914
    tonered
    tony
    Lynnwood, WA
    I know that @Shellshock is running Basecamp on his for OVT, but I don't think anyone has posted about using it for TS and the TSB tune flash.
    You could try loading it and testing the connection. Maybe do a customization or two before getting crazy on the flash?
    There is no real registration required with TS. So, you could use a friend's PC?
    BTW, there is a new TSB. TSB-0013-19. It lists a bunch of Toyotas including the MT Tacos, but the noted symptom is an odd one.
  15. Dec 27, 2019 at 3:27 PM
    #2915
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    I think there was a cat who tried this via a VM (unsure if was Virtual Box) and didn't he brick his ecu? Don't mean to insert fud but going vm from MAC OS just adds another point of failure.
    Tony's advice is good tho, try the customizations first to check for comm success...baby steps, you're a test pilot
    shakerhood likes this.
  16. Dec 27, 2019 at 3:39 PM
    #2916
    tonered
    tony
    Lynnwood, WA
    I thought that guy was using a cheap cable? TW post mud.
    At least it was in a separate thread, so it should be easy to find.
    I love it when my shit-ass memory works:
    https://www.tacomaworld.com/threads...-doing-the-b04-update-ovtune-fixed-it.564091/
    shakerhood and TeecoTaco[QUOTED] like this.
  17. Dec 27, 2019 at 3:39 PM
    #2917
    Shellshock
    Iowa
    I’ve got mine setup currently using bootcamp. I’ve also done the TSB via a windows 7 vm using vmware fusion. I won’t use any other virtualization software because the drivers can be janky and cause problems. The free ones are free for a reason (they suck).
  18. Dec 27, 2019 at 3:42 PM
    #2918
    Shellshock
    Iowa
    it might have been both. I don’t remember. The usb pass through on virtual box has always been problematic.
  19. Dec 27, 2019 at 3:42 PM
    #2919
    tonered
    tony
    Lynnwood, WA
    Did you use Bootcamp in the past?
    Just trying to remember for future questions. :cheers:
  20. Dec 27, 2019 at 3:43 PM
    #2920
    tonered
    tony
    Lynnwood, WA
    Found it and edited the post. My craptastic memory worked this time.
    TeecoTaco likes this.
Thread Status:
