ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Oct 23, 2020 at 6:07 PM
    #3501
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Just successfully updated my 09/2019 built 2020 6AT from 04B80 to 04B81. Used the T-0023-20 file on this thread, thank you to those that posted it. I didn’t have any prior complaints, so I can’t speak to any improvements. I thought I would share some details of the flash process, specifically battery voltage.
    Concerned about ensuring the minimum 11.8V, I had a DMM on the battery terminals and a large old school battery charger with selectable charge limit of 10A and 30A. With the ignition on - engine off (all accessories and lights off) at the 10A setting the DDM had 12.33V and CUW reading 12.1V and it was slowly dropping as I watched it for 10 min. I switched to the 30A setting for some margin, which brought the DMM to 14.45V and CUW reading 14.1V sending in roughly 18A. It would seem a good idea to be using at least a 15A if not 20A capable charger during a flash.
    For reference, I have Techstream V15.20.21 with CUW 8.30.213, Drew Tech MFC2 cable.
    tonered[OP], daveeasa and Koolbreeze7 like this.
  2. Oct 23, 2020 at 6:49 PM
    #3502
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Interesting point. I got my cable as we were heading out for the weekend. Hoping to flash my 2016 next week. I have a battery charger but it’s not super beefy. I wonder what my chances of bricking are. I did replace the stock battery with an optima but it’s not a North Star.
    tonered[OP] likes this.
  3. Oct 23, 2020 at 7:08 PM
    #3503
    Shellshock
    Iowa
    You’ll be fine
    tonered[OP] and daveeasa[QUOTED] like this.
  4. Oct 23, 2020 at 7:54 PM
    #3504
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Good info!
    I recently did a flash and TS wouldn't proceed due to battery voltage. I tossed on my jump pack and did not hit boost mode. It did just fine for the duration of the flash.
    ktbell444 likes this.
  5. Oct 23, 2020 at 7:57 PM
    #3505
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I just use a battery maintainer that can do 12v power supply mode. Battery voltage is either stable or slowly rising while flashing.
  6. Oct 23, 2020 at 9:59 PM
    #3506
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    What model? That mode is not too common for all but the high end. I read some brands have such high power draw during flashes that DIY people jumper cable them to a running vehicle.
  7. Oct 23, 2020 at 10:29 PM
    #3507
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    mattleg[QUOTED] likes this.
  8. Oct 24, 2020 at 11:39 AM
    #3508
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Any of you know why Techstream V14.20.019 won't accept the registration code? Mine was working fine, but now it keeps asking me to register. I've uninstalled and reinstalled, went through the entire process, but when I put in the reg code i=the window just pops back up asking for it again.
    Help needed, thanks!
  9. Oct 24, 2020 at 11:42 AM
    #3509
    harpo1
    harpo1 Well-Known Member
    I had the same issue. I just reran the code generator portion again and entered the new code and it worked.
  10. Oct 24, 2020 at 11:43 AM
    #3510
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    I found my error. I'm an idiot. I was typing a 1 instead of a 2... Less beer when playing with software...
  11. Oct 24, 2020 at 12:17 PM
    #3511
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Or more?
  12. Oct 24, 2020 at 1:32 PM
    #3512
    harpo1
    So if we flash this update does it void our warranty?
    tonered[OP] and RedWings44 like this.
  13. Oct 24, 2020 at 1:34 PM
    #3513
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Moreover, does this actually fix things?
  14. Oct 24, 2020 at 1:35 PM
    #3514
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    No. It's a Toyota OEM file.
    tonered[OP] and harpo1[QUOTED] like this.
  15. Oct 24, 2020 at 1:35 PM
    #3515
    lapoltba
    CT - 06076
    For the MT, 04B14 was a good improvement over stock 04B12 or 04B13.
    su.b.rat and tonered[OP] like this.
  16. Oct 24, 2020 at 1:36 PM
    #3516
    tonered
    tony
    Lynnwood, WA
    Good question!
    It is Toyota software. But, if you brick your ECU, then you could be out of pocket if you need to buy a new one. That said, it is only a soft brick. The ones that have been reported were able to be bench flashed.
  17. Oct 24, 2020 at 1:38 PM
    #3517
    tonered
    tony
    Lynnwood, WA
    Yes!
    I've witnessed it going from 04B12 to 04B13 to 04B14. Folks have told me the same on the recent TSB. Beyond that, there are examples of this in most every page in this thread.
    G8R_Taco and Shellshock like this.
  18. Oct 24, 2020 at 3:34 PM
    #3518
    Shellshock
    Iowa
    This is why I copy and paste lol
    G8R_Taco and tonered[OP] like this.
  19. Oct 24, 2020 at 4:26 PM
    #3519
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    04B31 to 04B33 was quite impressive. :thumbsup:
    tonered[QUOTED][OP] likes this.
  20. Oct 24, 2020 at 4:28 PM
    #3520
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    Don’t pee on the flash parade!! :rofl:
    How many times have YOU flashed Tony? :D:fistbump:
Thread Status:
