ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Nov 6, 2020 at 9:15 PM
    #3581
    CorbinDallas
    CorbinDallas Well-Known Member
    Corbin
    Tacoma
    16 MT OR
    I am trying to go back to the stock 04B14 TSB file. Since I have a OV 04B14 file flashed, techstream will not allow me to flash the TSB.
    When I first flashed the TSB, I used the flash utility to read the ECU creating a p5f file.
    Now, when I try to use the flash utility within VF tuner, I get this error message:
    Is there no way to go back to the stock file?
  2. Nov 6, 2020 at 10:35 PM
    #3582
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I replied to your other post. TS will only flash newer software than you have. It doesn't know that you have a tune in there.
  3. Nov 7, 2020 at 6:15 AM
    #3583
    Shellshock
    Iowa
    Just use the stock file thats in vF
  4. Nov 7, 2020 at 8:13 AM
    #3584
    CorbinDallas
    Corbin
    Tacoma
    16 MT OR
    I just discovered this option to download them but there is a server error and I can't DL atm
  5. Nov 7, 2020 at 11:09 AM
    #3585
    Shellshock
    Iowa
    In vF they are part of the install files
    c:\program files (x86)\vf tuner\tacoma
  6. Nov 7, 2020 at 12:21 PM
    #3586
    CorbinDallas
    Corbin
    Tacoma
    16 MT OR
    Thank you. You guys are amazing!
  7. Nov 16, 2020 at 11:48 PM
    #3587
    harpo1
    harpo1 Well-Known Member
    Just hit the OK button.
  8. Nov 17, 2020 at 12:38 AM
    #3588
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    You want to use it in offline mode and .cuw files are located in the first post. To start the update you double click on the .cuw file, don't try to open them from within Techstream.
  9. Nov 17, 2020 at 1:41 AM
    #3589
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    You don't need Techstream open, it will do it's thing and walk you through the steps.
  10. Nov 17, 2020 at 2:25 AM
    #3590
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Techstream will start on its own by opening the .cuw file. Without Techstream installed you cannot run the .cuw file at all.
    I haven't had any issues, personally, with having windows defender on or off, but that doesn't mean someone may have some setting that breaks the functionality. Easiest solution is to turn it off rather than find the exact setting to change.
    After installing the update then you can reset LV's via Techstream. It is recommended, and I believe the instructions are linked in the first post as well.
    Techstream is needed for both, the update and resetting LV's (if you don't have vFTuner to reset values). Basically, the .cuw file is associated with Techstream. Kind of like how an image or text file knows to open up with a specific program, the .cuw file will do the same.
  11. Nov 17, 2020 at 9:51 AM
    #3591
    SpheresDeep
    SpheresDeep Member
    Whenever I try to do step 21 it won't let me open anything because it says there is a virus. Even tried run anyway and it won't work. Any ideas?
    tonered[OP] likes this.
  12. Nov 17, 2020 at 9:52 AM
    #3592
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Try right button clicking on the file and running as administrator. If that doesn't work you'll need to disable all AV.
  13. Nov 17, 2020 at 9:56 AM
    #3593
    tonered
    tony
    Lynnwood, WA
    Like @ktbell444 said, you're A/V is still on. For Windows Defender, there are about four switches that you need to throw to turn it completely off.
  14. Nov 19, 2020 at 5:13 PM
    #3594
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    well, it's impossible to update ECU on work PC.
    They have certain settings I cannot change even if I'm disconnected from internet.
  15. Nov 19, 2020 at 5:18 PM
    #3595
    tonered
    tony
    Lynnwood, WA
    Probably no. Either the TS V14 or V15 needs admin access to install and register.
    You can use Bootcamp on a Mac?
  16. Nov 19, 2020 at 5:34 PM
    #3596
    whitedlite
    USA!
    3RD Gen TRD 4WD
    my 2010 MacBook probably won’t cut it with bootcamp
  17. Nov 19, 2020 at 6:04 PM
    #3597
    Shellshock
    Iowa
    It’s more than sufficient. Theres people running the tuning software on $200 shitboxes.
  18. Nov 19, 2020 at 6:19 PM
    #3598
    304_Taco
    304_Taco Well-Known Member
    Curtis
    Morgantown, WV
    16 TRD Sport DCSB MT
    All you should need is storage space and a flash drive. I did it on my 2012 MacBook last week with no problem at all.
    Apple has a guide on how its done, and windows 10 is free to download (minus the authentication code which isn't required to use windows, but is recommended by Microsoft).
  19. Nov 19, 2020 at 6:22 PM
    #3599
    Shellshock
    Iowa
    I setup bootcamp 3 years ago when i started tuning and never entered a key. It just stops you from getting updates. It’s no biggie, i only use it for the short period of time when I’m tuning
  20. Nov 19, 2020 at 6:25 PM
    #3600
    304_Taco
    Curtis
    Morgantown, WV
    This is the general consensus I found when scouring to make sure I wasn't going to brick my ecu. It seems to limit your ability to customize the wallpaper/theme, and adds a watermark to the lower right corner of the screen. Along with the lack of updates, but for the occasional techstream use it is perfect.
    If my plan was to use windows as my main software I would fork out the ~$90 for the code, but to use it a few times I don't see any problem in it.
Thread Status:
