ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Nov 29, 2020 at 10:35 AM
    #3641
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Ver 14 worked on my 2020. 4B81 (unsure which file you are referencing, away from my PC).
  2. Nov 29, 2020 at 10:41 AM
    #3642
    Shellshock
    Iowa
    I’ve never done this. Just check the voltage before flashing is above 12 and you’ll be fine
  3. Nov 29, 2020 at 10:41 AM
    #3643
    gForceDude
    gForceDude Well-Known Member
    Yes, the update from 04B80 to 04B81 is the one that I am asking about, and that is the perfect answer to that question - Thank You !
    :cheers:
    PapaRee and PhogDog[QUOTED] like this.
  4. Nov 29, 2020 at 10:43 AM
    #3644
    PhogDog
    20 MGM Sport
    I had the same question previously and a member told me 14 worked on their 2020 too.
    PapaRee likes this.
  5. Nov 29, 2020 at 10:52 AM
    #3645
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I have the same one as you and use 12V supply mode. Works great every time.
    These Taco's update fairly quickly, I'll give it that, but just flashed the girl's Camry yesterday and it was flashed in two parts, basically twice as long as it takes ours. Not worth the risk in my opinion. I'll flash tunes all day long without external power for my truck, but when it comes to updating the ECU, what's a few extra steps for added assurance?
    mattleg likes this.
  6. Nov 29, 2020 at 10:54 AM
    #3646
    gForceDude
    Good info - Thank You !
  7. Nov 29, 2020 at 10:59 AM
    #3647
    Shellshock
    Iowa
    I don’t have power when flashing TSBs in a parking lot lol
    also if you flash an early 16 truck, it’s a 2 part flash. Takes like 10 minutes.
    I always check the voltage in the precheck. If it’s too low, I’d go get another battery. Odds are it’s on its way out anyway..
  8. Nov 29, 2020 at 11:05 AM
    #3648
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    You can also jumper cable to a running vehicle, common for the European car crowd. Some can pull down 70A during a flash as it cycles high load components.
    PapaRee likes this.
  9. Nov 29, 2020 at 2:47 PM
    #3649
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Did this a few weeks ago flashing in a parking lot. The truck was at 11.5v. We just hooked up some jumper cables to the other running truck and everything was fine.
    Bottom line, do whatever you are comfortable with. If battery voltage is over 12v it's not going to drop significantly during a flash. Just turn off everything you can (lights, radio, HVAC fan, etc).
    Shellshock likes this.
  10. Dec 1, 2020 at 2:42 PM
    #3650
    SELAroadrunner
    SELAroadrunner Well-Known Member
    Ron
    WSNC
    17 Sport
    wheel decals
    Is the latest (2021) ECU the best version of any 3rd gen to date? If so, could one simply change a late model to it?
  11. Dec 1, 2020 at 2:53 PM
    #3651
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    It would be, but you can't update to it. ECU IDs have to match. When they drop a TSB for 04B05, you'll be as close as you can get.
    G8R_Taco likes this.
  12. Dec 1, 2020 at 4:26 PM
    #3652
    SELAroadrunner
    Ron
    WSNC
    17 Sport
    wheel decals
    Thanks Tony, what’s the likelihood they’ll be a 04B05? probably no ETA in sight....
    tonered[OP] likes this.
  13. Dec 1, 2020 at 4:28 PM
    #3653
    Shellshock
    Iowa
    Greater than zero.
    whenever Toyota gets around to it. They come outta nowhere.
  14. Dec 1, 2020 at 4:36 PM
    #3654
    tonered
    tony
    Lynnwood, WA
    Keep any eye on the nhtsa site.
  15. Dec 1, 2020 at 6:02 PM
    #3655
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    Are stock tunes octane learning? That seems like code and not tables/maps.
  16. Dec 1, 2020 at 11:12 PM
    #3656
    tonered
    tony
    Lynnwood, WA
    Yes. The Stock and 2.0 tunes are OL.
    G8R_Taco[QUOTED] likes this.
  17. Dec 2, 2020 at 3:58 AM
    #3657
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Wait, really? The stock tune?
  18. Dec 2, 2020 at 5:19 AM
    #3658
    tonered
    tony
    Lynnwood, WA
    Of course.
  19. Dec 2, 2020 at 5:26 AM
    #3659
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    I thought so then wondered how Mat made tunes that were non-OL. :notsure:
  20. Dec 2, 2020 at 5:32 AM
    #3660
    tonered
    tony
    Lynnwood, WA
    The code and access that he had inside the ECU before 2.0 was very different.
Thread Status:
