ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Dec 31, 2020 at 9:58 AM
    #3961
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Up to 16v is okay per the flashing TSB.
  2. Dec 31, 2020 at 9:59 AM
    #3962
    Teamrivers
    Teamrivers Well-Known Member
    Brent
    Atlanta, GA
    2018 TRD Off Road 4x4 DBL 5.5
    Diamond Back HD, full interior light change, DiodeDynamics main lamps, Caliraised amber fogs & ditches, Caliraised 25 Degree sliders no plate, SSO slimline front bumper w/ 20" LED Smitty Gen3 winch, Barricade rear bumper with rear in bumper lights from SuperbriteLEDs, Budbuilt rock 2 plates with rerouted exhaust, Method 306, 295 Ridge Graps. OEM Kings tuned from Filthy, Deaver Exp 1, SPC UCAs, 5.29 diffs. Dash mounted 1/4 threaded accessory plate. And a TRD Pro grill...assuming I qualify for pro status.
    Yeah I started without that connected and got the same error, and recently got the tender since it's an agm batt and i'm adding an auxiliary to the system. Just had time today to get back at trying the update.
  3. Dec 31, 2020 at 10:03 AM
    #3963
    Teamrivers
    Brent
    Atlanta, GA
    Whitedlite did or were you able to get this problem resolved on the 2018?
  4. Dec 31, 2020 at 10:06 AM
    #3964
    tonered
    tony
    Lynnwood, WA
  5. Dec 31, 2020 at 10:07 AM
    #3965
    Teamrivers
    Brent
    Atlanta, GA
    Does it matter what version of the Tactrix is used? I clicked on the ad at the bottom of this page to the Openport 2.0 on Amazon for 34 bucks, and it's a version E where mine is a version H.
  6. Dec 31, 2020 at 10:11 AM
    #3966
    tonered
    tony
    Lynnwood, WA
    You're using a $30 clone? If so, then that's the problem.
    The genuine Tactrix from tactix.com or vftuner.com is the least expensive, reliable option.
    Shellshock likes this.
  7. Dec 31, 2020 at 10:11 AM
    #3967
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Don't buy it from Amazon. It's fake, guaranteed. If that's what you are trying to use, that is your problem.
  8. Dec 31, 2020 at 10:14 AM
    #3968
    CDNTacoma2019
    CDNTacoma2019 Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    Fakes are everywhere....Walmart 3rd party sellers have Chinese Tactrix clones for $30 too. Not worth risking having to buy a new ECU.
  9. Dec 31, 2020 at 10:15 AM
    #3969
    lapoltba
    CT - 06076
    Yep, ebay wherever....
    It probably won't permenantly brick your ECM, but you will still have to buy the Tacrix adapter and bench flash to get it back anyway.
  10. Dec 31, 2020 at 10:16 AM
    #3970
    Teamrivers
    Brent
    Atlanta, GA
    Soooo...it was the computer he was using? I didn't see an answer prior to "that was it". I only have one windows laptop :(
    I got mine directly from Tactrix, the $170.00 version.
  11. Dec 31, 2020 at 10:18 AM
    #3971
    tonered
    tony
    Lynnwood, WA
    These arrows are your best friend on TW:
    Since you have the real Tactrix and DL'ed the drivers from their site, that should not be the problem. Do not use 3rd party drivers.
  12. Dec 31, 2020 at 10:18 AM
    #3972
    lapoltba
    CT - 06076
    His was a work computer and had security software locking things down. I doubt that is your issue. It sounds like a driver issue. You have two drivers when you shouldn't
    Go into device manager right click on the Openport device and do "uninstall". Make sure you check the box to delete the drivers.
    Unplug the adapter, reinstall the drivers, plug it back in.
  13. Dec 31, 2020 at 10:20 AM
    #3973
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    you are way misquoting me.
    no I never figured out the 18.
    the other quotes were on my 17 from a few weeks prior to the quote in question.
    tonered[QUOTED][OP] likes this.
  14. Dec 31, 2020 at 10:22 AM
    #3974
    tonered
    tony
    Lynnwood, WA
    Thanks for noting that.
    So, you never got the 2018 flashed?
  15. Dec 31, 2020 at 10:23 AM
    #3975
    Teamrivers
    Brent
    Atlanta, GA
    Thanks for the clarification, I thought I had read your posts clearly where you hadn't found a solution either, i'm stumped on what the issue could be. I've uninstalled/reinstalled drivers with no changes to that error popping up.
  16. Dec 31, 2020 at 10:26 AM
    #3976
    lapoltba
    CT - 06076
    Have you tried a different USB cable? Can you connect to the truck using Techstream?
  17. Dec 31, 2020 at 10:27 AM
    #3977
    whitedlite
    USA!
    3RD Gen TRD 4WD
    To both, no I recommended the guy go ahead and ask dealer to do it. I didn’t even try hooking back up to my truck yet, was busy over holidays. However I am now going to try to flash a tune on the 18 to see if it takes this afternoon when meeting up.
    good thing we’re both close to each other.
  18. Dec 31, 2020 at 10:33 AM
    #3978
    Shellshock
    Iowa
    And try a different USB port on the laptop
    tonered[OP] likes this.
  19. Dec 31, 2020 at 10:33 AM
    #3979
    Teamrivers
    Brent
    Atlanta, GA
    I have tried multiple cables and no Techstream won't connect. Unable to connect to VIM.jpg
  20. Dec 31, 2020 at 10:34 AM
    #3980
    tonered
    tony
    Lynnwood, WA
    Here, you went to the Setup menu, clicked on VIM, and selected the OpenPort drivers?
Thread Status:
