ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Jan 8, 2021 at 11:11 AM
    #4001
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I was puzzled by that one in daylight with the headlights on. It sounds like you hit all the stuff, esp with a charger connected. 1.5a is gonna take a while.
  2. Jan 8, 2021 at 11:12 AM
    #4002
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I decided to buy a battery maintainer that has 12v supply mode. Haven't had any issues with that.
  3. Jan 8, 2021 at 11:31 AM
    #4003
    dave82at
    dave82at Well-Known Member
    David
    Ontario/Canada
    2020 TRD Sport
    Tuned
    @ktbell444 what model of battery maintainer do you use?
    blitzkrieg3002 likes this.
  4. Jan 8, 2021 at 12:17 PM
    #4004
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
  5. Jan 8, 2021 at 12:19 PM
    #4005
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    I jumped 100AH deep cycle camper battery to it and was able to get through fine. Now going to flash B33 ovtune next. Thanks for the help all.
    ktbell444 and tonered[OP] like this.
  6. Jan 8, 2021 at 12:22 PM
    #4006
    tonered
    tony
    Lynnwood, WA
    You're welcome!
    Enjoy the new tune. :cheers:
  7. Jan 8, 2021 at 10:04 PM
    #4007
    beetledude
    beetledude Well-Known Member
    2020 TRD Offroad 4X4
    hi, really helpful thread. this will be the first time I am trying this. bought the tractrix cable, have TIS installed. I have some basic questions that I hope you can help with.
    1) I only have a battery maintainer (trickle charger), I don't think it will accomplish what is needed. My guess is that this recommendation is just in case the truck battery goes bad during the update, so that the flash doesn't stop mid stream. I do have one of those big jump starter lithium batteries. should I just hook that up instead?
    2) in the original and first post for the update instructions it says "key out of ignition". for newer trucks with push button start there is obviously no key. but with key out of ignition that means that the flash should be done with the tacoma completely off?
    thank you!
  8. Jan 8, 2021 at 10:09 PM
    #4008
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Not sure about the jump starter, but a few posts up I shared a link to what I purchased. Works great every time I use it.
    Yes, key can be in the ignition but in the off position. The update file will walk you through, step-by-step, on what to do and when to turn the ignition on and off (you'll do it multiple times).
    tonered[OP] likes this.
  9. Jan 8, 2021 at 11:20 PM
    #4009
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I used my maintainer on the 8amp setting.
    Start with the truck off (don't push the button) then follow the instructions on your computer. Acc is one push (foot off the brake!) And on is two pushes.
    tonered[OP] and PhogDog like this.
  10. Jan 9, 2021 at 6:52 AM
    #4010
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    @ReconSS0321
    keep an eye on this thread and the first page post by @tonered. All the information you would ever want to know is here - and the link where you can purchase the Tactrix from legit manufacturer.
  11. Jan 9, 2021 at 12:55 PM
    #4011
    beetledude
    thank you everyone, successfully upgraded this morning. a few notes that might help:
    1) when launching the upgrade file it complained that it couldn't connect to the network and that "updated messaging" or something like that would not work. I ended up just hitting cancel and proceeded with the update as normal.
    2) I have a Noco Boost XL portable jump starter that I tried to see if it could use. It didn't work, perhaps because its meant to be a jump starter not a battery maintainer. I think they have other models that will work, but apparently the Boost is not meant to maintain a constant supply.
    3) the first time I tried the upgrade the app said my battery was too low (11.8). I ended up disconnecting my amp/sub and that allowed the upgrade to continue.
    overall I am very pleased with the upgrade. a lot of the "dead spots" in the gas pedal seem to be eliminated and less overall gear hunting. In the short trip I took after the upgrade the computer is reporting slightly decreased gas mileage -- I am fine with this and it would make sense as the new code seems to keep the rpms slight higher.
    tonered[OP] and ktbell444 like this.
  12. Jan 9, 2021 at 1:09 PM
    #4012
    ctu5000
    ctu5000 Member
    2015 Tacoma DCSB TRD Sport 4x4
    Hi... Does T-SB-0092-20 (or any other) address the driveability/trans shifting issues on the 2017 Tacomas with automatic trans?
    I have a 2017 4x4 DCLB Sport that I've had since new. I like the truck quite a bit, but the transmission shifting issues have driven me crazy since day one, to the point I'm about ready to throw in the towel and get rid of the thing.
    There was an earlier TSB (sorry, don't remember the number) that the dealer applied, but it made zero difference.
    Any help would be much appreciated. Thanks!
    (I didn't read all 200+ pages of the thread, but I did read quite a bit of it... including several searches of the thread... but couldn't seem to find a straight-forward answer.)
  13. Jan 9, 2021 at 1:47 PM
    #4013
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    No, that T-SB does not cover you. All you need to know is on the first page. It addresses the T-SB you're looking for.
  14. Jan 9, 2021 at 4:39 PM
    #4014
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    0092-20 is JUST FOR THE 19 AND 20'Ss. that will not apply to your 17. you will have to find the tsb for your specific current ecu. it is easier to read the ecu with an obd2 reader, techstream, or the ov tune software, get your current ecu number, then look to see if you need a new update for your current ecu calibration, or not.
    hope that helps some.
    Ski
  15. Jan 9, 2021 at 5:02 PM
    #4015
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    If you have a tactrix cable you can hook to your truck with a laptop and update by double clicking the cuw file associated with your truck on post number 1 of this thread. Simple, just follow on screen instructions tells ya step by step.
  16. Jan 9, 2021 at 5:33 PM
    #4016
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    I too have the 2017 . I had mine vftuned /ovtuned to 2.0 . I loved it. Someone can do it for you for a small fee . You don’t have to but anything.
  17. Jan 9, 2021 at 9:40 PM
    #4017
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    Thanks @tonered! Just flashed 04B81 to my truck today
  18. Jan 9, 2021 at 9:41 PM
    #4018
    tonered
    tony
    Lynnwood, WA
    You're welcome!
  19. Jan 10, 2021 at 12:45 PM
    #4019
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Loaded TS on to my laptop per instructions but when connecting to vehicle I get a pop up window stating "Critical Update: This version of software became obsolete August 15th 2019. You MUST update to the newest version...please download latest version from TIS" when I click on the button "Update Now" within the window I'm directed to the TIS website but can't log in without name and password.
    Maybe I missed something but I can't get TS to connect to my vehicle without getting this pop up window every time. Appreciate any help.
  20. Jan 10, 2021 at 12:46 PM
    #4020
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Close TS, disconnect from the internet, and try again. You will get a warning and something about 30 uses left. It will work fine. Once in a while you may have to connect to the internet, let it check for an update (and fail), then disconnect from the internet again.
    PNWTacoma and tonered[OP] like this.
Thread Status:
