ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Jan 10, 2021 at 12:59 PM
    #4021
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Thanks for quick reply. Appreciate your help
  2. Jan 14, 2021 at 6:54 PM
    #4022
    StraightHardCore
    StraightHardCore Active Member
    Down in da southeast
    What are the risks of doing a TSB without a battery maintainer???
    Can I just hook my truck up to a running car with jumpers??
  3. Jan 14, 2021 at 7:14 PM
    #4023
    304_Taco
    304_Taco Well-Known Member
    Curtis
    Morgantown, WV
    16 TRD Sport DCSB MT
    Techstream won't let you flash the ecu if the voltage is too low. I flashed without a maintainer and didn't have a problem. YMMV though
    tonered[OP] and crbr like this.
  4. Jan 14, 2021 at 7:15 PM
    #4024
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    I’ve never flashed with anything other than the truck shut off and everything turned off. Lights, radio, screen display, seat heaters.... everything. Flashed fine every time. Same with updating tsb and never had an issue.
    tonered[OP] and skidooboy like this.
  5. Jan 14, 2021 at 7:25 PM
    #4025
    StraightHardCore
    Thanks and cool. And TSBs are really as easy as plugging in and clicking the cuw file and following the directions? Do I got to open techstream first or just click the cuw file??
  6. Jan 14, 2021 at 7:27 PM
    #4026
    mandog
    mandog Lesser-Known Member
    Race City, USA
    2017 4WD Off-Road Quicksand Overland
    How long does it take? I imagine running the OBD/Tactrix can't be too much draw.. Still, glad @StraightHardCore asked this question. I was just wondering/asking it m'self as I seen it posted on all the guides/walk-throughs.
  7. Jan 14, 2021 at 7:33 PM
    #4027
    304_Taco
    Curtis
    Morgantown, WV
    If it's your first time connecting to the truck then I would open TS to make sure you have it all set up correctly. Then close TS and it's as simple as opening the cuw and reading instructions.
    I think mine took around 10 minutes. It feels like an eternity the first time, but that's just your nerves lol.
    tonered[OP] likes this.
  8. Jan 14, 2021 at 7:48 PM
    #4028
    beetledude
    beetledude Well-Known Member
    2020 TRD Offroad 4X4
    that's what I did too, since it was my first time. opened up tech stream, change a window setting just to make sure my tractrix cable was working as intended. once confirmed, I exited out of tech stream and launched the cuw upgrade file.
    one other thing I'll point out is that during the updating process all of the subsystems will report an error -- I got a constant stream of radar not working, ABS not working, etc, etc. of course everything was back to normal once the process was done.
  9. Jan 14, 2021 at 7:52 PM
    #4029
    newdles
    Achmed
    Took all of 6/7 minutes first time if I remember correctly. That’s only because I was cautious and read everything word for word :)
    Vbpiper and tonered[OP] like this.
  10. Jan 14, 2021 at 8:24 PM
    #4030
    Shellshock
    Iowa
    You dont need to do anything. Just make sure your battery is over 12v (it’s the first check it does) and you’ll be fine. Shut off all accessories(lights, radio, etc) when flashing. It takes about 5 minutes unless you are a super old ecu, it’ll be closer to 10.
    Vbpiper, PhogDog and tonered[OP] like this.
  11. Jan 15, 2021 at 8:14 AM
    #4031
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Have someone wanting me to tune their 2016 tacoma. Dealer just flashed the truck using TSB-0077-16
    Does this update the truck to 04b04
  12. Jan 15, 2021 at 8:17 AM
    #4032
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I think that is an obsolete TSB that might have updated him to something lower than 04B04. You'll have to look at the TSB to see.
    If you are flashing him, you can certainly do the TSB update to 04B04.
  13. Jan 15, 2021 at 8:28 AM
    #4033
    whitedlite
    USA!
    3RD Gen TRD 4WD
    I got tired of screwing around with the new drivers on techstream and just took that PC back to bestbuy.
    I can flash tunes using my work computer, but I cannot update TSB's. Something to do with me not being able to turn off some security features.
  14. Jan 15, 2021 at 8:33 AM
    #4034
    tonered
    tony
    Lynnwood, WA
    You're kind of backed into a corner there.
    Shellshock likes this.
  15. Jan 15, 2021 at 5:15 PM
    #4035
    newdles
    Achmed
    If that’s the first tsb your 2016 has seen you’ll be very impressed with the changes just at stock level.
  16. Jan 15, 2021 at 5:17 PM
    #4036
    tonered
    tony
    Lynnwood, WA
    You're welcome!
    @Shellshock also. :cheers:
    Vbpiper and Shellshock like this.
  17. Jan 15, 2021 at 6:31 PM
    #4037
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I just hang around and share little known facts in my spare time. I guess that makes me Cliff. The heavy lifting was done by the others you tagged.
    "They did a study between postal workers and chimpanzees. They proved chimps were 32 percent slower. Of course, they were better with public relations."
    tonered[OP] and Vbpiper like this.
  18. Jan 15, 2021 at 7:16 PM
    #4038
    tonered
    tony
    Lynnwood, WA
    The Tactrix is handy. I know it works on Mazdas also.
    You never know. You might end up with OVT also.
    Vbpiper likes this.
  19. Jan 15, 2021 at 7:53 PM
    #4039
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Not that I know of, but I have done limited research. It's one of the reaosons I don't own either brand aside from the wifes Fit.
    Vbpiper likes this.
  20. Jan 15, 2021 at 7:55 PM
    #4040
    ninernation
    ninernation Well-Known Member
    WA
    TRDOR
    OME, ALUCAB, RCI
    Did this address adaptive cruise control too?
Thread Status:
