ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Jan 29, 2021 at 12:29 PM
    #4121
    Shellshock
    Iowa
    You can buy it and resell it. They sell almost instantly here for $100-130
  2. Jan 29, 2021 at 1:42 PM
    #4122
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    I bought mine from a TW member for $150 shipped. I saved like $30 from buying directly from Tactrix, and I was already looking for one for a couple months. You could probably sell it for about the same.
  3. Jan 29, 2021 at 6:47 PM
    #4123
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    I was able to program a transponder key with a cheapo Amazon cable (this was long before I got my tactrix cable) and it worked just fine. Not sure I would recommend it to someone else though...
    79CHKCHK likes this.
  4. Jan 29, 2021 at 8:08 PM
    #4124
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    I used a cable purchased off Amazon to program my FOB and a Lexus Key Card. No issues at all. I've been running the Lexus key card for well over a year now.
  5. Jan 30, 2021 at 2:30 PM
    #4125
    Tacoma Mike
    Southern Maine
    Ok I’m responding with advise.
    Let Toyota do it.
    They will scan it and update to the latest trans software.
    It does help.
    slvrtaco11 likes this.
  6. Jan 30, 2021 at 2:37 PM
    #4126
    Burritoma
    Burritoma Well-Known Member
    Deep South
    2019 Quicksand SR5 V6 DCSB
    I was in for the fuel pump recall today and got mine updated at Savannah Toyota today. Not a big hassle, they just said they had to write something in the "complaint/symptom" field. I said "doesn't shift right"
    I haven't driven it too much today afterwards, but it seems MUCH better. I usually hit ECT as soon as I get in. I did not feel the need on the way home.
    Taco Gang-cement likes this.
  7. Jan 30, 2021 at 2:38 PM
    #4127
    crbr
    crbr Well-Known Member
    east TN
    18 Sport / 93 Mastercraft Prostar 190
    I have been trying to make sense of all this information, as some of it seems to contradict itself.
    OK
    Or should i say some posters contradict others.
    More chiefs than indians
    I have a 2018 OR 4X4 and I am about ready to sell it. Theres a lot to love on the thing don't get me wrong. My biggest complaint is the erratic and unpredictable shifting. I think i am at a point where i am going to try the newest toyota update because i really don't want to sell it.
    Logical and the update will make you happy.
    It seems like that is the best way to go after reading mixed reviews on the OV tunes stuff. I have no problem spending the money but just want to clarify, the only way to use techstream and update the newest toyota information into my ecu is via the tactrix cable?
    Yes, with regards to your talking point. The other way is to get a Toyota service center to flash your ecu by honoring the Technical Service Bulletin(s) T-SB-0058 or T-SB-0062. Either TSB will get you the same results. They should do it under warranty for your 2018. Had mine done in about 1.5 hours with no charge. Makes a difference in the performance characteristics that I suspect you are looking for.
    Dont feel obliged to respond if you're not 100 percent sure.
    I am 100% certain on the information.
  8. Jan 30, 2021 at 2:39 PM
    #4128
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    There are other cables like the official Toyota / Mongoose cable, but they all cost a lot more money. A genuine Tactrix ($170) is the least expensive, reliable adapter. The latest update for the 2018s was in mid-2018. There should be a TSB soon to get the 2018s on the same tune as the 2017 MT and 2019 / 2020 ATs.
    And, OVT is very much worth it.
  9. Jan 30, 2021 at 3:53 PM
    #4129
    tonered
    tony
    Lynnwood, WA
    You are most likely on 04A60 (AT) or 04A70 (MT). You can use your OBD adapter with the Carista or OBD Fusion apps to find your ECU ID.
    Like I said, the TSBs were released mid-2018 and no known Tacos were delivered with the new ECU IDs as that was around the end of the production run.
    Yes. Folks have found comms issues with the cheap cables. You need 5min to 10min of solid connection and data transfer to flash the ECU. The cheap ones are clones of the real items. They might be okay for pulling codes and customizations, but not for flashing.
  10. Jan 30, 2021 at 3:58 PM
    #4130
    Burritoma
    Deep South
    I bought one of the cheap cables to try to program a chip key. Total waste of money.
    Taco Gang-cement and tonered[OP] like this.
  11. Jan 30, 2021 at 4:03 PM
    #4131
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    The cheap cables are a crapshoot. If you don't want to flash the cable sold by dxdiag will do everything up to that point. They're a little cheaper than the Tactrix.
    As someone who has been through ask of this just get the Tactrix. I own three of the cheap cables, the dxdiag version and the Tactrix. In this case trying to save a few bucks isn't worth it.
  12. Jan 31, 2021 at 7:57 AM
    #4132
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    Does anyone use a mongoose? My tactrix has been great but looking for something a little more heavy duty. If I do get one my tactrix will be up for sale.
  13. Jan 31, 2021 at 8:03 AM
    #4133
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    I have the drewtech cable, mfc2 / green case.
  14. Jan 31, 2021 at 8:40 AM
    #4134
    Burritoma
    Deep South
    All right, got some more drive time in today. This is DEFINITELY a BIG improvement over the factory setting circa 2019. The accelerator is far more responsive. There are no "surprises" of failure to shift or unexpected shift.
    10/10, would do again.
    tonered[OP] and disk_55FL like this.
  15. Jan 31, 2021 at 8:44 AM
    #4135
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    A real mongoose should work fine. The cheap clones not so much.
    MGMSangTaco likes this.
  16. Feb 2, 2021 at 6:06 AM
    #4136
    MGMSangTaco
    Denver, CO
    Thanks boss, for sure I would never go with the cheapo. I think I may grab the mongoose even though it's pricey.
    Also if you want to add me to your list in the bottom for Denver- CO I'd appreciate it no worries if not. Finally installed your 2LO harness btw. Badass!
  17. Feb 2, 2021 at 1:30 PM
    #4137
    stonedraiders
    stonedraiders Member
    Mario
    2019 Toyota Tacoma
    none
    Finally broke bread today! I got me a genuine tactrix cable. they even gave me a military discount of 10% $176 out the door lol. I'm seeing everyone saying they're getting some good feedback from the ecu mod. might have to check that one out. ill check to see if it update or not. I doubt it. my acceleration is not that good now. so hopefully this fixes it.
    dilbert[QUOTED] and tonered[OP] like this.
  18. Feb 2, 2021 at 1:39 PM
    #4138
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    :taco:
    04B33 is fantastic. I had two other TSB ECU updates done when I had my 2016 and they were a little better than before, but I still used the ECT button all the time. With this one it's like a new truck. I even disabled my ECT anytime mod.
    Canadian Caber and tonered[OP] like this.
  19. Feb 3, 2021 at 7:01 AM
    #4139
    Army of Juan
    Army of Juan Well-Known Member
    2017 Toyota Tacoma DCLB Sport
    Tyger side steps LEER 100XR Shell Method 17 rims -12 offset 285/70/17 BFG KO2 BAYAREAFAB TACOMA GRILL BILSTEIN 5100 2.5 LIFT W/ICON AAL AVS HOOD DEFLECTOR AVS WINDOW VISORS
    Anyone here in the Columbus Georgia area that can help me with the updates? I dont want to go to the dealer. I'll gladly pay a reasonable fee. TIA
  20. Feb 3, 2021 at 7:03 AM
    #4140
    tonered
    tony
    Lynnwood, WA
    There are a few GA folks on the list:
Thread Status:
