ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Mar 3, 2021 at 6:36 PM
    #4381
    Shellshock
    Iowa
    No but it’s recommended.
    NickJacq23[QUOTED] likes this.
  2. Mar 3, 2021 at 6:45 PM
    #4382
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    anyone that tunes your truck can, with a little patience, update the ECU.
    I updated one tonight, and it took maybe 10 mins.Your results may vary.
    Haven't done it in months and last one I done gave me all kinds of fits, I figured it was bad drivers, but could not get it to work one time with a new PC i took back to bestbuy.
    C41n and threejack like this.
  3. Mar 3, 2021 at 6:47 PM
    #4383
    NickJacq23
    NickJacq23 Well-Known Member
    @whitedlite do the tsb updates come with vf tuner or do you need to have the other program listed here? & how do you figure out your ECU/Others ecu number?
  4. Mar 3, 2021 at 6:48 PM
    #4384
    whitedlite
    USA!
    3RD Gen TRD 4WD
    @Shellshock is your man and he has the best writeup to do it.
    To answer your question no, TSB's have nothing to do with OVtune. However, update your ECU before paying to unlock that ECU for tune editing.
    IDK how tech savvy you are, but may be worth some beer money to see if anyone local can help you in your regions local subforum.
  5. Mar 3, 2021 at 6:50 PM
    #4385
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    tonered[OP] likes this.
  6. Mar 4, 2021 at 9:22 AM
    #4386
    DontPanic
    DontPanic Well-Known Member
    VA
    Color me disappointed. 2020DCSB AT; 04B80 to 04B81 not much improved‍... heavens didn't part, angels didn't sing, drives just as schizophrenically as before (thankfully I'm used to it at this point).
  7. Mar 4, 2021 at 9:23 AM
    #4387
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Did you do it, or a dealer? If you did it, did you do the Learn Value Resets?
    These are the steps in TS:
    Bastek likes this.
  8. Mar 4, 2021 at 9:27 AM
    #4388
    DontPanic
    VA
    Dealer did it. Adaptions cleared twice - their conclusion is that I am driving it incorrectly:anonymous:...
    Bastek, C41n and tonered[QUOTED][OP] like this.
  9. Mar 4, 2021 at 9:29 AM
    #4389
    tonered
    tony
    Lynnwood, WA
    At least they did that step since it is not in the TSB.
    That sucks though. The weird part is that there is still inconsistencies between Tacos. Not everything can be blamed on the owner.
  10. Mar 4, 2021 at 9:35 AM
    #4390
    DontPanic
    VA
    They redid the adaption game when I went back. The appropriate update made more of a difference on my 2017 (went from the 00 to the 04 versions).
    C41n likes this.
  11. Mar 4, 2021 at 9:40 AM
    #4391
    tonered
    tony
    Lynnwood, WA
    Yes. The mid-2018 TSB made a big difference on mine as did the TSB that is similar to the one that you got.
    Oh man! The Stock 3rd Gen tunes generally suck, but 04B00 is in a league of its own.
    C41n likes this.
  12. Mar 4, 2021 at 12:42 PM
    #4392
    NickJacq23
    Does the tactrix cable need to be purchased from the site directly? Or are you able to get a similar cheaper one off Amazon?
  13. Mar 4, 2021 at 12:44 PM
    #4393
    tonered
    tony
    Lynnwood, WA
    You can either purchase the Software Bundle from vF for $349 or the License ($199) and adapter from tactrix.com ($170). You do not want to use a clone from Amazon for flashing your ECU.
  14. Mar 4, 2021 at 12:49 PM
    #4394
    NickJacq23
    @tonered okay it makes sense that the cable that comes from vF & tactrix is the same. that’s what I needed. It sounded like you needed both cables to do each separate upgrade.
    when you upgrade to the newest TSB, does it tell you what ecu you had prior & the new one after the upgrade?
  15. Mar 4, 2021 at 12:52 PM
    #4395
    tonered
    tony
    Lynnwood, WA
    Cool! Both the vF Tactrix and the Tactrix.com one will work for many things. I've used mine on our Mazda and Subaru.
    Yes. The TS Flash program will show you your current ECU ID before it starts. When it completes, it will show you the before and after. Also, it will not update if the wrong CUW is used or if there will be no update to the current version.
  16. Mar 4, 2021 at 12:57 PM
    #4396
    NickJacq23
    Dude thanks you just cleared so much up for me lol :cheers:
  17. Mar 4, 2021 at 12:58 PM
    #4397
    tonered
    tony
    Lynnwood, WA
    You're welcome!
    Happy to help.
    :hattip:
  18. Mar 4, 2021 at 6:58 PM
    #4398
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Hey guys. Thank you very much for your work on this!! Following your write-ups I successfully installed TS on my Surface, and was able to connect it to the car (via adapter I received from OVT)!
    I'll try to update my ecu from 4B03 to 4B04 maybe tomorrow (then maybe I'll get to ovt....)
  19. Mar 4, 2021 at 7:03 PM
    #4399
    tonered
    tony
    Lynnwood, WA
    You're welcome!
    I have enjoyed my Surface for updating and logging. I keep thinking about getting a mount for it, but I don't log that often.
    Enjoy the flash.
  20. Mar 4, 2021 at 7:04 PM
    #4400
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Would be a good investment, regardless
    Cloaked and tonered[QUOTED][OP] like this.
Thread Status:
