ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Mar 14, 2021 at 7:17 AM
    #4441
    Tacoma Mike
    Southern Maine
    Mmmmm.
    So I did a thing.
    Had an old computer and a older cable.
    Downloaded and installed.
    Went great.
    However it says I need a critical update to a new version of Techstream
    software.
    Did not let me connect to the cable the very first time with 32 bit drivers.
    As me being stupid I have a 64 bit system.
    Then it tells me I have 29 connections left.
    Which I see all the time cause the shop goes down for hours at a time.
    I had disconnected from the internet.
    however and this is my thinking.
    my computer reconnected to the net without me knowing it.
    So nothing has been mentioned about another update to that it won’t
    Load in this situation on config.
    so I’m thinking I screwed up the install
    And my cable won’t work cause it’s a ver. 1.4 32 I think and
    Even if I have the 64 bit drivers I found it won’t accept the drivers.
    no big deal if it doesn’t work per say but I think I may need a 2.0 cable
    Anyway.
    Which I can’t find anywhere.
    Really wanted the mongoose. Don’t care if it’s the China 40 dollar one.
    if I have to do something different that’s ok too.
    I just had that cable..
    So I’m real real good at using the equipment but doing roundy round installs not so much.
    I’m wondering If I should uninstall and do it again and make sure I never connect to the net..
    just throwing this out here.
    Oh yea windows 7 home premium.
  2. Mar 14, 2021 at 7:28 AM
    #4442
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    The info is in the 1st Post and discussed many times in this thread.
    That version of TS is out of date, which is not a problem other than the warning. WiFi off to connect. If you accidentally try to connect with WiFi on, it will reset the counter.
    Even my new version of TS wants to call home if WiFi is on.
    I cannot help you with the cable drivers. Just a thing that folks often find it hard to connect with cheap closes. If all that you are trying to do is diagnostics and Customizations, then a cheap cable might work. If you are trying to flash a TSB, get the genuine Tactrix.
    NorrinRadd likes this.
  3. Mar 14, 2021 at 7:33 AM
    #4443
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
  4. Mar 14, 2021 at 7:53 AM
    #4444
    Tacoma Mike
    Southern Maine
    Yea like I said no biggie. Now with the counter and and add such it asks for the update even disconnected. Like I said I just might wipe it out and try again or go to the shop and see what happens. You have done a amazing job on this as well as your friends and I commend you highly.
    Good day sir
    tonered[QUOTED][OP] likes this.
  5. Mar 14, 2021 at 7:55 AM
    #4445
    Shellshock
    Iowa
    Once the counter hits 0, you just run the activation steps again. It’s no biggie
  6. Mar 14, 2021 at 8:20 AM
    #4446
    daveeasa
    David
    PNW
    I’ll see if I can build a quick exe we could copy to the techstream folder which would look for the ini file, open it, parse it, check days remaining.
    If under 10 then write a backup reset to 30, save.
    Then launch the techstream exe.
    That would probably be easier/safer/better than powershell or cmd script.
    Then I’d need to build for both 32 bit and 64 bit.
    Canadian Caber and tonered[OP] like this.
  7. Mar 14, 2021 at 8:50 AM
    #4447
    tonered
    tony
    Lynnwood, WA
    Thank you!
    :hattip:
  8. Mar 14, 2021 at 9:10 AM
    #4448
    Tacoma Mike
    Southern Maine
    I know you know your shit but somewhere a while ago somehow found the script line with the counter
    Number on it and he “says” he would go in and reset it to 30.
    Now I’m just going from memory but this sticks out for some reason.
    I don’t even remember if it was proved or not
  9. Mar 14, 2021 at 9:19 AM
    #4449
    tonered
    tony
    Lynnwood, WA
    Same person, but just accidentally trying to connect while on WiFi will do that all by itself. Then, you remember to turn off WiFi and proceed.
    Tacoma Mike[QUOTED] likes this.
  10. Mar 14, 2021 at 10:12 AM
    #4450
    daveeasa
    David
    PNW
    Exactly. And something I think could be automated. But as Tony says, forgetting to turn off wifi works too. Though it might be extra slick for the exe to do that for you too (turn off wifi)
  11. Mar 14, 2021 at 10:27 AM
    #4451
    Tacoma Mike
    Southern Maine
    no why?
    Is he an asshole too? lol
    daveeasa[QUOTED] and Shellshock like this.
  12. Mar 14, 2021 at 11:09 AM
    #4452
    daveeasa
    David
    PNW
    The stream of consciousness writing. Made me think of the RD.
  13. Mar 14, 2021 at 11:18 AM
    #4453
    Tacoma Mike
    Southern Maine
    I feel so sorry for him...
    Lol
    I am awake so I think that’s a good thing..
    daveeasa[QUOTED] likes this.
  14. Mar 18, 2021 at 3:58 PM
    #4454
    u2pilotjt
    u2pilotjt Member
    2020 TRD Off Road
    Perhaps you can explain exactly what all this credit thing is about and how it works; the web site isn't totally clear and I've already run into questions at my end.
    I installed and registered vFTuner, connected to my 2020 TRD and used up 4 credits to unlock the 04B80 ID; so my VIN is unlocked on that ID. If I upgrade my ECU with the TSB to 04B81, will I have to pay 4 more credits to unlock the 04B81 ID in vFTuner? Or can I get my tune pack swapped for the 04B81 ID (I already got one for the 04B80 ID) and just flash a tune from that pack at no extra credit expense since I already unlocked my VIN in vFTuner?
    It's a bit confusing about what's tied to the 4 credits and what's not.
    JT
  15. Mar 18, 2021 at 4:16 PM
    #4455
    tonered
    tony
    Lynnwood, WA
    Hey, JT.
    You get nine credits with a vF License, as you know. You need four Credits to Unlock a VIN forever for anyone. You need four Credits to Unlock an ECU for editing tied to your Master Key. If you want to flash up to 04B81, which I highly recommend, you need to get the 04B81 Tune Pack. @OVTune will send that to you if you message him, show him the update, and are on the latest vF Version, currently 1.2.9.9.2 .
    You won't have to spend any more Credits on your VIN, but you would need to spend four Credits to Unlock 04B81, if you want to edit it. It doesn't need to be Unlocked to flash.
    Lemme know if you have any other questions.
    See the 1st post of the ECU Update thread for instructions to flash 04B81.
    C41n likes this.
  16. Mar 18, 2021 at 4:19 PM
    #4456
    u2pilotjt
    u2pilotjt Member
    2020 TRD Off Road
    Interesting. when I opened vFTune for the first time, I have 5 credits and used 4 to unlock my 04B80 ID, now I have 1. I haven't done anything but follow the video for installing the software and connecting to and registering the software to my truck for the first time.
    JT
  17. Mar 18, 2021 at 4:44 PM
    #4457
    tonered
    tony
    Lynnwood, WA
    Send a message to OVT with your order number to get the remaining Credits. A lot of folks didn't get the last four.
    C41n and u2pilotjt[QUOTED] like this.
  18. Mar 20, 2021 at 10:58 AM
    #4458
    Palanku
    Palanku Active Member
    Josue
    Puerto Rico
    2019 Tacoma Off-Road magnetic gray
    Gashole..TRD coin box..Ultimate turn light..TRD Pro grill..Black overlays emblems..Black Toyota exhaust..Hard metal tonneau cover..TRD pro shift knob..
    Tech stream when I push connect to vehicle just said need and update...i can’t pass through there
  19. Mar 20, 2021 at 11:01 AM
    #4459
    harpo1
    harpo1 Well-Known Member
    Turn your wifi off.
  20. Mar 20, 2021 at 11:03 AM
    #4460
    Tacoma Mike
    Southern Maine
    Delete the program .
    Shut off internet connection.
    Reload. Don’t try to run program connected. I did the same thing
    Palanku[QUOTED] likes this.
Thread Status:
