ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Mar 29, 2021 at 10:23 AM
    #4561
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I generally recommend unedited tunes or tune edits that you do yourself. The editing is very easy using maps that folks have already tested and posted. See the Perf and Tuning forum or what was the AT tuning thread. It has become a cesspool though like all other AT threads. :rolleyes:
  2. Mar 29, 2021 at 10:23 AM
    #4562
    Shellshock
    Iowa
    @tonered is a MT.
    I’d ask @Mooseditty17 - he made it and knows all about it. I think he just had an updated version too.
    tonered[OP] and 4x4G[QUOTED] like this.
  3. Mar 29, 2021 at 10:26 AM
    #4563
    tonered
    tony
    Lynnwood, WA
    Agreed, but I do stand by my reccy and is what I tell the folks that I flash.
  4. Mar 29, 2021 at 10:27 AM
    #4564
    Shellshock
    Iowa
    Agreed. Community tuning at your own risk. Some I’d feel more comfortable flashing than others.
    C41n and tonered[QUOTED][OP] like this.
  5. Mar 29, 2021 at 10:29 AM
    #4565
    tonered
    tony
    Lynnwood, WA
    :hattip:
  6. Mar 29, 2021 at 11:21 AM
    #4566
    PatricNV
    PatricNV Well-Known Member
    Patric
    Reno, NV
    2018 Cement TRD OR Access Cab
    OV Tune Skinny tires Trail Gear Sliders
    I have downloaded techstream and played a bit successfully connecting to vehicle. If connected to internet it locks and wants to update, do I need to run with connection off?
    How do I identify the ECU version of my truck so I can puck the correct update file?
  7. Mar 29, 2021 at 11:25 AM
    #4567
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    @4x4G
    Mild and Wild was designed to be a daily driver tune, and once you push ETC Power, the tip in is increased and shift points are raised for a much sportier than usual feel. It's a free tune, give it a run. Don't like it, flash back to whatever you were on.
    C41n likes this.
  8. Mar 29, 2021 at 11:28 AM
    #4568
    Mooseditty17
    AJ
    WI
  9. Mar 29, 2021 at 11:29 AM
    #4569
    tonered
    tony
    Lynnwood, WA
    The update work around has been posted many times and is noted in the 1st Post near the installation step by steps.
    If you hit the Engine ECU after connecting, it will tell you all kinds of data including the calibration ID.
  10. Mar 29, 2021 at 11:48 AM
    #4570
    Cloaked
    Cloaked Well-Known Member
    No internet connection.
    PatricNV[QUOTED] likes this.
  11. Mar 29, 2021 at 12:51 PM
    #4571
    PatricNV
    Patric
    Reno, NV
    Thank you. I will look for that. Btw, did not ask how to update I asked how to ID my ECU because I could not figure it out in TS. I have the instructions from 1st post.
  12. Mar 29, 2021 at 12:55 PM
    #4572
    tonered
    tony
    Lynnwood, WA
    Yes. Once you connect to vehicle, you get the list of ECUs available. Picking the Engine, it will bring up the data for that ECU. I will try to get a screenshot later.
  13. Mar 29, 2021 at 1:02 PM
    #4573
    4x4G
    4x4G Well-Known Member
    Gavin
    2019 TRD Sport, 4x4
    Motofab 3” in the front 1” in the rear 17” Fuel Vandals 285,75,17 Hercules Mud Terrains
    Hey toner, I’m running a 3” block in the front, a 1” block in the rear, 33” mud terrains, and 17” wheels (they’re heavy). Other than that I’m on stock gears and have an intake and exhaust. What do you recommend me running for the files for 04B33?
    also in the files that Mat sent me there was nothing about mild and wild (mw) or performance tunes? - not sure if they are already the performance tune (sorry for my inexperience)
  14. Mar 29, 2021 at 1:04 PM
    #4574
    tonered
    tony
    Lynnwood, WA
    At this time, I would say 04B33_Reg_35.vft . Always round up on the tire size tunes. All 2.0 Tunes are Octane Learning.
    4x4G[QUOTED] likes this.
  15. Mar 29, 2021 at 5:37 PM
    #4575
    PatricNV
    Patric
    Reno, NV
    Hi, thank you! I got to the long list of parameters for the engine ECU but do not see the ID number. Sorry to be a pain but just don’t see it. I don’t want to flash until I confirm it. Mine is 2018 and there are a couple possibilities.
  16. Mar 29, 2021 at 7:13 PM
    #4576
    tonered
    tony
    Lynnwood, WA
    You're welcome!
    I was off a bit as I usually check it in vF / OVT, but:
    -- Connect to Vehicle
    -- From the Main Menu, select Health Check
    -- Only select the Powertrain ECUs
    -- Stay in Oflline Mode
    -- See the green highlight below for my 04B14 ECU.
    C41n likes this.
  17. Mar 29, 2021 at 8:34 PM
    #4577
    PatricNV
    Patric
    Reno, NV
    Success! Thank you!! I would have never figured that out. I was way off where I was looking. Successfully updated to the latest. Wow some scary messages flash on the instrument panel during the flash!!!!
    Also, one of the first screens in the calibration wizard does show the current ID. So if I was wrong it would tell me. It also looked like it checked the file to see if it was right??
  18. Mar 29, 2021 at 8:37 PM
    #4578
    Shellshock
    Iowa
    Yup.
    it won’t let you flash the wrong file. It checks the current ecu and which ones that specific file applies to
    C41n and tonered[OP] like this.
  19. Mar 29, 2021 at 8:40 PM
    #4579
    tonered
    tony
    Lynnwood, WA
    You're welcome!
    With TS, you can typically poke around with impunity. Everything has a confirmation message, so don't fear it.
    The center stack is like that when flashing anything. Don't worry unless you see those and am not flashing.
    Yes. Tons of confirmation messages and info. Like @Shellshock said, you can only flash an applicable file. It is slightly foolproof.
  20. Mar 29, 2021 at 8:58 PM
    #4580
    4x4G
    Gavin
    2019 TRD Sport, 4x4
    @tonered do you know anything about @Mooseditty17’s ability to raise the red line? On his guide I tried it and then reset everything and tried it again but have had no luck.
Thread Status:
