ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Aug 13, 2018 at 12:41 PM
    #441
    1000101
    1000101 Well-Known Member
    Jon
    Reno, NV
    2022 TRD OR DCSB
    So excited about this! Finally a fix. This issue has drove me nuts since I bought the thing.
  2. Aug 13, 2018 at 12:43 PM
    #442
    D-Rock531
    D-Rock531 Well-Known Member
    Tucson
    2017 TRD "PRO" 6MT ACLB
    Bilstein 5100, ARB Single, 4.88 Gears, 33" on Method 305
    I made an appointment at my local dealer for next week. They seemed receptive when I described my need for service on the phone. Hopefully they do it for real when I actually go in.
    Rainman70 likes this.
  3. Aug 13, 2018 at 12:47 PM
    #443
    WizardsAndBooze
    WizardsAndBooze Well-Known Member
    Maryland
    2003 Tacoma ex-stepside
    1st gen owner here. I'm not trying to troll, but needing a software update for your transmission just boggles my mind.:bananadead:
  4. Aug 13, 2018 at 12:48 PM
    #444
    SContiVT
    SContiVT Back in a Toyota
    Central Vermont
    2010 Tundra Rk Wr/2023 WRX/2023 Ford Exp
    Engine, this is a MT thread, but yeah, unheard of until about 10-12 years ago.
    tacoguy88 and tonered[OP] like this.
  5. Aug 13, 2018 at 12:50 PM
    #445
    Zoop
    Zoop Well-Known Member
    I called and said I wanted to make an appointment for a tech to hook up Techstream and check for any updates. They said okay and made the appt. Been a bit of a PIA in the past with issues so I hope they don't spring any BS on me. Got a 7yr/75,000 ext. warranty and I'm under the 80K/96month limit on the TSB so I don't expect there to be a problem. The next trick is to get them to show me the numbers on TS and/or prove there aren't any updates (if it goes sour).
  6. Aug 13, 2018 at 12:51 PM
    #446
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Update... Just talked to me service rep and he said they would hook it up and see if it has any updates available.
    I just explained the issues in 2nd and 3rd fear and asked if they could check it out while it’s there for the clutch pedal and see if they could check on Techstream for any updates...
    He said yes. We will see!!!
    MickeyB, Rainman70, Zoop and 3 others like this.
  7. Aug 13, 2018 at 12:51 PM
    #447
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    ummm ya, it's not a software update for the trans, it's for the engine like SContiVT said, it's just that those engine updates were packaged with the AT guys update.
  8. Aug 13, 2018 at 12:52 PM
    #448
    Whitetail Assassin
    Tedric
    West Virginia
    Question... Should they give me something showing it is all up to date??? That way I know if they really did it or not.
  9. Aug 13, 2018 at 12:53 PM
    #449
    WizardsAndBooze
    Maryland
    Ahh i see
    inksin[QUOTED] likes this.
  10. Aug 13, 2018 at 12:53 PM
    #450
    BeaverNation
    BeaverNation Well-Known Member
    Yeah you should get a receipt regardless if they change anything. Mines going in on Friday with 37k miles, hoping it goes smooth.
  11. Aug 13, 2018 at 12:54 PM
    #451
    inksin
    Hawaii
    The TSB says that they are suppose to put the sticker under the hood saying that it's been updated and I believe it'll be outlines in your paperwork too
  12. Aug 13, 2018 at 12:58 PM
    #452
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    You will also see it in your vehicle history on the Owners page at Toyota.com.
  13. Aug 13, 2018 at 12:59 PM
    #453
    Whitetail Assassin
    Tedric
    West Virginia
    Now one more question... Since the correct TSB still hasn’t been posted will they base the update off the model number?
    tonered[OP] likes this.
  14. Aug 13, 2018 at 1:00 PM
    #454
    tonered
    tony
    Lynnwood, WA
    Like it says in the TSB, they'll write the new calibration number (04B13) on the work order, vehicle history, and the emissions sticker under the hood.
    The AT TSB might get referenced on the work order.
  15. Aug 13, 2018 at 1:03 PM
    #455
    Whitetail Assassin
    Tedric
    West Virginia
    I will def keep you posted about how it goes. I’m getting pumped! If they don’t do it for some reason I’m still gonna get it done one way or another.
  16. Aug 13, 2018 at 1:04 PM
    #456
    tonered
    tony
    Lynnwood, WA
    I am honestly excited for all the folks that are getting this done.
    Same here, if it doesn't happen when I go in for the 10k service, I will be getting real familiar with TS.
    02Duck, shakerhood, inksin and 2 others like this.
  17. Aug 13, 2018 at 1:10 PM
    #457
    inksin
    Hawaii
    It really is easy to do yourself if you have the cable and Techstream. Seems foolproof. I tried installing different versions of it on my truck and only the version that specifically applied to my ECU would allow me to continue, all the other versions (MT versions and '18 versions) told me that my ECU wasn't eligible.
  18. Aug 13, 2018 at 1:11 PM
    #458
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    I'll be doing the same, and if I have the same problems, it seems like there's quite a few WA/Seattle manuals in here, maybe we can have a party.
    I'm in Port Townsend but tend to float over to Seattle here and there.
    tonered[QUOTED][OP] likes this.
  19. Aug 13, 2018 at 1:12 PM
    #459
    Zoop
    Earlier in the thread someone stated it should ping techstream as an ECU update for the manual, regardless where the file is burried. I hope to see that happen.
  20. Aug 13, 2018 at 1:13 PM
    #460
    tonered
    tony
    Lynnwood, WA
    I'm with you. It doesn't seem any more difficult than doing a FW upgrade on a smart phone. I just haven't invested in a Tactrix or similar cable. I just have a four or five year old bluetooth OBD tool. It works great for Carista and Torque, but . . .
Thread Status:
