ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Apr 2, 2021 at 11:45 AM
    #4641
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Yes. Sometimes they are fast. I waited a day or so.
  2. Apr 2, 2021 at 11:55 AM
    #4642
    Shellshock
    Iowa
    Or just use TSv14 and you can use it immediately :notsure:
    C41n likes this.
  3. Apr 2, 2021 at 11:57 AM
    #4643
    NickJacq23
    NickJacq23 Well-Known Member
    I tried using v14 yesterday but got a message saying it needed to be upgraded
  4. Apr 2, 2021 at 11:58 AM
    #4644
    Shellshock
    Iowa
    Disconnect from WiFi
    C41n and tonered[OP] like this.
  5. Apr 2, 2021 at 12:02 PM
    #4645
    NickJacq23
    @Shellshock If I’ve already downloaded the v15 will that still work?
    or will I need to uninstall, download v14 again & go through the process without WiFi while flashing the tsb?
    also, if I uninstall v15 & redownload it, will I have a new system ID that will need a registration key from mhh auto? I only ask cause I don’t want to wait double the time for that key
  6. Apr 2, 2021 at 12:05 PM
    #4646
    Shellshock
    Iowa
    I dunno that you can run them in parallel, I’ve never tried.
    I’ve been using v14 for a long time, it’s easy and quick. Just stay disconnected from the internet.
  7. Apr 2, 2021 at 12:06 PM
    #4647
    NickJacq23
    so if I uninstall v15 & install v14 then run it without WiFi I should be able to do my TSB is what you’re telling me
  8. Apr 2, 2021 at 12:07 PM
    #4648
    Shellshock
    Iowa
    Correct
  9. Apr 2, 2021 at 12:07 PM
    #4649
    tonered
    tony
    Lynnwood, WA
    TS updates the existing installation when installing a newer version. It does not appear to allow two different installations. I don't know what it would do trying to install an older version, but most likely, stop or force an uninstall.
    Also, I updated the 1st Post to copy the WiFi workaround to be both inside and outside the Step-by-Step spoiler.
    C41n likes this.
  10. Apr 2, 2021 at 12:17 PM
    #4650
    NickJacq23
    @Shellshock @tonered
    It's interesting that you don't need wifi for that, you would assume that you'd need to be connected to some form of network you know?
  11. Apr 2, 2021 at 12:18 PM
    #4651
    tonered
    tony
    Lynnwood, WA
    Nope. This is all offline work, always. You have all the files that you need.
    Going online requires a TIS subscription. That is an option that folks can do, but it costs money.
  12. Apr 2, 2021 at 12:19 PM
    #4652
    Shellshock
    Iowa
    Sure don’t. If you are connected to network, it’ll check for updates (which we dont need / want). We have all the TSB files, TS can only grab them if you have an active subscription (which we dont). Outside of that, theres nothing it needs network for. It also doesn’t need java.
  13. Apr 2, 2021 at 12:19 PM
    #4653
    Shellshock
    Iowa
    And @tonered beats me again. I should learn to type faster.
    ktbell444 and tonered[OP] like this.
  14. Apr 2, 2021 at 12:21 PM
    #4654
    tonered
    tony
    Lynnwood, WA
    It is just the red dot that I see. :D
  15. Apr 2, 2021 at 12:22 PM
    #4655
    NickJacq23
    So untill 2021's have TSB's there shouldn't be a need to update TS correct? because i saw that it won't work for them?
  16. Apr 2, 2021 at 12:23 PM
    #4656
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Or if you want to customize some settings on a 2021+ MY. There are also other uses that are less frequently used as well.
    tonered[OP] likes this.
  17. Apr 2, 2021 at 12:25 PM
    #4657
    tonered
    tony
    Lynnwood, WA
    TS V15 that I linked certainly works for 2021s. TS V14 does not.
    C41n likes this.
  18. Apr 2, 2021 at 1:13 PM
    #4658
    NickJacq23
    Well gents, I'm updated & tuned. Thanks for the help!
    Shellshock likes this.
  19. Apr 2, 2021 at 1:20 PM
    #4659
    tonered
    tony
    Lynnwood, WA
    You're welcome!
    :cheers:
  20. Apr 2, 2021 at 2:15 PM
    #4660
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    I was curious what this costs. $1295 a year it looks like
    https://techinfo.snapon.com/TIS/register.aspx
Thread Status:
