ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Aug 26, 2021 at 2:43 PM
    #5041
    xrider472
    xrider472 Active Member
    Arkansas
    2021 TRD OR AT
    Stock
    Well, dang. Yeah, I didn't like the MHH route, so I just purchased a 2 day license with TIS and flashed it that way. I guess I wasted about $65. Oh well, I spent quite a bit of time in the service manual section of the TIS website & downloaded a few things. Not a total loss. Lol, live & learn. Thanks Tony.
  2. Aug 26, 2021 at 2:46 PM
    #5042
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    Yeah. There a lot of goodness on the TIS site.
    That is really strange that the version you installed from there would not connect to your Taco though. At this point, if it is still installed, you should be able to launch the CUW file.
    I did a similar thing with Carista before going down the TS route. I didn't cancel the trial period in time, so I was roped into a $40 subscription for the year. Still, being able to do all the customizations with messing with the dealer was worth it. Helped a couple other folks out with it also.
  3. Aug 26, 2021 at 2:54 PM
    #5043
    xrider472
    Arkansas
    2021 TRD OR AT
    Stock
    The v16.10.017 that I downloaded from TIS worked fine. That version is how I flashed to 04C21 per your recommendations in preparation for the vF tuner software & tune pack. I never tried just double clicking the CUW file after I installed v14. If I get a chance, I'll reinstall it & try it that way just to confirm & report back, but I'm sure you are correct.
  4. Aug 26, 2021 at 2:58 PM
    #5044
    tonered
    tony
    Lynnwood, WA
    I see.
    Sounds good. Lemme know how it goes and reach out with any other questions.
  5. Aug 26, 2021 at 3:02 PM
    #5045
    xrider472
    Arkansas
    2021 TRD OR AT
    Stock
    Will do. :thumbsup:
    tonered[QUOTED][OP] likes this.
  6. Aug 26, 2021 at 10:00 PM
    #5046
    Barrister
    Barrister Well-Known Member
    Dennis
    Mesa, Arizona
    2023 TRD Pro, Solar Octane, 6 speed Manual
    Predator Steps, OEM Tonneau
    Should the spoiler be updated to reflect what has to be done in the search on mmh auto? It says to look for the V15 thread. I would assume the process is the same for V16 and one would have to specify that in the search, correct?
  7. Aug 26, 2021 at 10:14 PM
    #5047
    tonered
    tony
    Lynnwood, WA
    Thanks!
    Good catch. I missed that.
    :cheers:
  8. Aug 27, 2021 at 1:21 PM
    #5048
    xrider472
    Arkansas
    2021 TRD OR AT
    Stock
    Okay sir, you are correct!! I reinstalled v14 and the Calibration Update Wizard does in fact work on the 2021 just as you stated. The key is to just double click the CUW file and that opens the Calibration Update Wizard only, not Techstream itself. That's where I got confused before. I thought I needed a 2021 compatible version of TS to use the Calibration Update Wizard. Also, for the CUW utility to work, it has to have an activated version of TS. Wish it was just a standalone utility. Oh well, now I know. Thanks Tony.
  9. Aug 27, 2021 at 1:23 PM
    #5049
    tonered
    tony
    Lynnwood, WA
    You're welcome!
    I'm glad that it is working as expected. Saves a lot of editing. :D
    You should be all set for the next update if one happens.
    :cheers:
  10. Aug 27, 2021 at 1:28 PM
    #5050
    xrider472
    Arkansas
    2021 TRD OR AT
    Stock
    Yes sir :thumbsup:
  11. Aug 31, 2021 at 7:18 PM
    #5051
    gregnauman
    gregnauman Well-Known Member
    Greg
    2020 Tacoma TRD Pro
    None
    Tonred
    I am assuming the OBD2 dongle that comes with VF Tuner software will work for using the tech stream?
    First page it recommends Tactrix
  12. Aug 31, 2021 at 7:26 PM
    #5052
    Shellshock
    Iowa
    Yes. Same thing
    shakerhood likes this.
  13. Aug 31, 2021 at 7:30 PM
    #5053
    gregnauman
    Greg
    2020 Tacoma TRD Pro
    None
    Thanks just checking cause my plan is to do KDMax in the future so might as well go that route.
    Besides the TSB update I need to program a new keyfob using tech stream. I lost one. Dealer wants $150 to program :eek:
  14. Aug 31, 2021 at 10:05 PM
    #5054
    JJD92
    JJD92 Well-Known Member
    JORGE
    Springfield, MA
    2020 TRD OR DCSB
    If you plan to do a KDMax, or anything related to VF Tuner, I would buy adapter from them. The stand-alone software is no longer available.
  15. Sep 1, 2021 at 12:05 AM
    #5055
    Barrister
    Dennis
    Mesa, Arizona
    Is the KDMAX adapter a Tactrix?
  16. Sep 1, 2021 at 4:35 AM
    #5056
    AbnMP13
    AbnMP13 Well-Known Member
    Shelby
    2020 TRD Crew Long Bed
    Yes sir.
  17. Sep 1, 2021 at 5:25 AM
    #5057
    tonered
    tony
    Lynnwood, WA
    That is not true. If folks have a Tactrix already, they just need to contact vF Tuner before purchasing to get the software only.
    The choice was pulled because folks couldn't understand the difference.
    304_Taco and Shellshock like this.
  18. Sep 1, 2021 at 5:38 AM
    #5058
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    KD doesn't use a different or non-Tactrix adapter. And if they did, they'd be risking bricking the ECU if it even let them flash.
    Furthermore, the tune is separate from the hardware. All VFTuner software users use tactrix. Flashing a KDMax file does not make the OBD2 plug/device their adapter.
    *I am educating, not talking down to you.
    PapaRee and tonered[OP] like this.
  19. Sep 1, 2021 at 5:39 AM
    #5059
    mZiggy
    mZiggy Honey badger
    Marc
    Couldn't read and comprehend the different product list descriptions**
  20. Sep 1, 2021 at 6:45 AM
    #5060
    tonered
    tony
    Lynnwood, WA
    Sadly.
Thread Status:
