ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Sep 29, 2021 at 9:15 PM
    #5101
    mavrick6382
    mavrick6382 Well-Known Member
    2017 Tacoma SR5, DCLB, MGM
    Icon ext. travel coilovers Icon 2.0 VS rear reservoir shocks Deaver Expo leaf springs Total Chaos Upper Control Arms P285/75R17 Toyo Open Country ATII Method NV A.R.E. Z-Series Front Runner Slimline II WeatherTech floor mats Clazzio leather seat covers De-badged
    @tonered - Nope, can't find cuw.exe anywhere. Do I need to remove TS and re-install?
  2. Sep 30, 2021 at 1:59 AM
    #5102
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    AV may have removed it? I don't think you managed to delete it, so my next thought would be AV.
    Shellshock likes this.
  3. Sep 30, 2021 at 5:24 AM
    #5103
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I think so. There's no way to get it otherwise.
  4. Sep 30, 2021 at 7:38 AM
    #5104
    mavrick6382
    @tonered @ktbell444 - Hey all. When you say "AV may have removed it" what does that mean? What would you guys suggest I do as a next step? I know for sure I downloaded TS correctly, although I did install/uninstall/reinstall a few times (I don't remember why) before getting to where I am now. I wonder if that is the reason that CUW.exe is missing? Bottom line, I have what seems to be a working TS and my activation key is live (Ver 16.20.023, 4991d 00h 31m until subscription expiration).
    And if I uninstall and re-install TS, can I re-use my activation key or will I need to get a new one?
  5. Sep 30, 2021 at 7:41 AM
    #5105
    tonered
    tony
    Lynnwood, WA
    I have had no antivirus issues with TS. For V14, we had to completely shut down all protection due to the key generator file. No issues afterward.
    In your case, it wouldn't hurt to create an exception for the TS installation folder and try again.
  6. Sep 30, 2021 at 7:56 AM
    #5106
    mavrick6382
    Ok so the antivirus software may have prevented it from loading?
    So I need to:
    - Uninstall TS
    - Reinstall TS
    - Create an AV exception for the TS installation folder (will I be prompted to do that during install?)
    - Use same activation key
    Is that correct? I use Avast Free AV and need to update it to Avast One Essential anyway. Would it make sense to remove the current AV, download TS and confirm that CUW.exe is there, then install the new AV?
  7. Sep 30, 2021 at 7:59 AM
    #5107
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    What I did was completely shut down the anti-virus program while I used techstream- it was constantly fucking with it for me
  8. Sep 30, 2021 at 7:59 AM
    #5108
    MIDTNTACO
    MIDTNTACO Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
    Reboot (restart computer)
    Completely uninstall
    Remove all files and folders prior installs may have created
    Reboot again
    Disable AV completely (should be an option to suspend or disable temporarily)
    Re-install
    I don't have TS so can't answer the activation question.
  9. Sep 30, 2021 at 8:01 AM
    #5109
    tonered
    tony
    Lynnwood, WA
    Create the exception now. The software ID is likely to change so you will most likely need a new activation key.
    From my perspective, Windows Defender / Windows Security is the best a/v program. It's free, already installed, and appears to do its job unobtrusively.
    NorrinRadd likes this.
  10. Sep 30, 2021 at 8:08 AM
    #5110
    mavrick6382
    @tonered - How do I create an exception? I am in Avast and in Settings there is an option to "Add Exception." It then asks for a file path/folder path/URL. Do I use the following?
    I can also add an Advanced Exception which looks to allow me to browse to that exact location.
  11. Sep 30, 2021 at 8:08 AM
    #5111
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    This to me seems that he's not looking at the .cuw file in the location it was downloaded to. He needs to go to his download folder and right click on a .cuw to see it's associations are set correctly as you initially stated.
  12. Sep 30, 2021 at 8:09 AM
    #5112
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    The exception should be C:\Program Files (x86)\Toyota Diagnostics\
    You want that entire folder to be ignored
  13. Sep 30, 2021 at 8:12 AM
    #5113
    tonered
    tony
    Lynnwood, WA
    Yes. You're creating an exception for that folder. While your there, create one for the vFTuner folder also.
    Edit: Oops! What @Saeros said. Create an exception for the whole installation folder, not just the CUW folder.
  14. Sep 30, 2021 at 8:13 AM
    #5114
    tonered
    tony
    Lynnwood, WA
    There is no CUW.exe in his installation folder to point to. The a/v may have chewed it up.
  15. Sep 30, 2021 at 8:21 AM
    #5115
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    I'm just curious... What if they went to his download folder, would it not be there? We're all assuming they downloaded it to the .dll folder for the actual calibration updater.
  16. Sep 30, 2021 at 8:23 AM
    #5116
    mavrick6382
    OK so here's what I've done:
    1. Removed Avast AV
    2. Gone into Windows Security and added exceptions for the following folders:
    - vF Tuner
    - vF Tuner Pro
    - Toyota Diagnostics
    Next up:
    - Uninstall TS?
    - Re-install TS?
    - Go to the Calibration Update Wizard folder and verify that "CUW.exe" in in there?
    - Obtain new Activation Key & apply to new software?
    Look right?
  17. Sep 30, 2021 at 8:27 AM
    #5117
    tonered
    tony
    Lynnwood, WA
    The CUW was on his desktop and he was launching it as an executable. The file association was set to PDF for some reason. When he check the TS installation folders, the CUW.exe Update Wizard program was missing. The actual program, not the 04B04.cuw file.
  18. Sep 30, 2021 at 8:28 AM
    #5118
    tonered
    tony
    Lynnwood, WA
    The CUW.exe will not magically appear. You have to reinstall TS.
  19. Sep 30, 2021 at 8:48 AM
    #5119
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    Oooooooh!!!! I gotchu! Carry on :)
  20. Sep 30, 2021 at 8:51 AM
    #5120
    tonered
    tony
    Lynnwood, WA
    :D
    :hattip:
Thread Status:
