ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Jan 22, 2022 at 2:02 PM
    #5261
    Shellshock
    Iowa
    I didn’t even know there was a cable check lol
    a tactrix cable should work just fine with techstream. That’s what most of us use
  2. Jan 22, 2022 at 2:11 PM
    #5262
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I have no idea. Getting a connection to the vehicle has always been enough for me.
  3. Jan 22, 2022 at 2:58 PM
    #5263
    mrengineerical
    mrengineerical Well-Known Member
    Baltimore, MD
    2019 Tacoma TRD Sport DCSB
    I just wanted to see if anyone else had this result. Don't want to cause an issue down the line with ECU updates bricking the truck.
  4. Jan 22, 2022 at 3:13 PM
    #5264
    Shellshock
    Iowa
    Mine shows the same. I wouldn’t worry about it. Probably just something funky with ts
  5. Jan 22, 2022 at 3:18 PM
    #5265
    mrengineerical
    Baltimore, MD
    Thanks for checking! I appreciate it!
  6. Feb 5, 2022 at 7:42 AM
    #5266
    jardoo
    jardoo Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
    How do you know if your truck needs an ecu update? I haven’t taken mine to the dealer since 2018.
  7. Feb 5, 2022 at 9:25 AM
    #5267
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    Do you know your current ECU ID?
    Figure that out then look at the first post of this thread.
  8. Feb 5, 2022 at 9:59 AM
    #5268
    jardoo
    Beirut, Lebanon
    thanks! How do I figure that out?
  9. Feb 5, 2022 at 10:14 AM
    #5269
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    If you don't have VFTuner, *most* obd code readers can identify ECU info
    Murd3rd and jardoo[QUOTED] like this.
  10. Feb 6, 2022 at 2:07 PM
    #5270
    BlastphemE30
    BlastphemE30 New Member
    Joseph
    17' TRD pro
    may be a sillly question, but does anyone know if i can use my VCDS cable from ross-tech?
  11. Feb 6, 2022 at 2:32 PM
    #5271
    Shellshock
    Iowa
    No idea. You can install ts and see if it shows up in the vim select section.
  12. Feb 22, 2022 at 10:32 AM
    #5272
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    How do you program the extra key fobs? I see you can add a key fob, but there are some data parameters?!? Dunno.
    Greg.Brakes.Tacos likes this.
  13. Feb 22, 2022 at 10:36 AM
    #5273
    tonered
    tony
    Lynnwood, WA
    Here are a couple videos that I used:
    Credit @daveeasa .
  14. Feb 22, 2022 at 10:38 AM
    #5274
    virginiamarine
    Northern Virginia
    Thanks Brother!!!
    tonered[QUOTED][OP] likes this.
  15. Feb 22, 2022 at 10:47 AM
    #5275
    tonered
    tony
    Lynnwood, WA
    You're welcome!
  16. Feb 22, 2022 at 11:12 AM
    #5276
    virginiamarine
    Northern Virginia
    Go figure....I go through all this and find out that the "brand new" lexus key card has already been registered. That sucks.
  17. Feb 22, 2022 at 11:16 AM
    #5277
    tonered
    tony
    Lynnwood, WA
    Is that a problem? When I got the @MESO FlipFob, a group of us got old, used H-keys with the transponder and remote. We installed those guts in the new FlipFobs and successfully programmed them.
    TS should be used offline regardless. So, how would the program have known if your new key was previously registered? Just curious and don't have any other input here as I don't have PTS.
  18. Feb 22, 2022 at 11:18 AM
    #5278
    Shellshock
    Iowa
    Even if it has been registered, you should be able to clear / reset
  19. Feb 22, 2022 at 11:19 AM
    #5279
    virginiamarine
    Northern Virginia
    Wait.....you're doing this off line? let me try that again.
  20. Feb 22, 2022 at 11:24 AM
    #5280
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I think you need some sort of token to register a previously registered key for the PTS trucks. There are also some places that you can mail it to that will make it an unused key again and send it back
Thread Status:
