ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. May 5, 2022 at 5:23 PM
    #5421
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    That's how it is done.
    :cheers:
  2. May 5, 2022 at 5:28 PM
    #5422
    MPL Ops
    MPL Ops Active Member
    2018 Tacoma
    Hell yeah :playball:
    tonered[OP] likes this.
  3. May 5, 2022 at 6:33 PM
    #5423
    JMS1
    JMS1 Well-Known Member
    2021 TRD OR Tacoma, KDMAX tuned
    2021 Tacoma TRD OR, KDMAX-Pro with Kreg's custom shifting, 3” lift, SPC upper control arms, Victory 4x4 Blitz aluminum winch bumper, Warn Zeon 10S
    When I update the ECU to 04c21 does that also take care of T-SB-0045-21 at the same time or is this require a separate update. Once the update process is started how long should that take. Thank You
  4. May 5, 2022 at 6:38 PM
    #5424
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Yes, that update will satisfy everything the TSB would do. Most TSB's for updates are just that, symptoms and the resolution (update). There are a few tundra updates that also changed a fuel pump as well, but I have not seen it with the 3G Tacoma.
  5. May 5, 2022 at 6:43 PM
    #5425
    JMS1
    Can VFtuner be used for the ECU update or does it require Tech Stream? I have VFtuner that i used to upload previous tunes. Thank You
  6. May 5, 2022 at 6:44 PM
    #5426
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Currently you have to use Techstream. But it's in the works to do it from within vF.
  7. May 5, 2022 at 6:47 PM
    #5427
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Did this get resolved?
  8. May 6, 2022 at 4:29 AM
    #5428
    red_tacoma_pro
    red_tacoma_pro New Member
    nope still waiting for vftuner to reply as i have sent an email to ask if it can be done and if possbile to get the software without the cable as i have Tactrix
  9. May 6, 2022 at 4:53 AM
    #5429
    MPL Ops
    2018 Tacoma
    Ah the waiting…and waiting :bored:
  10. May 6, 2022 at 5:10 AM
    #5430
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    Where are you located? Maybe there is someone nearby with VF that can come try a Gen2 Force Flash. If it doesn’t work your back to buying a $1200 ECU.
  11. May 6, 2022 at 5:17 AM
    #5431
    Shellshock
    Iowa
    It can be recovered. Someone with vF software may be able to. Otherwise it’s possible to bench flash
    @lapoltba has recovered quite a few
    tonered[OP] and mZiggy like this.
  12. May 6, 2022 at 5:23 AM
    #5432
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    Agree, I know there are a dozen or more of us with bench flash harnesses around the country. Depending on the urgency and his location it may be able to be recovered quickly.
  13. May 7, 2022 at 12:48 AM
    #5433
    red_tacoma_pro
    thanks all for trying to help but the car is in Dubai UAE as here no one knows what is a VFtune for that i want to know if i can get VFtune without the cable the software and credit as i have tactrix and used it for techstream.
  14. May 7, 2022 at 6:50 AM
    #5434
    trdquoc
    trdquoc Well-Known Member
    "Q"
    2020 Cement DCLB TRD-Offroad
    Unfortunately you have to buy the vFTuner Software and their own serialized Tactrix to use with your software license.
  15. May 7, 2022 at 7:00 AM
    #5435
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    Yep, if you have the clear/grey Tactrix it won’t work with VF Tuner 1.6+, you’ll need to purchase the kit from VF for ~$390. However, that’s cheaper than a replacement ECU for ~$1200.
    Do you know why your cuw failed? Did your voltage drop below 11.8? We’re you using a battery tender/power supply to maintain voltage during the cuw?
  16. May 7, 2022 at 7:16 AM
    #5436
    GrandMasterB
    GrandMasterB Well-Known Member
    2020 Tacoma TRD Sport
    Supercharged, 2" Lift, 33" tires.
    I couldn't get it to update, I kept getting an error. Looked like it was going to but failed. Couple questions, I was just using the CWU wizard i downloaded here. The error on the truck said break overide error, Tracktion control light and lsd lighis were on after it failed. The wizard kept saying to turn truck off for 10 seconds and turn back on and start the flash. I followed the directions but still failed.
    Should wifi be on during the flash? I tried both ways to be honest. Not sure what else to try.
    Think its because i have a maggy tune on it already?
  17. May 7, 2022 at 7:19 AM
    #5437
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Yes. EROM tunes like the Maggy and YotaWerx supercharger tunes change the ecu ID prefix from 89963- to V9663-, requiring you to first flash a non-erom tune to return it to a 89663- prefix, and then update via TS
  18. May 7, 2022 at 7:22 AM
    #5438
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    You’ll need to use VF to flash your truck to a stock calibration that aligns with your current Maggy tune. If you’re 2020, could be 04B80 or B81, I’m assuming you’re trying to go to B82. So load the B80 or B81 (which ever matches your current Maggy tune) with VF Tuner. Then run the cuw to get you to B82, then load the B82 Maggy tune with VF.
    make sense?
  19. May 7, 2022 at 7:34 AM
    #5439
    GrandMasterB
    Makes perfect sense now! Thank you!
    I read the stock tune is in VF tune files somewhere correct.
  20. May 7, 2022 at 7:38 AM
    #5440
    mZiggy
    mZiggy Honey badger
    Marc
    correct; navigate to whatever drive you installed VF on (C-drive, unless you have more than one available to you) and go to Program Files x86 and VFTuner and within that directory you can find all the stock tune files for all the vehicles supported by VFTuner
Thread Status:
