ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Jun 21, 2022 at 8:57 AM
    #5541
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Thank you Buddy, I will look further in to this bootcamp. I just purchased a ATEQ VT31 because I run summer/winter tire setups and for some reason the id's from my summer tires didn't stay with the truck. (both summer/winter tire TPMS"s are aftermarket)
  2. Jun 21, 2022 at 9:02 AM
    #5542
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    @Shellshock is the Bootcamp guru, but I think it is part of the Mac OS?
    I have seen posts about a/m sensors not working at times. Not sure if it is a specific type or just some FW that the Taco ECU doesn't like.
    smugly likes this.
  3. Jun 21, 2022 at 9:03 AM
    #5543
    Shellshock
    Iowa
    Yup. Works just fine. Does require an intel Mac
    https://support.apple.com/boot-camp
    smugly and tonered[QUOTED][OP] like this.
  4. Jun 21, 2022 at 11:00 AM
    #5544
    smugly
    Doug
    Sweet! thanks for the help. If I run into anything in my journey,
    I'll be sure to holler for you :):D
    Shellshock[QUOTED] likes this.
  5. Jun 21, 2022 at 11:11 AM
    #5545
    Shellshock
    Iowa
    :thumbsup:
  6. Jun 21, 2022 at 1:00 PM
    #5546
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    For what it's worth, I would recommend NOT doing the Learned Value Resets. I did that when going through the process of flashing KDMax Pro. First 50 miles totally sucked, and it took a good 1000 to 2000 miles for it to finally feel dialed in. Afterward I found out the KDMax guys don't do LVR anymore, basically for that reason. I'm a newb at this stuff, so take my advice with a grain of salt, but just letting you know what I experienced.
    ChilliTaco likes this.
  7. Jun 21, 2022 at 1:31 PM
    #5547
    tonered
    tony
    Lynnwood, WA
    Sorry, but I will have to heartily disagree there. LV Resets have proven crucial in my experience for both getting a tune to adapt and to have a consistent feel when developing / testing tunes. That said, the weirdest that the Resets have ever felt has been for less than 3mi. The folks that I flash note similar weirdness. Nothing as extreme as you noted.
    Beyond that, the first first vF Tune that I tried didn't adapt well at all (1.05 SFOB). I drove around on Base for a while, then thought that I'd try the Resets. It made it a completely different tune. From there, the Resets became part of the process.
    In the end, I will continue to recommend doing the Resets, but doing what is noted is always optional. That is why the :thumbsup: and :anonymous: list exists in the 1st Post.
    C41n, ChilliTaco and ktbell444 like this.
  8. Jun 21, 2022 at 1:36 PM
    #5548
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I do it almost every time. I've seen high transmission temps after a flash that were resolved from doing a reset. If it weren't being monitored, who knows what would have happened?
    But I also do it to not cause anything weird to happen. Let's say there's a table with values ranging from 0 to 10, and a learned value that interacts with that map and adds up to an additional 3. If the learned value was previously a 3 and the table had a set value of 4, that keeps you within the allowable range (4 + 3 < 10).
    Now let's say you flash a new tune which has a value of 9 in that table. You keep that learned value of 3 by not resetting and now you're outside of the 0 to 10 range (9 + 3 !< 10).
    This is theoretical of course, as I have not read the ECU code to confirm how it functions, but it makes sense when things aren't working as intended.
    Shellshock and tonered[OP] like this.
  9. Jun 21, 2022 at 1:39 PM
    #5549
    Mojo Jojo
    Mark
    Harpers Ferry, WV
    I suspected it wouldn't be as simple as I thought lol
  10. Jun 21, 2022 at 1:41 PM
    #5550
    tonered
    tony
    Lynnwood, WA
    There is nothing simple about the 3rd Gen ECU. vF Tuner posted a flow chart for one small part of the tune once. We all: :boom: .
    ktbell444 likes this.
  11. Jun 21, 2022 at 1:42 PM
    #5551
    Mojo Jojo
    Mark
    Harpers Ferry, WV
    Point well taken. After reading yours and Karl's responses, I'm glad I went through the trouble of relearning if for anything to avoid any potential issues. Appreciate the insight.
  12. Jun 21, 2022 at 1:47 PM
    #5552
    tonered
    tony
    Lynnwood, WA
    You're welcome!
    It is unlikely that there would be an issue without the Resets, but I think they are needed to get the full benefit of a tune.
  13. Jun 21, 2022 at 1:59 PM
    #5553
    Shellshock
    Iowa
    ^ 100%
    LV resets make a huge difference and NOT doing them is a mistake. yeah.. sometimes the learning sucks sometimes.. but its worth it. doing a 10 minute idle definitely helps. then usually within 100 miles its fairly well sorted and fully settled by 500 or so.
  14. Jun 25, 2022 at 5:43 AM
    #5554
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Anyone have a laptop they don’t need that has a working techstream installed? Mine crashed and when I bought a new one no matter what I try no version of techstream will work on any new computer. I get it installed and registered but won’t install an ecu update. I can change any settting on a vehicle just cannot flash an ecu anymore at all
  15. Jun 25, 2022 at 6:05 AM
    #5555
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I have my old laptop that I used for TIS and VF before eventually upgrading, but it's honestly kinda shitty and a bit overtaxed, I wouldn't wish it upon you.
    At the time that I upgraded, it was able to successfully update ecu versions with TS but just couldn't seem to handle VF anymore lol
    That said, I had no issues getting a new laptop and installing one of the latest TS versions using MHHAuto's forum
    Shellshock likes this.
  16. Jun 25, 2022 at 6:24 AM
    #5556
    newdles
    Achmed
    I’ve tried the newest from there but can’t flash tsb updates. I’ve removed, reinstalled, and now bought a 3rd computer brand new for trial and no dice.
  17. Jun 25, 2022 at 7:29 AM
    #5557
    mZiggy
    mZiggy Honey badger
    Marc
    The version I'm on isn't the absolute newest, it's one or two behind, works fine for me. I'd have to see which one it is
  18. Jun 25, 2022 at 7:35 AM
    #5558
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    What is Techstream saying/doing?
  19. Jun 25, 2022 at 8:25 AM
    #5559
    newdles
    Achmed
    Does nothing but pops a screen up saying low voltage b+ check all sorts of stuff. Even with power supply hooked up.
  20. Jun 25, 2022 at 8:29 AM
    #5560
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    And you're sure that the issue isn't a blown OBD fuse? @G8R_Taco ran into that issue once. Would hate to suggest getting a new laptop over something simple. I don't know if it's necessary to have a good fuse in order to do customization settings though.
Thread Status:
