ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Jul 24, 2022 at 5:26 PM
    #5581
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Nonetheless, and I asked him to do this, but he should still reach out to Magnuson to get their 04B82 copy of the tune for his truck.
    I actually ask everyone who applies the ECU update to do this regardless of how smoothly the process goes, just so they have it available. They paid for it, they should have it even if they never use it again.
  2. Jul 24, 2022 at 5:48 PM
    #5582
    mZiggy
    mZiggy Honey badger
    Marc
    @reymataco sent you an additional couple messages as follow up.
    ktbell444 and PapaRee like this.
  3. Jul 24, 2022 at 7:32 PM
    #5583
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    So trying to flash the Stock tune as a test isn't working?
    reymataco likes this.
  4. Jul 24, 2022 at 8:02 PM
    #5584
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    seems as though the OBD device / computer cannot now connect to the ECU and start only cranks. @reymataco please describe and converse with @tonered.
  5. Jul 24, 2022 at 8:07 PM
    #5585
    tonered
    tony
    Lynnwood, WA
    Dang. I know that helped some folks when the Recovery didn't.
    I saw @mZiggy 's post.
    I feel that a bench flash will sort it out, but I was hoping for a final, easier option.
    It might also be worth trying to flash or Recover with another vF person, if possible? Just to eliminate any computer or Tactrix possibilities.
  6. Jul 24, 2022 at 8:20 PM
    #5586
    GoldenBrew
    Golden, Colorado
    Background:
    he is trying to go from 04B81 (Magnuson tune) to 04B82 + Stryker tune
    He flashed back to stock 04B81, then used the most recent 04B82 CUW TSB file for his truck. then started the truck, everything was good. This was not the updated Magnuson Tune - then he shut off the truck and put it back into accessory mode and flashed the Stryker tune. After seeing the "successful" message he tired to start the truck - it won't start, just cranks. Now the ODB2 serial device can't talk to the truck either. So he can't try to reflash. vfTuner says the device is not connected or the truck is not in accessory mode.
    tonered[QUOTED][OP] likes this.
  7. Jul 24, 2022 at 8:25 PM
    #5587
    Shellshock
    Iowa
    Have you tried connecting to the truck with techstream again?
    i had one truck I couldn’t get to flash after trying everything out there, but tried connecting with techstream and for some reason it worked.. then I was able to flash with vF
    it was super weird. Not sure if it’ll help but just another idea I’ve seen work.
  8. Jul 24, 2022 at 8:33 PM
    #5588
    tonered
    tony
    Lynnwood, WA
    Yessir. I saw that.
    Sucks. Hopefully my suggestions might help, but it is low percentage.
  9. Jul 25, 2022 at 3:13 AM
    #5589
    mZiggy
    mZiggy Honey badger
    Marc
    Super weird.
  10. Jul 25, 2022 at 6:11 AM
    #5590
    GoldenBrew
    Golden, Colorado
    Thanks for the input - all information is appreciated and welcome.
    Not sure if he has tried that. Gonna give him a call and see what the status is, and if schedules align go over to assist. Was also wondering if he can get .vft to launch (software thing); or if his Tactrix device took a dump; or if the pins of the device got damaged; disconnect battery too. a few possibilities to consider before removal of the ecu for a bench flash if all else fails.
    tonered[OP] and mZiggy like this.
  11. Jul 25, 2022 at 7:20 AM
    #5591
    tonered
    tony
    Lynnwood, WA
    That is why a second setup (yours?) can be a quick verification of that. Since his VIN is Unlocked, flashing would be fair game for anyone.
    mZiggy likes this.
  12. Jul 25, 2022 at 7:32 AM
    #5592
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I have a Tactrix and Techstream setup in Denver if that is helpful.
    mZiggy and tonered[QUOTED][OP] like this.
  13. Jul 25, 2022 at 7:33 AM
    #5593
    tonered
    tony
    Lynnwood, WA
    Awesome!
    :cheers:
  14. Jul 25, 2022 at 7:36 AM
    #5594
    mZiggy
    mZiggy Honey badger
    Marc
    This community is so helpful for each other, thanks for the offers of assistance guys.
    tonered[OP] likes this.
  15. Jul 25, 2022 at 8:46 AM
    #5595
    reymataco
    reymataco Well-Known Member
    Denver, CO
    2020 DCLB Off Road Premium in Slowsand
    Hey folks,
    The love and support is overwhelming. I got members calling me yesterday and first thing this morning asking if they can help. What a great community, indeed.
    TL;DR - I think a low voltage event occurred during the last step applying the Stryker tune.
    History:
    Magnuson tune on 04B81
    Reset to 04B81
    TSB *.cuw file to go to 04B82
    Confirmed post flash, ECU reads 04B82
    Start the truck, it runs ok, just doesn't have knowledge that the SC is there.
    Flash the Stryker tune, progress bar finishes, success popup says Success, turn off IG and start the truck.
    Unplug the cable, set the laptop aside
    Climb in to start the truck, but it won't start, it just cranks.
    VFTuner/Tactrix can't talk to the ECU anymore
    So some updates:
    The Tactrix cable pins are in good order. The two in the middle along the longer row are longer than all the other pins. This is also true on my VFTuner branded ODB2 serial device (which was only used once by RSG when installing the SC).
    But the VFTuner program 1.6.x sees the cable just fine. The program won't work with the other VFTuner branded ODB2 serial device because its not registered to that device's ID.
    When trying to apply the last step, flashing the Stryker tune, the battery voltage was like 11.9 so it wouldn't begin the flash. That is part of the reason I started the truck (thus verifying the flash up to 04B82 stock was ok). I only ran the truck for a couple minutes so it was probably just not enough to survive the intercooler/water exchange pump demand during the flash?
    I also have a hood mounted solar panel but the blue sea breaker is default to disconnected so that wasn't in play at the time (but should have been).
    Next steps are to see if TechStream 16 can talk to the ECU still.
    If it can, I will try the baseline flash back to 04B80 since that is what my truck originally shipped with. And the latest *.cuw TSB file will take 80 or 81 and bring them to 82.
    If it can't see the ECU then I will try Gen 2 force flash of the same baseline 04B80 file.
    Else, remove the ECU and hope @MGMSangTaco is available. I could make a bench setup from my second ODB2 device, but who's got time for that sh*t when you're on TW but are supposed to be at work! :bananadead:
  16. Jul 25, 2022 at 8:55 AM
    #5596
    mZiggy
    mZiggy Honey badger
    Marc
    Keep us updated.
    However, WRT Techstream you will not be able to return to 04B80 or 81, since the update to 82 was applied. Techstream does not support ECU ID reversion. As such, flashing a 04B80/81 stock file is not an option either.
  17. Jul 25, 2022 at 9:11 AM
    #5597
    tonered
    tony
    Lynnwood, WA
    :cheers:
    Mine is the same.
    11.9V is plenty good. It is when it dips into the 10s that you need to worry, but we have seen a few folks that got hoarked up by the coolant pump. Startup draw is always short, but always more than constant draw. That may have dipped it down enough.
    You do not need to disassemble your spare Tactrix to make a bench flash setup. Just some good jumpers.
    What @mZiggy said. You are now 04B82 no matter what.
    Shellshock and reymataco[QUOTED] like this.
  18. Jul 25, 2022 at 9:13 AM
    #5598
    reymataco
    Denver, CO
    Good to know. The very first thing I did yesterday in an attempt to recover the ECU, was attempt to flash the 89663-04B82.vfc file with VFTuner ECU Flash function. No joy.
    tonered[OP] and mZiggy[QUOTED] like this.
  19. Jul 25, 2022 at 9:18 AM
    #5599
    reymataco
    Denver, CO
    Sounds like its:
    1) connect with TechStream
    2) if that works, force flash gen 2 on the 89663-04B82.vfc stock tune, then flash the YW-Stryker.vft tune.
    or
    2) if that works, force flash gen 2 with the YW-Stryker.vft tune.
  20. Jul 25, 2022 at 9:25 AM
    #5600
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    You may want to use an external power supply/battery tender to keep your voltage high enough during the flash. The draw from your pump may be too much (especially after a slow TSB update and flash) and dragged you down to lower than what you thought you saw. I know someone on here found that you cannot pull the fuse, so that's out of the question. Maybe others with the SC have an idea?
Thread Status:
