ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Jul 27, 2022 at 1:43 PM
    #5661
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Okay thank you.
  2. Jul 27, 2022 at 6:40 PM
    #5662
    reymataco
    reymataco Well-Known Member
    Denver, CO
    2020 DCLB Off Road Premium in Slowsand
    MGMSangTaco likes this.
  3. Jul 27, 2022 at 6:44 PM
    #5663
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    Please update us if ya get an answer on it. Again I know you worked hard on stryker/did a ton of testing and it wasn’t a dig at all- in fact I know people like it and as you know I considered trying it, I just wanted to make my position/involvement clear for potential clients.
  4. Jul 27, 2022 at 6:47 PM
    #5664
    mZiggy
    mZiggy Honey badger
    Marc
    I actually heard back from Mat a bit ago, but in regard to the Decode error. Turns out that's due to trying to open or flash a tune that was created/exported in a version of VFTuner that is more up to date than your own.
    Haven't heard back yet about this incident.
    Will keep people updated.
  5. Jul 27, 2022 at 7:09 PM
    #5665
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Sounds like bad software engineering.
    Mat, put a check in place while loading file that if created/exported in newer VF Tuning software, display error and upgrade message for VF Tuning. Don't allow this to flash the truck and brick it.
  6. Jul 27, 2022 at 7:09 PM
    #5666
    MGMSangTaco
    Denver, CO
    He was on the most recent update, I could tell cause I updated today myself from last most recent vfpro (I can’t even say what that was at this point with all the numbers) to most recent (then bought 100 credits) and there was a different looking toolbar/grey on top I didn’t see last week.
  7. Jul 27, 2022 at 7:10 PM
    #5667
    JasonLee
    15 TRD OffRoad
    How did you end up un-bricking it, @MGMSangTaco ? ECU on bench power and connected to ODBII and reflash to older, good firmware?
  8. Jul 27, 2022 at 7:13 PM
    #5668
    mZiggy
    mZiggy Honey badger
    Marc
    Yeah he'd confirmed that he was fully updated too.
    Just passing that info along since a few people have been getting it recently.
    MGMSangTaco[QUOTED] likes this.
  9. Jul 27, 2022 at 7:13 PM
    #5669
    MGMSangTaco
    Denver, CO
    No I only use the most current software per matt’s request in good faith.
    Here’s what i wrote up today after doing it cause I couldn’t find a good actual SOP. Glad I did that cause I’m smoking meats and drinking beers and it would have been more difficult tomorrow. I couldn’t find something clear on the interwebs after doing my own research while my lady was in my ear telling me I’m a nerd and to pay attention to her so here it is written out.
    Bench flash procedure/at least what worked for me today
    1. Connect tactrix to laptop BEFORE providing any power to ECU
    2. Align all bench flash ports to ECU and plug in- it’s easy they’re all keyed separately and you can’t miss
    3. Connect loose red wire from harness/IGN and loose black wire with all necessary ground attached to Schumaker jump clamps (if you have a 12v battery that will work too but will need necessary connections) provide constant power between 12v-13.5v)- the noco wasn’t switching from off position to provide power. Tried multiple times and couldn’t get it to register when connecting to the little leads. Perhaps a heavier duty connection at the ends of the loose wires would do the trick but Schumaker made it easy and verified with a voltmeter. Note- the Schumaker is very expensive but came in handy and is specifically used for flashing vehicles
    4. Select stock file of current ECU cal
    5. Gen 2 force flash. Should take right away.
    6. When flash was complete, turn shumaker off to emulate the truck power/ign off
    7. Disconnect and plug ECU back into truck
    8. Voila. Truck should be ready to romp
    JasonLee[QUOTED] and GoldenBrew like this.
  10. Jul 27, 2022 at 7:18 PM
    #5670
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Happy to help. Sounds like your truck is back up and running thanks to the awesome TW community here.
    Also, @dave82at built @MGMSangTaco Bench Flash Harness. So solid group effort here. Lots of good people here. We try to make sure we have a solid network of tuners populated with all the tools for the job.
    https://toyotatuningnetwork.com/locations
    Sounds like a win to me!
  11. Jul 27, 2022 at 7:23 PM
    #5671
    MGMSangTaco
    Denver, CO
    Thanks Bart. Always appreciate you.
    In other news:
    https://youtu.be/I0spFY1I2NQ
    Bastek likes this.
  12. Jul 27, 2022 at 7:36 PM
    #5672
    reymataco
    Denver, CO
    Very first attempt from the bench at Prepare ECM and Force Flash Gen 2 failed, just like it did in the truck. So we restarted vfTuner (not the computer) and did Force Flash gen 2 of the stock 04B82 file, and it worked. Then put the ECU back, then did the standard method of applying a tune from the ODB2 port in the truck, with the Magnuson 04B82 file from Ryan. Everything is up and running, just test drove the truck, it feels like it did before, no issues.
  13. Jul 27, 2022 at 9:27 PM
    #5673
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
  14. Jul 28, 2022 at 7:09 AM
    #5674
    reymataco
    Denver, CO
    My question is what version of vfTuner is Ryan at Magnuson using? Because he was able to cut me a new file on the new ECU ID 04B82 on Monday. Emailed it and I took it down and copied it over with the rest of the tune packs on the laptop. So, it worked. Let me email him and ask what version they're using.
    [Edit]
    "I am on the current version. I would make sure there are not antivirus software’s running while ... saving the file."
    - Ryan
  15. Jul 28, 2022 at 7:21 AM
    #5675
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    ?? wonder if this update is a case where the old version should be deleted and entire new version downloaded ??? @tonered what do you think.
    my version is 1.6.7....updated 7/25/2022
  16. Jul 28, 2022 at 8:21 AM
    #5676
    mZiggy
    mZiggy Honey badger
    Marc
    As a follow up, I worked with @ktbell444 this morning to use VFTuner 1.6.7.x (most up to date version, and same version Matthew's files were VIN locked with) to VIN lock both a NA 3.5L tune file and a Stryker 3.5L tune file (both 04B82 EROM) using ktbell's VIN. He flashed both tunes to his truck successfully, said they both started right up.
    ECU ID matches that of Matthew, and I used the same process for VIN lock/saving prior to distribution that I always have, so I'm not sure why Matthew's ECU bricked. Especially in the manner it did, appearing to have completed flash.
    Will continue to investigate.
  17. Jul 28, 2022 at 8:33 AM
    #5677
    reymataco
    Denver, CO
    I write software for a living... this one is sneaky. If I hadn't taken Ryan's tune down from email on my mac, save to flash drive, boot windows, grab from flash drive... I'd say it was something corrupting the file along the mac to windows file systems or what not, but that doesn't add up.
    My truck is a 2020 DCLB Offroad AT w/ Premium package (sunroof, JBL, front camera, etc) - what is yours @ktbell444 ?
  18. Jul 28, 2022 at 8:36 AM
    #5678
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    2020 Pro, so the B82 TSB applied to both of our vehicles.
    mZiggy likes this.
  19. Jul 28, 2022 at 8:37 AM
    #5679
    mZiggy
    mZiggy Honey badger
    Marc
    My antivirus is on, on my PCs, but I have exceptions built into all my relevant tuning folders and install directories which is pretty common practice for lots of us.
    JDSmith and ktbell444 like this.
  20. Jul 28, 2022 at 8:38 AM
    #5680
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Not the first won't be the last. Just the way bad software works.
Thread Status:
