ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Jul 28, 2022 at 9:24 AM
    #5681
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Will PM you with an update on options available with the current information @reymataco
    GoldenBrew and reymataco like this.
  2. Jul 28, 2022 at 6:35 PM
    #5682
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Checksum? Pretty common, especially if moving and updating firmware with USB flash drives. Run a checksum after writing to the USB drive. Ideally compare to the supplier provided value, or if that's not available, the freshly downloaded file.
    JasonLee likes this.
  3. Jul 28, 2022 at 7:34 PM
    #5683
    mZiggy
    mZiggy Honey badger
    Marc
    VFTuner/Mat didn't find an issue with the file following review. Recommended re-doing the procedure normally used (ensure customer is on newest VF version, start with previously built file, apply VIN and export).
    GoldenBrew and Shellshock like this.
  4. Aug 19, 2022 at 9:20 AM
    #5684
    LunarQ8
    LunarQ8 New Member
    2021 Lunar Rock TRD Pro
    Hey Guys.
    first time posting!!
    before tuning my truck with a OTT tune I discovered my ecu version was 04c20, I wanted to update and I followed OP guide , i managed to get techstream V14 up and running but have a few question before going through the update.
    my truck VIN number and window sticker shows that my truck is 2021 model but the ecu and door sticker shows its a 2020 model, is it something I should consider if I only want to update ?
    my battery voltage is 12.3 is it safe to flash without using the battery charger?
  5. Aug 19, 2022 at 9:26 AM
    #5685
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    ECU is not a 2020, else it would be 04B80, 81, or 82 for the ID. Door sticker is when it was manufactured, doesn't necessarily tell you the year. Update to 04C21 and you'll be just fine.
    12.3 VDC is fine, but check again before flashing the tune. Flashing the update takes much longer than flashing a tune.
    LunarQ8[QUOTED] and PhogDog like this.
  6. Aug 19, 2022 at 9:27 AM
    #5686
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    The TS and vF software and the ECU Update Wizard will tell you your ECU ID.
    If you can listen to the radio for 30min on Accessory, you can do a 10min flash.
    LunarQ8[QUOTED] and ktbell444 like this.
  7. Aug 19, 2022 at 9:32 AM
    #5687
    LunarQ8
    LunarQ8 New Member
    Thank you, I'll be flashing the update, just wanted to confirm i have to only update the file itself (04c21) without having techstream running correct ?
  8. Aug 19, 2022 at 9:33 AM
    #5688
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Correct. You need Techstream installed and configured, but you do not need to open it up. Just double-click on the .cuw file and it will walk you through, step-by-step.
    LunarQ8[QUOTED] likes this.
  9. Aug 19, 2022 at 9:35 AM
    #5689
    LunarQ8
    LunarQ8 New Member
    thank you for your reply, didn't know that I can update the ecu via VF tuner. I already have it installed TS, would you suggest updated it via VF tuner or TS ?
  10. Aug 19, 2022 at 9:36 AM
    #5690
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    vF Tuner does not support updating ID's yet. So you need Techstream.
  11. Aug 19, 2022 at 9:38 AM
    #5691
    tonered
    tony
    Lynnwood, WA
    Like @ktbell444 said. vF cannot update ECUs yet. Just saying that you can check ECU IDs with it.
    ktbell444 and LunarQ8[QUOTED] like this.
  12. Aug 19, 2022 at 11:28 AM
    #5692
    LunarQ8
    LunarQ8 New Member
    Hey there,
    Just a quick update
    I went ahead and updated my ECU and it all went smooth.
    Thank you for your help
  13. Aug 19, 2022 at 11:33 AM
    #5693
    TacoTunesday
    TacoTunesday Well-Known Member
    Tony
    It will be nice when VF has this ability but TS handles it pretty easily.
  14. Aug 19, 2022 at 11:36 AM
    #5694
    tonered
    tony
    Lynnwood, WA
    You're welcome!
  15. Aug 22, 2022 at 2:44 PM
    #5695
    TacoTunesday
    Tony
    At one point I ran across a decent thread of various Techstream instructionals detailing how to modify door chimes, seat belt chimes, etc...can someone point me in the right direction? Thanks!
  16. Aug 22, 2022 at 2:45 PM
    #5696
    tonered
    tony
    Lynnwood, WA
    The very last Spoiler in the 1st Post has the link.
  17. Aug 22, 2022 at 2:46 PM
    #5697
    TacoTunesday
    Tony
    There it is! Thanks again!
    tonered[OP] likes this.
  18. Aug 22, 2022 at 2:58 PM
    #5698
    tonered
    tony
    Lynnwood, WA
    You're welcome!
  19. Aug 26, 2022 at 10:29 AM
    #5699
    Kruuuzn
    Kruuuzn Well-Known Member
    Randy
    Traverse City, Michigan
    I just downloaded and installed TechStream V14.20.019 from the first page of this thread and Shellshocks EXCELLENT directions. Everything went smoothly but when I click on CONNECT TO VEHICLE (just trying this before actually connecting to my truck) I get a CRITICAL UPDATE pop-up window telling me this version is obsolete and needs to be updated. That didn't bother me until I noticed the CANCEL button is greyed out and not available.
    Will this happen when I connect to the truck? If so, what's the best way to handle it?
    MegaHurts777 likes this.
  20. Aug 26, 2022 at 10:32 AM
    #5700
    tonered
    tony
    Lynnwood, WA
    See the red text in the 1st Post.
Thread Status:
