ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Aug 16, 2018 at 12:17 PM
    #781
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Sorry! One question. Engine not running, but the key in the On position, key in the Accessory position, or key out? It thought the first situation was said earlier?
  2. Aug 16, 2018 at 12:27 PM
    #782
    mstrbrc
    mstrbrc Well-Known Member
    ABQ
    '16 DCSB OR MT
    While you're plugging everything up don't even have the key in. Once you open the CUW file it will prompt you on the computer screen about what you need to do with the truck and what position to have the key in... Just plug everything up and run the file, the program will guide you the rest of the way.
  3. Aug 16, 2018 at 12:30 PM
    #783
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    I haven't tried it yet. I have one of the cheesy ebay/Amazon cables, and I'm not 100% confident in it's quality. When I get a few minutes, I'll hook it up to the truck and try changing a few customization settings and go from there.
    This cable did work to delete and program keys from my '05 ecu, so it should be fine...
  4. Aug 16, 2018 at 12:31 PM
    #784
    tonered
    tony
    Lynnwood, WA
    Perfect! That is idiot proof enough for me.
    0uTkAsT and Whitetail Assassin like this.
  5. Aug 16, 2018 at 12:51 PM
    #785
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    Question, what effect will this have at smog time. Seems to me if there is no tag showing the updated ECU from a dealer that you will be failed.
  6. Aug 16, 2018 at 12:55 PM
    #786
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    That doesn’t make sense man. It’s an update for the manual. It’s not some weird alteration of exhaust fumes like VW. You will be fine.
  7. Aug 16, 2018 at 12:57 PM
    #787
    SContiVT
    SContiVT Back in a Toyota
    Central Vermont
    2010 Tundra Rk Wr/2023 WRX/2023 Ford Exp
    Isn't that sticker more for mandated recalls affecting the ECU?
    P.S. Love that VT only has a MIL check and Safety Inspection. Made using my Accessport on my Legacy GT more enjoyable...:burnrubber:
    tonered[OP] likes this.
  8. Aug 16, 2018 at 1:07 PM
    #788
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    Cali is a whole nother thing.
  9. Aug 16, 2018 at 1:22 PM
    #789
    Whitetail Assassin
    Tedric
    West Virginia
    I got ya, but Toyota wouldn’t just throw a fix together to make you fail an emission test. If that is the case, take it to your dealer and make them sort it out. A 3rd of any year has no business failing an emission test unless you are dumb enough to delete your cats or something.
  10. Aug 16, 2018 at 1:33 PM
    #790
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    Also, if you check the thread for the AT tsb 62, some dealers dont put that fancy sticker under the hood stating its been updated per the TSB.
    Worse case replicate a sticker and copy the text from a picture of a stickered truck.
    A dealer can forget to note it down on the service records as well....
  11. Aug 16, 2018 at 1:40 PM
    #791
    Zoop
    Zoop Well-Known Member
    I asked the tech upon the update about the new sticker and his reply was "those things? I don't even know the last time we actually used them"
    tonered[OP] and Burro09 like this.
  12. Aug 16, 2018 at 1:55 PM
    #792
    trdude10
    trdude10 Well-Known Member
    Nick
    17 DCSB Trd OR 6sp
    Does anyone in the north bay have the tools to do it? If youre willing to help me out some beer and a burrito are on me!
  13. Aug 16, 2018 at 2:00 PM
    #793
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Just curious, how was it known that T-0033 is for 16-17 trucks and T-0037 is for 18 trucks? Not doubting, just curious how this was determined.
  14. Aug 16, 2018 at 2:05 PM
    #794
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    You run it and it says so
  15. Aug 16, 2018 at 2:08 PM
    #795
    mstrbrc
    ABQ
    '16 DCSB OR MT
    Here's the link to that post on page 11: Software Update for the Manual!
  16. Aug 16, 2018 at 2:08 PM
    #796
    Rainman70
    Rainman70 Well-Known Member
    2016 Tacoma extra cab 6 speed 4x4
    Anybody use the cheap Amazon cable yet? And are people paying for the tech stream subscription to get the files or using the free stuff?
  17. Aug 16, 2018 at 2:10 PM
    #797
    inksin
    Hawaii
    free stuff
  18. Aug 16, 2018 at 2:12 PM
    #798
    2016trdtacoma
    Trevor
    Utah
    No, I just use the one I got from OVTune.
  19. Aug 16, 2018 at 2:14 PM
    #799
    mstrbrc
    ABQ
    '16 DCSB OR MT
    Read page 39 up to current please.
  20. Aug 16, 2018 at 2:16 PM
    #800
    ToyoVL
    ToyoVL Well-Known Member
    Because when I downloaded the files from TIS, that was the way they named those files for those specific trucks. On 2nd note, when you installed Techstream, run CUW.exe it's in C:\Program Files (x86)\Toyota Diagnostics\Calibration Update Wizard\cuw.exe then click on file open and select the cuw file that I posted, you'll see what year the file is for. For example I clicked on 34-18 file it showed for 16-17 Tacoma AT
    So summary is file 33-18 is for 16-17 MT
    34-18 is for 16-17 AT
    36-18 is for 18 AT
    37-18 is for 18 MT
Thread Status:
