ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Sep 18, 2018 at 7:35 AM
    #1801
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    :cheers:
  2. Sep 18, 2018 at 7:58 AM
    #1802
    su.b.rat
    su.b.rat broken truck
    yeah yeah yeah... that's post #1828 everyone. don't forget that number when folks ask.
    thank you Tony!
  3. Sep 18, 2018 at 7:59 AM
    #1803
    tonered
    tony
    Lynnwood, WA
    No problem!
    TeecoTaco likes this.
  4. Sep 18, 2018 at 8:09 AM
    #1804
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    POST #1828 FTMFW
    @Livinserene , where you at lol?
    Thanks for putting this together Tony :hattip:
    02Duck, Livinserene and tonered[OP] like this.
  5. Sep 18, 2018 at 8:30 AM
    #1805
    tonered
    tony
    Lynnwood, WA
    Hahahahahahahaha!
  6. Sep 18, 2018 at 10:06 AM
    #1806
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    I’m here man I’m here lol thanks !!
    MOC221_[QUOTED] and tonered[OP] like this.
  7. Sep 18, 2018 at 10:13 AM
    #1807
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Awesome, DCH Oxnard did my clutch and rear diff repairs!
    derf77[QUOTED] and shakerhood like this.
  8. Sep 18, 2018 at 10:55 AM
    #1808
    DirtyD1985
    DirtyD1985 Well-Known Member
    Dain
    2017 White TRD Sport
    Tactrix success for me. Stumble 90% eliminated, and acceleration through power band is much smoother. Big thank you to everyone
    Bascoma, specter208, su.b.rat and 2 others like this.
  9. Sep 18, 2018 at 11:12 AM
    #1809
    tomz3rdtoy
    tomz3rdtoy Well-Known Member
    Tucson
    '16 White DBL Cab ORSB 6MT
    Icon f/r, add-a-leaf, SR8 w/285/75-16 BFG KO2
    Findlay and Desert Toyota need a wake-up call (corporate-type).
    ajsabra[QUOTED] likes this.
  10. Sep 18, 2018 at 12:39 PM
    #1810
    derf77
    derf77 Well-Known Member
    Fred
    South Chesterfield, VA
    2017 TRD DCSB OR MT Silver
    6112's 2.75 in. lift front, Icon UCA's, 5160s w/res, Deaver mini pack in the 1.5 in rear lift, TJM Rock Crawler front Bumper, Baja Squadron Sport lights, TJM Rock crawler lights, SPOD w/touchscreen, Rokblokz rear mud flaps, Method NV Wheels, 285/70R17 Nitto Ridge Grapplers
    What is the clutch problem I keep hearing about?
  11. Sep 18, 2018 at 12:54 PM
    #1811
    specter208
    California
    I think most people are having issues with squeaky pedals. I had a overtorqued pressure plate causing clutch drag for notchy shifts and bearing type noise.
  12. Sep 18, 2018 at 12:59 PM
    #1812
    shiftz
    shiftz Active Member
    GTA
    '19 DCSB 6MT Sport
    Can I ask how this was diagnosed and resolved?
  13. Sep 18, 2018 at 1:05 PM
    #1813
    specter208
    California
    Sometime In my first 500-600 miles I started hearing a whistle sound when pressing the clutch. Then I started feeling some resistance when pulling the shifter out of gear and some notchyness on shifts. Took it in, did a ride along with a tech to confirm the noise which was very subtle but it was there. Tech dropped the tranny and found that the clutch pressure plate bolts were stripped from over tightening with an air powered tool.
  14. Sep 18, 2018 at 1:23 PM
    #1814
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    I just got a call back from corporate, but it wasn't related to my engine calibration update. It was for my clutch complaint that the dealer couldn't "replicate", Sometimes I need to clutch twice to get it in gear from a stop, and sometimes it's notchy like you stated, my clutch has been inconsistent for a while and it is happening more and more often.
    They had a record from when they repaired my creaking clutch the first time, and they said they will have the service manager call me to take care of this concern even though they couldn't replicate it. I'm hoping this is the fix, and they will fix it. I'm tired of wasting my time at Findlay Toyota.
    Dirtridercrf250 likes this.
  15. Sep 18, 2018 at 1:34 PM
    #1815
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Holy crap this tread grew, what're you all on TW at work
    derf77 likes this.
  16. Sep 18, 2018 at 1:48 PM
    #1816
    shiftz
    GTA
    '19 DCSB 6MT Sport
    Wow. Dealer just installed a URD clutch for me and will be very reluctant to pull stuff apart unless on my dime. Don't think I'm hearing anything but will pay close attention. What's baffling is 3rd to 2nd downshifts are very smooth, but 1st to 2nd very bad sometimes, also 0 to 1st/Reverse.
    How important is this whistle noise as a symptom?
    Did they just replace the bolts or entire clutch assembly?
    On topic: Just had software updated from B10 to B13 and after short drive agree with everyone here that throttle is almost normal now. You should not need to do this yourself, as stated in this thread, once they actually run the update check they will either get a green checkmark to go ahead or not. My guess is the dealers rejecting people don't even run the check. There was hesitation from technician for liability reasons and info from this thread went a long way to help convince him that research was done.
    Main issue was the pdf of Canadian TSB version (5133 I believe) shows only B12 not B11 or B10, that's where the .cuw file came in handy as it lists all 3 as targets. Dealer was Scarborough Toyota.
    Was hoping this would help with shifter going into 2nd easier but no dice.
    Granny shifting and ripping it up seem to go okay but can't do normal.
    tonered[OP] likes this.
  17. Sep 18, 2018 at 1:54 PM
    #1817
    tonered
    tony
    Lynnwood, WA
    The US version of the TSB doesn't show 04B10 or 04B11 in the table either. It's only in the software file, as you noted.
  18. Sep 18, 2018 at 2:16 PM
    #1818
    tomz3rdtoy
    Tucson
    T-SB 0186-12
    If it’s squeaking, just let them know...and mention the TSB. Experienced mechanics seem to know about this long time problem.
    They didn’t bother trying to lube it...just ordered the parts per the TSB and set up a new appt.
    derf77[QUOTED] likes this.
  19. Sep 18, 2018 at 2:47 PM
    #1819
    derf77
    Fred
    :pccoffee:
  20. Sep 18, 2018 at 3:00 PM
    #1820
    Dirtridercrf250
    Where is the full tsb? dealer said I can't demand an update on my truck. Simply asked for the manual transmission update.
Thread Status:
