ECU TSB Update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 8, 2018.
Thread Status:
Not open for further replies.
  1. Sep 28, 2018 at 9:11 AM
    #1941
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Same here, no difference in mine either.
    TBV[QUOTED] likes this.
  2. Sep 28, 2018 at 9:54 AM
    #1942
    su.b.rat
    su.b.rat broken truck
    same... i'm not saying there's no learning on the MT, but it's never been clear that mine has ever learned or changed bevavior. i watch it carefully and see all kinds of changes like different response in different temps & humidity, etc, but nothing has been clearly from my driving inputs. i've even gone so far as to change how i use the throttle for a week at a time and there's never been any obvious difference from that.
  3. Sep 28, 2018 at 9:59 AM
    #1943
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Agreed, it's not "learning" WRT driver inputs but rather due to everything settling in over time (Knock correction, fuel trims, etc etc.). Mat mentioned this a few times.
    The one thing I always notice is throttle delay/inconsistency. Every file I've flashed starts off one way and then changes over time. Sometimes it takes several hundred miles.
    Oh and it's bipolar when it comes to temps/humidity - very noticeable difference.
    nevadabugle and tonered[OP] like this.
  4. Sep 28, 2018 at 10:07 AM
    #1944
    su.b.rat
    i totally get it having seen your reports since this all began. i have watched my throttle response as the main thing since that's what you've always said is a big issue for you. i haven't ever seen my throttle response change over time after a flash. it always has stayed the same as far as i can see. probably one of those 04B10 things.
  5. Sep 28, 2018 at 10:07 AM
    #1945
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    Isn't that just VSC, TRAC and all the other nannies doing their job? I get the feeling a lot of us were raised in the pre-drive-by-wire era, and we miss the direct connection an analog throttle + manual trans gave us to the road. Perhaps we'll just have to look back fondly. Maybe I should have kept my '95.
    tonered[OP] and MOC221_[QUOTED] like this.
  6. Sep 28, 2018 at 10:12 AM
    #1946
    MOC221_
    Frank
    I'd have to say no to the nannies, because right after flashing a particular file my throttle may be very responsive and consistent... but over time it would become delayed or "squishy". It would then stay that way until the next flash.
    This is another reason I eagerly await 1.05, because I'm on 04B13 based code now - AND Mat (OVtune) has learned quite a bit more recently WRT ECU code.
    TBV[QUOTED] and specter208 like this.
  7. Sep 29, 2018 at 3:00 PM
    #1947
    mechanic
    mechanic Member
    Amarillo Texas
    2017 Inferno DCSB TRD Off-Road 6 Speed M/T
    Finally got it updated. Amazing how hard it is to communicate these days. The dealer said they thought I wanted an update to the manual transmission calibration. Once they actually looked into it and didn’t just blow me off, they figured it out. Truck is much smoother now.
    shakerhood, tonered[OP] and su.b.rat like this.
  8. Sep 29, 2018 at 3:01 PM
    #1948
    Yotaholic
    Yotaholic Well-Known Member
    Oahu, HI
    2017 DCSB Sport 4x4 MT
    I was turned away this morning. Service rep looked at the first page and saw “automatic” then quickly denied the tsb working for my truck.....
  9. Sep 29, 2018 at 3:05 PM
    #1949
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Look up the newest update. It’s a different number.
    shakerhood and tonered[OP] like this.
  10. Sep 29, 2018 at 3:09 PM
    #1950
    wtjl240
    wtjl240 Well-Known Member
    Jeff
    Spring Hill, TN
    That's TSB 125-18, right? Still doesn't include MY 2018 but it's a step in the right direction
  11. Sep 29, 2018 at 3:16 PM
    #1951
    Whitetail Assassin
    Tedric
    West Virginia
    Yeah that’s the one. I didn’t notice your year. People with 18’s have still had it done. Problem is you are probably super limited with dealerships in HI. Just print the AT one off and try again maybe soon. It has the ECU code at least.
    tonered[OP] likes this.
  12. Sep 29, 2018 at 3:20 PM
    #1952
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    Yes this is the problem for ‘18 MT owners. 125-18 is 16-17 and 58-18 is AT. If you can find someone at the dealership willing to hear you out and look at the calibration numbers they hopefully will figure it out.
    Talked to a service advisor at my local dealer when picking up some oil filters.
    I think they will do it, I’ll find out this week.
    tonered[OP] and wtjl240[QUOTED] like this.
  13. Sep 29, 2018 at 3:22 PM
    #1953
    TD90S
    GA
    ‘18 TRDOR 6MT
    Has anyone figured out a build date for when Toyota started shipping with the updated calibrations?
  14. Sep 29, 2018 at 3:50 PM
    #1954
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    A page or so back, folks with 08.2018 build dates were told that their Tacos were up to date. Those folks never did confirm the ECU IDs though.
  15. Sep 29, 2018 at 5:02 PM
    #1955
    TD90S
    GA
    ‘18 TRDOR 6MT
    Mine was built 7.2018. I haven’t checked the calibration numbers. Two biggest complaints are the tricky 1-2 shift and this thing feels like it has a rag stuffed in the throttle body below 2500. Would like to try the new calibration and let others beta test the new OV tune :thumbsup:
    tonered[QUOTED][OP] likes this.
  16. Sep 29, 2018 at 6:44 PM
    #1956
    tjr1127
    tjr1127 Member
    2018 Tacoma TRD Off Road manual
    Mine was built on 6/18 and was told it doesn't apply. Had the truck about 2 months and the stumble is driving me crazy.
    02Duck likes this.
  17. Sep 30, 2018 at 3:47 AM
    #1957
    Whitetail Assassin
    Tedric
    West Virginia
    Told ya! ;)
    tonered[OP] and Ruggybuggy like this.
  18. Sep 30, 2018 at 4:13 AM
    #1958
    TacomaSingh
    TacomaSingh Active Member
    2017 TRD Sport DCSB M/T
    I can't keep my foot off the throttle anymore! This thing flies now & I am even more proud now about choosing the manual over A/T.
    As per the HUD stats I am probably getting 1 - 1.5mpg less but I could care less about that, maybe because I am pushing it like a maniac.
    With the older ECU tune you had to drive it like a semi, now it is closer to a sports car feel and I have to get adjusted back again!
    You can drive around slow traffic and parking lots in 2nd gear or even 3rd in some places. The new smooth & instant delivery of torque gives the feeling of a all new vehicle drivetrain. From what I can judge the throttle position adjustments are revving the engine a bit higher with a smoother curve. Now, time to fix the clutch pedal squeak.
    02Duck, BlakeM, Dogg23 and 1 other person like this.
  19. Sep 30, 2018 at 4:48 AM
    #1959
    Whitetail Assassin
    Tedric
    West Virginia
    That’s crazy. I’m the opposite of your situation. Still don’t have the ECU upgrade but my clutch is getting squared away. I’m gonna talk to them some more when I go to have the parts installed and hopefully get both done the same day.
    shakerhood and MOC221_ like this.
  20. Sep 30, 2018 at 5:08 AM
    #1960
    MOC221_
    Frank
    Uh, you didn't speak with Mat?
Thread Status:
