ECU Tune and Failed Emissions Testing Experience
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PacoTheTaco303, Nov 27, 2023.
  1. Dec 8, 2023 at 1:06 PM
    #221
    kevin323
    kevin323 Active Member
    2023 White Tacoma TRD Off-Road 4x4
    Will this be coming to California residents?
  2. Dec 8, 2023 at 2:10 PM
    #222
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    We're already underway for this to be CA legal through CARB EO certification.
    machotaco91, vivid02, JS11B and 8 others like this.
  3. Dec 8, 2023 at 11:13 PM
    #223
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Ok great so whatever.
    Considering the OP got fucked in CO, did you smog yet?
  4. Dec 8, 2023 at 11:18 PM
    #224
    helix66
    DPRC
    2017 DclB TRDor MgM
    OTT……or
    Aloha Friday!!!
  5. Dec 9, 2023 at 3:41 AM
    #225
    kevin323
    LFG!!
    JustDSM[QUOTED] and GilbertOz like this.
  6. Dec 9, 2023 at 6:25 AM
    #226
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    So is this new tune software change a "cloaking device" to make a tuned truck pass an emissions test, or does it actually make a tune legal in those states that are now testing to determine if a tune exists?
  7. Dec 9, 2023 at 6:44 AM
    #227
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    After this passes for the 3.5L 2GR-FKS, is there a road map to also CARB=certify OTT's tune for the 4.0L 1GR-FE? Lots of 1GR-FE's out there.
    JustDSM[QUOTED] likes this.
  8. Dec 9, 2023 at 6:59 AM
    #228
    JustDSM
    Justin
    Ogden, UT
    Yes sir, that is the intent. We’ve already done our preliminary work with our 5-gas analyzer and dyno time doing the simulated drive cycles as well as confirming output as advertised.
    We are evaluating the landscape at this time based on the various markets (platforms we support) and will crunch the numbers as we decide what will be next.
  9. Dec 9, 2023 at 7:18 AM
    #229
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I have the OTT tune and I'm very happy with it. I live in an area that doesn't require testing, at this time, but I figured with the Colorado CARB test failure we'd be hearing about a lot of others failing by now. Maybe I missed it but I haven't heard of any other failures, on TW or any other sources. Go figure?
    Mr. Twisty and JustDSM[QUOTED] like this.
  10. Dec 9, 2023 at 7:52 AM
    #230
    JustDSM
    Justin
    Ogden, UT
    This certification validates our OTT CE calibration as emissions-compliant, performing well below the allowable thresholds for the FTP, US06, and HWFET tests. Performed independently by the full-time engineering staff at SEMA utilizing a 48-inch AVL-Zöllner 2WD emissions testing chassis dynamometer; AVL iGEM CVS system; AVL i60 AMA Emissions bench with HC, NOx, CO, CO2, and CH4 analyzers; and AVL iGEM Vehicle software suite for test cell integration and control.
    With the OTT CE calibration being tested in a CARB-approved emissions laboratory and having been awarded the CE status, you'll now have documentation to present to inspection officials validating that the program in your ECU has lower emissions output than what the vehicle was originally certified to.
    With the CARB EO, it will be 50 State legal.
  11. Dec 9, 2023 at 8:04 AM
    #231
    GilbertOz
    GilbertOz Driver
    CA
    https://giphy.com/gifs/they-live-roddy-piper-rowdy-9PPwYVFxX8L4Y
    ERod27 likes this.
  12. Dec 9, 2023 at 8:59 AM
    #232
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    It's the difference between a multinational corp having targets to hit (with a small margin to account for some variation possible in testing) vs an aftermarket company wanting to be able to show they worked for as wide a berth as possible to regulators and inspectors. This is good news, and very good to hear.
  13. Dec 9, 2023 at 10:19 AM
    #233
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Would or does that apply to 4WD testing if there is such a thing?
  14. Dec 9, 2023 at 10:21 AM
    #234
    JustDSM
    Justin
    Ogden, UT
    The vehicles are tested in their primary drive mode.
  15. Jan 16, 2024 at 12:34 PM
    #235
    rolot2
    rolot2 Well-Known Member
    Rolando
    Denver, CO
    2015 TRD OR DCSB
    Front: Extended Travel 2.5” King coilovers with/adjusters (Set at 3” lift) Rear: 2.0” King shocks with adjusters Icon RXT (Option 2) Pack Toyota TRD Cat-back exhaust AnytimeBackup Camera Anytime Front/Rear Camera RCI Sliders KB Voodoo Bed Rack Center Console Ram Mount
    Emissions concern is only thing holding me back from a tune on my 4.0L 1GR-FE. Please keep us posted on timeline.
  16. Jan 16, 2024 at 12:57 PM
    #236
    JustDSM
    Justin
    Ogden, UT
    I’ll be sure to update. It’ll probably be a year or so before we have CARB OE on the 2G 4.0L calibration as we have the 5.7L Tundra in the works at this time.
  17. Jan 16, 2024 at 1:08 PM
    #237
    rolot2
    Rolando
    Denver, CO
    2015 TRD OR DCSB
    Thank you very much.
  18. Feb 2, 2024 at 11:46 PM
    #238
    Liv4Spd
    Liv4Spd Member
    For those of us considering getting a tune... will we require a reflash once the 3rd gen Manual tunes become "Carb Certified"? Or are we covered having the ECU flashed in advance?
    Also - can we run the current flash whilst running any octane 87-91, without consequence? I have no personal need to squeeze every last HP out of a tune for this vehicle - rather, I am often in very rural areas in Canada and Alaska.. where I would wager advertised octane is less than reliably accurate. So, I guess the simple question is... is this a "safe" tune for any pump, like any other OE vehicle?
    Appreciate your work on this!
  19. Feb 3, 2024 at 6:14 AM
    #239
    JustDSM
    Justin
    Ogden, UT
    We're thrilled to offer this to the community!
    Once we secure CARB EO for the 3rd Gen Calibration, there won't be a need to flash back to stock for emissions/inspection compliance. Those who purchase the OTT-CE calibration file will be automatically included in the CARB EO program, receiving their CARB documentation/sticker at no additional cost.
    The OTT-CE file will incorporate the "octane learning" function of the OE calibration, allowing it to operate on a range of fuels from 85 to 93 and beyond (we recommend using 87 or higher for optimal performance/economy). While we always suggest quality fuel from Tier 1 facilities, it's important to note that it is recommended but not required.
  20. Feb 3, 2024 at 6:35 AM
    #240
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I carry octane booster for those scenarios just to be safe.
    Liv4Spd[QUOTED] and JustDSM like this.
