ECU Voltage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scalleywag, Jan 8, 2020.
  1. Jan 12, 2020 at 7:28 PM
    #61
    Scalleywag
    Scalleywag [OP] Well-Known Member
    North Carolina
    2005 SR5 Double Cab V6 6 Speed
    When I checked my voltage at the OBD2 port there was zero drop compared to the battery. I suspect the scan tool may be the reason for the lower reading which is now within a few tenths of a volt. That’s measuring battery voltage with my DVOM and ECU voltage with the scan tool.
    There must be something here I’m missing.
    Is it possible the voltage is present all the time at pin 2 of F19 and the gauge switches by the ground? Perhaps 11ish volts is the ref voltage before the sending unit rheostat?
  2. Jan 12, 2020 at 7:44 PM
    #62
    Scalleywag
    North Carolina
    I double check all my wiring again along with the terminations on the fuse box as well.
    DG92071[QUOTED] likes this.
  3. Jan 13, 2020 at 6:14 AM
    #63
    DG92071
    DG92071 Well-Known Member
    That's actually how I would expect it to be wired but like I wrote before I don't know Tacomas electrical systems.
  4. Jan 13, 2020 at 6:17 AM
    #64
    DG92071
    Then there isn't a connection issue with that power line so you don't need to look under the fuse box, or peel the battery cables insulation, or anything else pertaining to that power line.
    Replace the cluster.
  5. Jan 13, 2020 at 6:31 AM
    #65
    Scalleywag
    North Carolina
    Roger that, I’ll start looking for a second hand unit
    DG92071 likes this.
  6. Jan 13, 2020 at 3:47 PM
    #66
    Scalleywag
    North Carolina
    Delphi fuel pump assembly taken 12-16-19
    Note the fuel level and mileage
  7. Jan 13, 2020 at 3:49 PM
    #67
    Scalleywag
    North Carolina
    OEM Toyota assembly as of about 15 minutes ago.6CB9454A-E9B0-4A2F-B883-531292457577.jpgSomething has definitely changed as far as the indication. 40 miles less to 3/4 of a tank. I’m going to burn through this tank and see how low the gauge goes.
    I usually don’t like problems that fix themselves but maybe I’m overthinking the whole thing.
    Now to figure out why the engine is knocking and that cool red light is on below the speedo!? LOL
    DG92071 and CurtB like this.
  8. Jan 17, 2020 at 8:51 PM
    #68
    Scalleywag
    North Carolina
    A9FBC94A-12D1-43B0-96E3-11A4B1313B07.jpg Things are still headed in the right direction!! This is dead on so far as the past three times I’ve run the tank dry I was indication 360-370 miles per tank until the engine stalled! The needle looks like it’s slightly above half in the picture but it’s due to the angle, it showed slightly below half from my perspective seated in the truck.
    DG92071 and Muddinfun like this.
  9. Jan 17, 2020 at 8:52 PM
    #69
    Scalleywag
    North Carolina
    EFD379DA-BB60-4FFB-8E8A-0F765EBF638B.jpg This was with the Delphi unit
  10. Jan 17, 2020 at 8:54 PM
    #70
    Scalleywag
    North Carolina
    Delphi tank number 2, it was very consistent. Just consistently inaccurate!
  11. Jan 18, 2020 at 7:14 AM
    #71
    DG92071
    The Delphi unit is showing inaccurate readings and the OEM shows accurate readings, is that correct?
  12. Jan 18, 2020 at 12:05 PM
    #72
    Scalleywag
    North Carolina
    Yes, so far that is correct. What surprises me is all three sending units ohm’d out very closely. Either way, I’ll take it.
  13. Jan 19, 2020 at 3:35 PM
    #73
    Scalleywag
    North Carolina
    4BC056AD-E1A7-4FC9-B6FA-97FF9F4576EA.jpg Well, looks like my problem is still here. I put 20.6 gallons of fuel in the tank and took this picture before I stepped out to refuel. No low fuel level light and the gauge only goes to 1/8 of a tank. Looking for a spare cluster now that I can swap to see if the indication changes. I talked to a few gauge overhaul shops and they indicated they see a fair number of Toyota gauge clusters for speedo and fuel gauge repairs. I wish my cluster was one of the models that had the replaceable fuel gauge module!
  14. Jan 19, 2020 at 9:21 PM
    #74
    DG92071
    I just figured out the Delphi/OEM that you were writing about was the sending unit and not the cluster. Lol
  15. Jan 20, 2020 at 3:24 PM
    #75
    Scalleywag
    North Carolina
    DG92071 likes this.
