ECU Water Damage
Discussion in '1st Gen. Tacomas (1995-2004)' started by TruckingNW, Apr 19, 2017.
  1. Apr 19, 2017 at 8:29 PM
    TruckingNW
    TruckingNW [OP] New Member
    Hi Folks,
    I've got a 2003 3.4L V6 4wd Tacoma and the ECU just went bad due to water damage. It had corrosion along the back-right portion of the board (side closest to the passenger door as it sits in the truck). Just spent 10 minutes spraying a hose into the cowl and on the windshield, and I can't see any water leaking in... Is there another spot that I should test or is there something I'm missing?
  2. Apr 20, 2017 at 12:01 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    If the board is badly corroded you probably destroyed some of the copper traces on the PCB. If that's the case I'd go buy a new ECU especially with how important they are. You can try using some 99% Isopropyl to clean the board as best as you can. Not sure where the water would be coming from.
  3. Apr 20, 2017 at 1:11 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do you have a hole in the floor in front of the ECM ??
    Unless you were using the truck as a water craft and had water deep enough to reach the ECM
    With the ECM mounted parallel to the floor water just about has to be spraying onto the plugs and filtering inside .
  4. Apr 20, 2017 at 5:33 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    ? Ecm is mounted above A/C box
    Not near the floor.
  5. Apr 20, 2017 at 12:03 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    AC box I don`t know what that is do you mean the Evaporator coil ??
    Well if I say Firewall it confuses people most times
    Like I said a hole in the front section of the cab allowing water to spray in on the ECM but then there should also be water on the floor
    Unless it has been taken apart except for the electrical connections it is pretty water tight.
    mechanicjon likes this.
  6. Apr 20, 2017 at 1:40 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Yes on top pf evaporator box or suitcase as I've heard it called before.
