ECU wiring 5vz engine.
Discussion in '1st Gen. Tacomas (1995-2004)' started by JPricer, Aug 13, 2023.
  1. Aug 13, 2023 at 12:27 AM
    JPricer
    JPricer [OP] Member
    I have a question about the wiring from my ECU to my injectors.
    I need to know if the wire that goes from the fuel injector to the ECU is on pin 1 or pin 2 on the fuel injector. I found some engine wiring diagrams of the 4 cyl and that suggests its on pin 1. Is there anybody with an engine diagram that can confirm this is the same with the V6?
    There are no markings on the injector connecter that can give me a clue.
    Thank you in advance!
  2. Aug 13, 2023 at 12:35 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    My 2000 3.4 is pin 1 Be careful yours might be different.
    pin 2 goes to the ignition switch AM2
  3. Aug 13, 2023 at 12:47 AM
    JPricer
    JPricer [OP] Member
    Thanks! How do i find out how mine is wired?
    Is there a way to look at the injector and know what pin is nr 1 and what pin is nr 2?
  4. Aug 13, 2023 at 12:58 AM
    JPricer
    JPricer [OP] Member
    The reason that I need to know for sure is that I need to buy an injector cut-off wiring set and thats available straight and inverted haha
  5. Aug 13, 2023 at 12:58 AM
    Bivouac
    Always good to tell as much as possible Year /Mileage /Engine / Transmission the more we know the easier to help.
    With the Pig tail from the injector facing you the clip on the top # 1 should be on your left.
  6. Aug 13, 2023 at 1:03 AM
    Bivouac
    Pray tell what are you trying to fix or do?
    Solder and heat shrink the connections.
    Good luck!
  7. Aug 13, 2023 at 1:04 AM
    JPricer
    JPricer [OP] Member
    Thanks for the help. It’s an 2002 Tacoma 4x4 manual with a V6 engine. Mileage about 180k. I took it to Europe after my stay in the states.
  8. Aug 13, 2023 at 1:07 AM
    JPricer
    JPricer [OP] Member
    I need the signal from the gasoline ECU for the Propane ECU. I could solder it but I would prefer a wiring harness with proper connectors. These are available here but then I need to know what pin the signal goes through.
  9. Aug 13, 2023 at 1:09 AM
    JPricer
    JPricer [OP] Member
    in that case the ECU signal goes through pin #1. Thanks!!
  10. Aug 13, 2023 at 1:20 AM
    JPricer
    JPricer [OP] Member
    So just confirm. In the photo I circled the right pin?
  11. Aug 13, 2023 at 1:20 AM
    Bivouac
    Now the rest of the story !
    Curious to hear how this works.
    Where do you plan to mount the tank permanent or easy to swap.
    what size tank?
    Good Luck !!
  12. Aug 13, 2023 at 1:22 AM
    Bivouac
    :thumbsup::thumbsup::thumbsup:
  13. Aug 13, 2023 at 1:28 AM
    JPricer
    JPricer [OP] Member
    I have not decided on that. It’s either a 40gl tank in the bed or a 15gl on the spare wheel spot. It will be permanent.
    Bivouac[QUOTED] likes this.
  14. Aug 13, 2023 at 1:30 AM
    JPricer
    JPricer [OP] Member
    Its not a very complex conversion. 99% of the imported American truck are propane here.
  15. Aug 13, 2023 at 1:34 AM
    JPricer
    JPricer [OP] Member
    In that case my signal wire is on #2. So weird it’s different on same engines. Yours was on pin 1 right,
  16. Aug 13, 2023 at 1:46 AM
    Bivouac
    Correct!
    Are you looking at the Harness connector
    that is what you should be going by .
    The plug facing you the clip on top like your going to plug it into the injector .
    The 2000 and 2001 are on pin one which is on the left
    The wires going to the ignition switch should all be the same color.
    Not having the Correct wiring diagrams for the vehicle your working on is very frustrating!
  17. Aug 13, 2023 at 1:53 AM
    JPricer
    JPricer [OP] Member
    Haha yes it is. I have to buy the factory book some day.
    On the photo that I sent I cirkeld the pin I thought is the #1 pin. When I look at the harness connector that is the positive wire (with the same colour for every injector). That gives me the Ecu wire is on pin #2.
  18. Aug 13, 2023 at 1:57 AM
    Bivouac
    Now you have it figured out
    Just a year difference changed things!!
  19. Aug 13, 2023 at 1:58 AM
    JPricer
    JPricer [OP] Member
    Thanks for the help!
    Bivouac likes this.
  20. Aug 13, 2023 at 2:06 AM
    Bivouac
    Your very welcome!!
    Not a problem Glad we figured it out!!
