Ecu/wiring
Discussion in 'New Members' started by jpangelinan671, Apr 13, 2024.
  1. Apr 13, 2024 at 2:10 PM
    jpangelinan671
    jpangelinan671 [OP] New Member
    96 single cab
    Hello,
    I was given a 96 tacoma with a blown motor. Not knowing anything, I purchased a new 2rz due to it does not have distributor anymore. I was able to source out the correct wiring harness, but I'm stuck on getting an ecu. Motor mated with trans and is in the truck just confused on ecu's. I'm $1k into purchasing ecu's and harness at this point. Any help would be appreciated.
    Thank you.
  2. Apr 13, 2024 at 3:30 PM
    sublimaze
    sublimaze Well-Known Member
    Welcome aboard!
    If you don’t get the answer here, try posting in “1st gen Tacomas” section. Good luck!
  3. Apr 13, 2024 at 3:35 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Welcome
    "Help" in the title is reserved for those needing immediate assistance IE vehicle physically stuck somewhere, stranded, etc
    Change your title, and head over to the 1st Gen section to post there
    Include specifics about what you really need, and someone might have what you're looking for
  4. Apr 13, 2024 at 3:43 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    post the part #s of the ecus and then the part #s of the harness you have.
