ECU
Discussion in 'Technical Chat' started by devkurf, Jun 17, 2023.
  1. Jun 17, 2023 at 8:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    See if you can find the X6 connector.
    Test for power there.
    Bivouac and Dm93 like this.
  2. Jun 17, 2023 at 8:13 PM
    devkurf
    devkurf [OP] Member at Large
    midwest
    0.12 volts
  3. Jun 17, 2023 at 8:16 PM
    TnShooter
    Deogee
    STOCK
    So you have 12v coming out of the switch?
    But only .12v making to the X6 connector?
    Are you back probing the connector?
    You can’t really test that connector with it unplugged.
    Power comes in and out of it…..
  4. Jun 17, 2023 at 8:18 PM
    devkurf
    midwest
    Yes, the connector is plugged in with the key on, and stuck the probe in the back
    Dm93 and TnShooter like this.
  5. Jun 17, 2023 at 8:19 PM
    TnShooter
    Deogee
    STOCK
    You found a problem:thumbsup:
    Now, it’s up to you on how you want to fix it?
    Dm93 likes this.
  6. Jun 17, 2023 at 8:21 PM
    devkurf
    midwest
    I just got under ther again, and pulled the wire cover back. It’s chewed in two from a furry little tenant.
    Bivouac, Viaccess4x4, Dm93 and 2 others like this.
  7. Jun 17, 2023 at 8:22 PM
    TnShooter
    Deogee
    STOCK
    Well, now we know :thumbsup:
    Bivouac, Dm93 and koditten like this.
  8. Jun 17, 2023 at 8:24 PM
    devkurf
    midwest
    Thanks for all your help, I had been looking at this thing for 2 days straight. I had about given up.
    Dm93, koditten and TnShooter like this.
  9. Jun 17, 2023 at 8:25 PM
    TnShooter
    Deogee
    STOCK
    No Problem
    Happy to help.
  10. Jun 18, 2023 at 5:55 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did you get it spliced and test ran?
    We need closure!
    Bivouac likes this.
  11. Jun 19, 2023 at 6:12 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I thought open circuit from the start just the question of finding it.
    Schematics make this so much easier!
    TnShooter likes this.
  12. Jun 19, 2023 at 9:59 AM
    devkurf
    midwest
    Sorry, yes. Cut the chewed wire further up the harness and capped it off. Then tied the dead wire going into the ECU directly to the wire that sends power when the PTO switch is pulled. That leaves the mower with the seat and brake switches intact and just removes the reverse switch from the equation which is what I wanted to do anyway. It ran and mowed great.
