Edan's Parts Changin Kinda Overlandish Build
Discussion in '3rd Gen. Builds (2016-2023)' started by edansnatches, May 23, 2017.
  1. May 23, 2017 at 11:52 AM
    edansnatches
    edansnatches [OP] Well-Known Member
    erik
    wv
    2016 trd off road mgm
    icon 2.5 ext coilovers , icon resi rears dakar's lr uca's 255/80/17 wildpeak at3w Scs sr8’s are v series ccg 'merica trd grill
    This thread is to keep up with my changing of parts....
    Wheels, Tires & Suspension
    - Icon 2.5 Coilovers Extended Travel 650# Coils
    - Icon 1/4" Top Plate Spacer
    - Total Chaos Uniball Upper Control Arms
    - Dakar HD Leaf Packs
    - Icon Remote Resi Ext Travel Rear Shocks
    - OME Carrier Bearing Drop
    - Extended Stainless Steel Rear Brake Lines
    -SCS SR8 17x8.5 10mm offset matte black
    -Falken Wildpeak AT3W 255/80 17
    - Full Size Spare
    -ECGS Clamshell Bushing Swap for Needle Bearing
    -Drivers Side Wheel Bearing upgraded
    Armor
    Pelfrybilt Standard Rear Bumper w Hidden Hitch
    Front Skid via my fabricator bro - Aluminum
    Transfer Skid - Same
    Working on trans and ifs skids, math is hard
    RRW Bolt on Sliders w kickout and gussets
    FUN TIME
    - KB VOODOO Mid Height Bed Rack
    -ARE V Series Camper w Lotsa Lights
    - Kobalt D handle shovel and Axe in Quick Fist Clamps
    - Tuff Stuff Recovery Treds w Custom aka Home Made Mount
    - Quick Fists here and there
    -GOPRO Session
    Electrical
    -Blue Sea Fuse Block - Modified to Split 6 Always "Hot" 6 Switched on Relay
    -2 50 Amp Breakers
    -2 12v Acc Plugs in Bed
    -2 USB ports in Bed
    -Voltage Meter in Bed
    -Midland 75-822 2 in 1 CB
    -Fire Stik 3' Tuneable 'Merica Antenna w Fire Ring
    -Fire Stik Door Jamb Mount in Bed
    -750 Watt Inverter
    - "Performance" -
    -TRD Filter
    - Shift Enhancement TSB
    - Cosmetic & Miscellaneous -
    - Front: Carbon Fiber Tint, 32% Sides/Rear
    -Custom Car Grills 'Merica TRD Grill
    -Cover King Rhinohide Black Seat Covers
    -Prinsu Cab Rack
    -ARE V Series Camper Top Yak Racks
    -uhhh some stickers...... not so much into the cosmetic only
    - Lighting -
    - Rago Fab Ditch Light Brackets w/ Cali Raised 27W Side Projecting LED Pods
    - LED Strip Camp Lights Wired for 12V ACC Plugs in Bed
    - LED Pods in Bed For Camp Lighting/Reverse Lighting - Not Installed Yet
    - Baja Designs S2 Pro Flush Mount Reverse/Rear Lights in Pelfrybilt bumper
    -Lexus LED Fogs
    -LED Lows and Highs w Heat Sink Fins
    -LED Brake Lights and Reverse Lights
    - Gear -
    - RoofNest Sparrow X
    - Tuff Stuff Roof Top Tent w/ Annex
    - Tuff Stuff 4x7' Awning
    - RTIC 45 Cooler
    - RTIC 20 Soft Side Cooler
    - HF150 High Output Compressor
    - Pelican 1550
    - Weather Tight Storage Containers
    - Action Packers
    -Front Runner Wolfpack x 2, metal latches
    - Plano 42" Tactical All Weather Case
    Want List
    aluminum front bumper/winch
    Pelican or other weathertight tactical gun case for roof rack
    bubba rope
    mo shackles/another snatch block
    BloodyTaco and trlfrk like this.
  2. May 30, 2017 at 6:58 AM
    edansnatches
    erik
    wv
    Memorial Day 2017
    Powerprozeus and BloodyTaco like this.
  3. Aug 11, 2017 at 8:37 AM
    GROOT5252
    GROOT5252 Well-Known Member
    2017 Toyota Tacoma 4X4 DCLB Quicksand
    Did you get the Dakar light/medium leaf pack or the heavy leaf pack?
  4. Aug 11, 2017 at 8:40 AM
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    Nice truck! Looks great.
  5. Aug 11, 2017 at 11:04 AM
    edansnatches
    erik
    wv
    This is the light/med leaf pack, gained 2 7/8" after 3 months, was at 3 1/4" after install.
    Thanks brother.
  6. Aug 28, 2017 at 8:57 PM
    edansnatches
    erik
    wv
  7. Aug 28, 2017 at 9:00 PM
    edansnatches
    erik
    wv
  8. Aug 28, 2017 at 9:01 PM
    edansnatches
    erik
    wv
  9. Oct 10, 2017 at 7:52 PM
    edansnatches
    erik
    wv
    New river gorge. Prince to thurmond, thayer.
  10. Oct 11, 2017 at 7:23 AM
    BloodyTaco
    BloodyTaco Well-Known Member
    Luke
    Colorado
    17 TRDOR DCSB
    Awesome start, subd!!
    edansnatches[OP] likes this.
  11. Oct 18, 2017 at 6:10 AM
    edansnatches
    erik
    wv
    thanks brother
  12. Oct 18, 2017 at 6:17 AM
    edansnatches
    erik
    wv
    Pelfrybilt rear arrived! Install this weekend.
  13. Nov 16, 2017 at 7:48 AM
    edansnatches
    erik
    wv
  14. Nov 16, 2017 at 7:55 AM
    Powerprozeus
    Powerprozeus IG: @1987toyota4r
    Aaron
    Birmingham, AL
    2016 Quicksand TRD OR 4x4 / 1987 4Runner SR5
    Awesome build! Looks great!
  15. Nov 16, 2017 at 10:32 AM
    edansnatches
    erik
    wv
    thanks brother
    Powerprozeus[QUOTED] likes this.
  16. Jan 17, 2018 at 4:55 PM
    mhshark
    mhshark Well-Known Member
    Bend, Or
    Now that you’ve had the coils on for awhile how do you like your front setup? Still close to 3” after settling?
  17. Jan 17, 2018 at 7:05 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    Sick truck man!
  18. Jan 31, 2018 at 5:38 AM
    edansnatches
    erik
    wv
    sorry for the late response, lots of family badness happened. Things are getting near normal again. Front end still performs well I have obtained a few squeaks that I've tracked down with normal wear and tear on the trail. I have beat the front end pretty hard late fall and this winter. sitting today at 2-7/8" up front settled from 3-1/4 initially and hasn't settled since the first 3 months it was on the truck.
    Thanks man!
  19. May 31, 2018 at 9:19 AM
    edansnatches
    erik
    wv
  20. May 31, 2018 at 9:20 AM
    edansnatches
    erik
    wv
    Blue ridge parkway and grandfather mtn
