Edge CS2 gauge display with temp sensor and pressure sensor. $500
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by tacotunner06, Dec 7, 2022.
  1. Dec 7, 2022 at 10:37 PM
    tacotunner06
    tacotunner06 [OP] Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    I'm selling the edge cs2 out of my truck. I had it installed with an ls3 swap but its obd 2 so could be installed into anything really. This pulls gauges from the obd2 port along with diagnostic codes. It also comes with extra sensors to add for pressure and temperature. I used this for oil temp and pressure but could be used for anything you want to add that the ecu doesn't monitor or display. I originally had it setup to use in front of the coolant temp gauge since with my ls swap that wasn't working. currently its designed to be screwed into the top of the steering column like this
    but i could rework the bracket real quick to move it back up if desired. $500
  2. Dec 11, 2022 at 6:36 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
  3. Dec 28, 2022 at 12:28 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
  4. Jan 18, 2023 at 11:31 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
  5. Feb 23, 2023 at 11:50 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
  6. Aug 10, 2023 at 8:06 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
