EDIT FOUND : Balls Out Offroad RAM Mount
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Taco505, Apr 4, 2019.
  1. Jan 3, 2020 at 6:47 PM
    #41
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    I have the same wireless charger. Do you recall the connecting portion you used that ties into the back of the wireless charger?
  2. Jan 4, 2020 at 10:24 AM
    #42
    the dashing ham
    the dashing ham Taco n00b
    Scotty
    Los Angeles
    '12 DCLB rattle can
    yes, I have done the mods
    You can get them here. They each use two 1/2" long 1/4-20" socket cap screws to mount. I put them on both sides, offset to the outside so that the climate controls aren't blocked by anything hanging. They use the bottom two threaded holes so the top hole is still available for a 1" ball, which is how I run mine - with an iPad mini mounted on that top hole, CB mic on the right, ham mic on the left.
    I've been running mine for two years now and they're pretty bombproof.
    kingk0ng and Manfred[QUOTED] like this.
  3. Jan 5, 2020 at 1:12 PM
    #43
    LukaszK
    LukaszK Well-Known Member
    Lukasz
    Elmwood Park, NJ
    2020 Tacoma DCSB Cement Grey
    If anyone happens to have an extra mount, just one, I’d be very interested in purchasing it.
    PM me the price if anything. Crossing my fingers that someone has one to spare (sell)
    Thank you in advance!
    Manfred likes this.
  4. Jan 31, 2020 at 11:51 AM
    #44
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Just like quite a few others on TW, I'm also looking for one, maybe two of these mounts. Reading the post by @the dashing ham on the mic hanger and clicking on the link, it appears the mic hanger was design to be used exclusively with Lostsheep's mount. Crazy how these mounts have just vanished.
  5. Feb 1, 2020 at 8:53 PM
    #45
    Taco505
    Taco505 [OP] Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    Another member PMd me asking more or less the same question. I have part of my response below, I hope it helps but let me know if I can clarify anything.
    “A few things to note if you're planning on using the charger I did.
    - The A RAM ball is 9/16"
    - The B RAM ball is 1"
    - The charger ball is somewhere in between, about 3/4"
    - With that said I had to "modify" the A RAM Ball to fit the charger. All I did was take a thick rubber band, cut it, then wrap it around the ball to add a bit of thickness. I then just stuffed the rubber band wrapped ball into the charger socket and tightened the nut. I've had to readjust it once or so during the weather change other than that I've had zero issues.”
