Edmonton Checking In
Discussion in 'New Members' started by Toy.Yoda, May 3, 2015.
  1. May 3, 2015 at 4:40 PM
    Toy.Yoda
    Toy.Yoda [OP] Member
    YEG, Alberta
    '15 DCLB MGM
    Revtek Lift and Level
    Hey hows it going? I got my tacoma last october and have no regrets and so many plans. Its a 15 dclb in magnetic grey. First question i have is how big of tires can i run with the revtek coil spacer and leaf block without cutting my cab mounts? Thanks
  2. May 5, 2015 at 8:18 AM
    Over da Hill
    Over da Hill "Roads...where we're going we don't need roads"
    Johnny
    SoCal
    15 Black Taco 4WD DC SB SC
    Supercharger, Icon stage 3 suspension, Pelfreybilt Armor, All-Pro Sliders & Leaf Pack, 17 inch Black Rhino Sidewinder wheels, 33 inch Toyo tires, Rigid Lighting, SPod,
    You can probably run 33's, but they will likely rub just a little in extreme positions.
  3. May 6, 2015 at 1:37 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Welcome!
  4. May 6, 2015 at 1:29 PM
    Jrozz
    Jrozz Well-Known Member
    Jonathan
    Colorado
    08 Acc TRD offroad
    My girlfriend lives in Edmonton! Welcome! And what size spacer lift are you gonna run? I would advice against spacers and blocks. Save your money and do it right
  5. May 11, 2015 at 7:32 PM
    Toy.Yoda
    YEG, Alberta
    '15 DCLB MGM
    Right now I have the revtek coil spacer in the front struts and the blocks in between the leafs. I found it for cheap so its temporary. Im saving for OME and dakar leafs. Soon.... :D
  6. May 11, 2015 at 7:43 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I run ~33's on my truck with bilisteins set at 2.5" of lift. Tire size LT 255/80R17. Cooper ST Maxx. Actual height of the tire is ~32.8". I had minor rubbing on the upper a-arms and I am running longer studs with 1/4" spacers to fix the issue. I also had to ditch the air dam flap and the mud flap to get the tires to not rub anything up front.
    When I have the money I will be getting rid of my stock upper a-arms and go with something aftermarket. Then I should be able to fit the tires without the spacer.
  7. May 12, 2015 at 8:07 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome to TW!
