Educate me on snow chains
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kevinlambchops, Dec 18, 2016.
  1. Jan 18, 2017 at 5:33 PM
    #181
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    Les Schwab up here has a similar style, don't think it's the same brand but I use them on my government vehicle all the time.
  2. Jan 18, 2017 at 6:21 PM
    #182
    woodywoodward
    woodywoodward Member
    Josh
    2016 tacoma dcsb
    Why wouldn't you guys run cables on all 4? I bought some z6 and want to know your thoughts?
  3. Jan 18, 2017 at 6:27 PM
    #183
    JoshyP
    JoshyP Well-Known Member
    Josh
    Northern California
    2016 TRD OR 4x4 DCSB MT
    I don't think you can run chains/cables on our trucks. The manual says only put them on the rear or they will hit the upper control arms.
  4. Jan 18, 2017 at 6:37 PM
    #184
    theredofshaw
    Need something for icy/snowy weather. Those chains are relatively low clearance. Cables would definitely be less clearance but they tend to break easier.
  5. Jan 18, 2017 at 6:44 PM
    #185
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    They do. Just depends on size. Won't fit 285 for example.
  6. Jan 18, 2017 at 6:45 PM
    #186
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    Chains or cables only get applied to the drive axle (or rear, in the case of 4WD). And yes, you can apply them to a Tacoma
    nudavinci64 and theredofshaw like this.
  7. Jan 18, 2017 at 6:45 PM
    #187
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Les Schwab used to buy back unused chains.
    theredofshaw likes this.
  8. Jan 18, 2017 at 7:43 PM
    #188
    theredofshaw
    Still do :thumbsup: even think they do if very lightly used.
    nudavinci64 likes this.
  9. Jan 18, 2017 at 8:21 PM
    #189
    Biggums
    Biggums Well-Known Member
    Jade
    SoCal
    You may want to check O'Reilly's. I just called and inquired about cables that would fit 285/70/17 and they have them in stock. I'm really having a hard time deciding if I really need them for my trip this weekend. Spending $100 with a chance I might not even need them has held me back. I have snow rated tires and 4x4 but the mountains down here are supposed to get hammered.
  10. Jan 18, 2017 at 8:25 PM
    #190
    theredofshaw
    Buy them and return afterwards. If you don't use them they should take them back, especially if it's only a weekend trip. I would rather have them and not need them.
  11. Jan 18, 2017 at 8:32 PM
    #191
    Cuffs
    If CHP asks to see them and you don't have them you will get a ticket or turned around.
  12. Jan 18, 2017 at 8:48 PM
    #192
    Biggums
    Jade
    SoCal
    Nonrefundable. Most places you buy them from will tell you ahead of time.
  13. Jan 18, 2017 at 8:49 PM
    #193
    Biggums
    Jade
    SoCal
    My buddy has a set of chains but don't fit my tires. Thinking about just bringing them along and flashing them if asked to see them. I'm almost certain I won't need chains, but I know you are required to carry them.
  14. Jan 18, 2017 at 9:02 PM
    #194
    nudavinci64
    Robert
    Went a head and purchased a set from 4WheelParts. I will pick them up on my way up on Friday. they were $115 plus tax. They had a small coupon and used Ebates to get 3 or 4% cash back as well.
  15. Jan 18, 2017 at 9:10 PM
    #195
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I have 265/75-16s on stock alloy wheels and there is no cable made that will safely fit on the front. There is less than 1/4" of clearance between the sidewall and the bump on the knuckle. Probably closer to 1/8" than 1/4". Try to run your hand back there and see what you have. If you have maybe half an inch of clearance static and at full stuff them you might get away with one of these very low clearance cable options. But if they come apart you could easily damage something like an ABS sensor.
    http://www.peerlesschain.com/brands/traction/technical-information/limited-clearance-issues/
    Nickel likes this.
  16. Jan 19, 2017 at 5:44 AM
    #196
    theredofshaw
    You aren't suppose to chain the front, only the rear on tacomas. Says it in the manual.
    FredRed315 likes this.
  17. Jan 19, 2017 at 5:52 AM
    #197
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    So, the "S" class cable does not apply?
  18. Jan 19, 2017 at 6:36 AM
    #198
    steelhd
    Eastern WA
    2011 DCSB TRD OR
  19. Jan 19, 2017 at 6:51 AM
    #199
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Manuals are written around stock configuration and to the lowest common denominator. Look at how many folks show up on TW asking if it's possible without having ever stepped out to their garage or carport and physically checking their actual clearance first. If the manual didn't say that many people would chain up the front, tear things up, and go to the dealer demanding a repair.
    If I were to run 235/85-16s with the correct wheels I could run S class cables long enough to get me off an icy mountainside If I were to install longer studs and 3/8" spacers or just install standard spacers in the winter I wouldn't need the 235s. But then we are talking about non-stock configurations and all the risk is on the owner. A manual can't cover those scenarios.
  20. Jan 19, 2017 at 7:53 AM
    #200
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    I just saw this is 3rd Gen.
    Gonna check it out my self. My T100 takes them fine. 265 70 16, 265 75 15, 31 10.5 16. Chains in the back cables in the front. Makes for better steering.
