EE Needed! LED step-up booster wiring question
Discussion in 'Technical Chat' started by FreidTaco, May 6, 2014.
  1. May 6, 2014 at 9:36 PM
    FreidTaco
    FreidTaco [OP] boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
  2. May 7, 2014 at 9:51 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Hmmm. This might seem like a stupid question, but why do you want to boost the voltage to the LED bar since it can already work on your 12V system?
    Looks like you have your 12V negative ground common with the negative output of the voltage converter, the positive output of the voltage converter switched by a relay which feeds power to the LED bar. I don't see a problem with this.....however, keep in mind that a DC to DC converters are switching power supplies which typically generate noise. You may introduce noise which could cause problems with things such as your audio system.
  3. May 7, 2014 at 9:54 PM
    FreidTaco
    jeff
    More light
  4. May 7, 2014 at 10:11 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Uhh...what?
    P=IV
    If you increase voltage, just means it will draw less current. The bulbs in your LED bar don't magically put out more power.
  5. May 7, 2014 at 10:13 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    OK...So I'm assuming the higher voltage input, the higher the light output?
    Do the specs for the LED bar state different output in lumens at different voltages?
  6. May 7, 2014 at 10:14 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I'm not a EE so I may be off on this and my terms may not be correct. Some of the LED lights that I have come across run on a constant current source. It will internally vary the voltage to hit the current needs of the light. So you can basically throw any voltage and current at it within its specified range and you are still going to get the same output. Depending the the light you may need to mess with the internal circuits to get a higher output. You aren't going to want to drive those LED too much more than what they are already doing. You will likely just get more heat output and not much more light.
  7. May 7, 2014 at 10:15 PM
    FreidTaco
    jeff
    I keep reading and seeing different outcomes from various sources.
  8. May 7, 2014 at 10:19 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Every LED bar I've seen internally regulates the power output of the LED's.
    Throw as much voltage as you want at it, still gonna be a 3 watt LED (or 5 or 10...whatever you bought). Double the voltage just means half the current draw.
  9. May 7, 2014 at 10:20 PM
    Tacomaruss
    Tacomaruss Active Member
    Russ
    Leduc
    Alpine White 2013 TRD Trail Teams
    My understanding of an LED "bulb" is that its basically on or off. Unlike an incandescent bulb, it will not be brighter with a higher voltage. So save your money and buy a cool switch for that beast instead..just my 0.02.
  10. May 7, 2014 at 10:21 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    If the LED bar has a wide input range, it stands to reason that is has some sort of internal circuitry(a driver) to regulate voltage and current to the LEDs. You can apply different voltages within this range but I doubt that it is going to vary the brightness of the LEDs.
    LEDs are designed to run at specific voltages and the brightness depends on how much current (amps) you pass through them. The internal driver is going to regulate this no matter what voltage you apply.
  11. May 7, 2014 at 10:23 PM
    FreidTaco
    jeff
    Well I got an unbranded one from hong kong. So I don't know all of the circuit board set up operations.
  12. May 7, 2014 at 10:25 PM
    FreidTaco
    jeff
    Well I guess I learned something.
  13. May 7, 2014 at 10:26 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Power regulation is required for passenger vehicles as there's 2-3 volt delta just between a vehicle running (with alternator doing it's thing) and a vehicle shut off. Since you need the regulator anyways, it's not that big of a change for the manufacturer to include a regulator to be capable to accept 24+ volt systems (semi trucks, tractors, military applications, etc.)
  14. May 7, 2014 at 10:26 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Hong Kong huh?
    Sounds like "Sum Ting Wong" to me LOL!:rolleyes:
  15. May 7, 2014 at 10:31 PM
    FreidTaco
    jeff
    No. I am also in the process of changing out some of the fog lenses to spots as well. 48 of the 96 are floods.
  16. May 7, 2014 at 10:36 PM
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    Typically these light bars have a range for input voltage for different applications. Example would be tractors that run on 24v or some forklifts with 36v battery banks. If the specs on your light bar does not show a range for lumens, then it's safe to say it only outputs the maximum regardless of voltage input.
  17. May 7, 2014 at 10:41 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Ok. I have LED bulbs for my headlights and fogs. they both have LED "drivers" which regulate the voltage and current seen by the LED bulbs. I suspect your Light bar has something similar, perhaps internal.
    Here's a thought...before you go off and wire up a power supply, try bench testing your light bar with 12V and 24V to see if there is any difference in output. You should be able to connect two 12V batteries in series to provide the 24V if you don't have the voltage converter yet. I suspect the light output will not change.
  18. May 7, 2014 at 10:44 PM
    FreidTaco
    jeff
    Oh I wanted to bench test it but only have a battery charger with outputs of 6v or 12v. Anyway I could use a battery charger and battery on my pickup to make this work?
  19. May 7, 2014 at 10:56 PM
    SGT Taco
    SGT Taco It all fun and games till its not.
    Scott
    Spring Hill TN.
    R.I.P. 2007 TRD, Land Rover Disco II, F250.
    Wife rolled it 3x mod...
    Do not use a charger to try to up the volts I a series circuit.
  20. May 7, 2014 at 10:58 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Yes, that will work. Connect the Positive cable to the Negative battery post. Then take the Negative cable and run it to your light bar. Now run a wire (jumper cables?) from the Positive battery post to the light bar.
    You might want to make sure your charger is set to 6V or 12V low. Battery chargers can often put out in excess of 16V to 18V with no load. You don't want to accidently exceed the 36V rating of the light bar.
