EEK! Driving with the locker on
Discussion in '1st Gen. Tacomas (1995-2004)' started by Adrian.Brewster, Apr 20, 2018.
  1. Apr 20, 2018 at 12:45 PM
    Adrian.Brewster
    Adrian.Brewster [OP] Well-Known Member
    Adrian
    2020 trd off road
    hey guys
    I did a dumb thing yesterday. When I was reinstalling my 3rd member was forgot to manual disengage the locker. So today I woke up, hopped in the truck and drove 10 miles on the highway going about 65mph. It was only when the wheels started hopping when I got off the highway that I realized the rear wheels were locked. I pulled into an orielly parking lot, pulled off the locker and manually switched it back.
    My question is, what kind of damage could I have done by driving with the locker on at 65mph and around turns at 15mph? The truck is driving fine now. But I’m worried about internal damage I can’t see.
  2. Apr 20, 2018 at 12:45 PM
    Adrian.Brewster
    Adrian
    2020 trd off road
    Oh. This is on a 2003 trd off road
  3. Apr 20, 2018 at 12:53 PM
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    If damage didn't show its head immediately, in the form of bangs, pops, or the inability to move when you press the gas, you're probably fine. May you have shaved some of the lifetime off the diff? Maybe, maybe not. If you don't hear anything that sounds odd when driving, I'd say you're fine to drive it until you give that differential a better reason to blow up.
    Straight line travel isn't really harmful, as the spider gears don't turn independently of one another much. Turning is when damage would show up, and if it's working okay now, it's probably gonna stay fine for a while.
  4. Apr 20, 2018 at 1:35 PM
    Adrian.Brewster
    Adrian
    2020 trd off road
    I sure hope you’re right. I’m going to drain the fluid and see if any metal chunks are in there.
    hoverlover likes this.
  5. Apr 20, 2018 at 1:36 PM
    Adrian.Brewster
    Adrian
    2020 trd off road
    Has anyone else driven above the recommended speed with the diff locked?
  6. Apr 20, 2018 at 1:48 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Yes, all the time. The speed is not a problem at all, as stated the issue is turning when you have high grip. I used to use mine off road all the time and would leave it locked all weekend. The manual says you dont want to "engage" the locker over the specified speed, that means you dont want to hit the button and go from unlocked to locked above that speed, not you cant drive while already locked above that speed
  7. Apr 20, 2018 at 1:51 PM
    Adrian.Brewster
    Adrian
    2020 trd off road
    That makes a ton of sense. Unfortunely, I did turn probably 15 times total with it locked. And I was on pavement... on new grippy tires. Is there is way to check the gears and make sure I didn’t destroy anything? I’ve driven it about 30 miles since and it seems to be driving fine.
  8. Apr 20, 2018 at 2:03 PM
    Bullnettles
    Bullnettles Well-Known Member
    Jared
    Houston
    2017 OR DCSB
    You probably took more life from your tires than you did your diff.
  9. Apr 20, 2018 at 2:04 PM
    Adrian.Brewster
    Adrian
    2020 trd off road
    That would be great. I’m not worried about my tires at all. Just the rear diff I just spend a week taking apart and putting back together.
  10. Apr 20, 2018 at 2:07 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    You'll be fine, it happens. Truck's diff is pretty strong and lots of folks drive with even worse (welded diffs)
  11. Apr 20, 2018 at 2:08 PM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    I had an e-locker with a DIY controller on a 89 Toyota Pickup. The controller had a wire break on the lock indicator light and I drove about 80 freeway miles home with the diff locked. Didn't notice till the next morning because the rear tires had a polished look to them. Drove this truck another 10K miles after that without any problems with the rear end. When I changed the gear oil the drain plug magnet had the typical amount of metal particles.
    IMO you will be fine.
  12. Apr 20, 2018 at 2:40 PM
    Adrian.Brewster
    Adrian
    2020 trd off road
    Phew, this is what I was looking for! I just wanted to hear from someone who had "been there, done that" and didnt have anything blow up on them.
    I appreciate the feedback
  13. Apr 20, 2018 at 2:42 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    You're fine. If it still engages and disengages, you've got nothing to worry about.
  14. Apr 20, 2018 at 2:43 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    No problem
    I’ve ran on the pavement plenty of times when you stupid diff won’t unlock
    MicComa likes this.
  15. Apr 20, 2018 at 2:46 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    You should be fine, the tires take the brunt of the speed difference because the rear end is light.
  16. Apr 20, 2018 at 3:01 PM
    Adrian.Brewster
    Adrian
    2020 trd off road
    Thats a good point. And the only thing I had in the bed was my canopy. So hopefully it just skipped the tires a bit and didnt wear out the gears.
  17. Apr 20, 2018 at 4:24 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    The only real problem you can get from driving around locked up is you twist the splins on the axel shaft after turning alot with the wheels locked up, if the locker is strong nothing will happen to it.
    cruxofthebisquit likes this.
  18. Apr 20, 2018 at 4:57 PM
    toyrunner
    toyrunner Puddle Jumper
    Danny
    Pasadena, Ca.
    2004 4X4 Tacoma TRD Xtra Cab
    Kings in front, Bilstien Reservoir rears, Custom sway bar disconnects, 265/75 16 BFG AT's, ARB front bumper and FROR rear bumper. Bao-Feng 2 meter radio and Cobra CB
    Normal driving will not harm the e-locker. When you are offroading and really using it, no damage is done. What causes issues is spinning the tires and them grabbing suddenly. That will chip gears and or twist the axle splines and break axles. I drove from Oregon to Los Angeles with the locker engaged. No issues. The e locker motor was stuck and no tools to pull it off to disengage it. Kind of noisy at the gas station parking lots and a lot of eyes watching me!
  19. Apr 20, 2018 at 10:16 PM
    Adrian.Brewster
    Adrian
    2020 trd off road
    Wow! That makes a ton of sense. And hey, if your truck made it 1000 miles with the locker engaged, that gives me a ton more confidence. I just drove the truck for a few hours and it seems to be just fine.
  20. Apr 20, 2018 at 10:45 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Lots of hot rod guys who drag race either have a welded diff or a fully locked diff all the time(when they are being cheap, watch road kill lol) which is good for big smokey burn outs and stairr when theydrag racing but no good for road cars, but they still drive them on the street, after going around corners alot it will start to twist the splins on your axels. But thats after tons of miles of turning.
