EFI fuse near battery. What does it control?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hansel, Apr 23, 2013.
  1. Apr 23, 2013 at 7:45 AM
    Hansel
    Hansel [OP] Well-Known Member
    Glenn
    Arizona
    base
    In a 2003 base truck there is a fuse box near the battery. One of the fuses is marked EFI. What is the function of this fuse?
    Reason I ask is that I want to crank the engine over in order to build up oil pressure without actually starting the engine...if this fuse cuts out the fuel injectors from functioning, then maybe this is the way to do it.
    thanks
  2. Apr 23, 2013 at 9:42 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    I always prefer to disconnect the coils to crank an engine without starting it for oil pressure build. The EFI fuse will work, because it is one of the power fees for the ECU, but I have personally just disconnected coils myself.
